New Member With Implement Questions
/ New Member With Implement Questions #1
Dranrab
Perkinston MS
Mahindra 1626 HST
Hi folks. Great forum and great group of members here. I have been reading fairly extensively here over the past several days and have been learning quite a bit. My newbie questions are going to be about implements rather than what tractor to buy. I am slowly closing in on the right tractor for me.
I have 10 acres in South MS. About 2 1/2 are cleared in some fashion. The parcel is pie shaped with intermittent creek beds along the edges. It's high and dry in the center. The soil is somewhat sandy with some light clay. The land had been mostly clear cut about 10 years ago. Some nice hardwoods were left along the edges, so it's going to be pretty when I am done. Some pines up to about 12" in diameter were left scattered about. I had a forestry mulcher come in and clear about an acre at the back. He cleared about a 20'x 300 foot driveway leading to about 3/4 of an acre cleared house pad in the middle. Then I had him clear about a 6' wide walking path completely around the perimeter. It's right at 1/2 mile long. I also had about a 30x100 strip cleared off to the side so that if I decide to bring in a shipping container or build a metal building I will have a place to kind of hide it.
The land was a tangled **** of yaupon and other assorted brush. I can walk through anything, but this stuff was impenetrably thick. I mention that to give you an idea of the root mess that lies beneath the surface of the cleared areas. That and some decent size pine stumps. With the walking path, I just want to level it off and smooth it out. some grass will eventually grow back in. I want to haul in some gravel or lime rock and distribute it out over the driveway. I will also need to install a small culvert in the driveway at the road's edge. I want to smooth out the house pad area and eventually get grass to grow there. The house won't be built for five or so years. The back acre will be planted in food crops in the spring and summer and a food plot in the winter.
For leveling gravel and dirt, am I better served with a grader/scraper or box blade implement?
For preparing the back acre for a crop, will a disc harrows cut the yaupon roots up well enough or would another implement be better. Do I need a tiller if I have a good disc?
If I bring in a container or build a garage, I'll have some red dirt brought in to firm up the foundation. I'll need to scatter and level it. Is a box blade or grader/scraper the best tool for the job?
When I shop for a bush hog for the walking path and the house pad, since I will likely hit a stump every now and then, do I need a bush hog with a clutch? If I get a tiller do I need one with a clutch?
The soil at the road's edge is fairly soft. I know it isn't ideal, but is the FEL on a 25 HP tractor capable of trenching enough to install a 12 inch culvert?
Any other suggestions?
I am brand new to all of this and still very ignorant, so if my terminology is incorrect or I seem confused about something, please clear me up.
Thanks, Paul
/ New Member With Implement Questions #2
The most efficient way to shop for tractors is to identify potential tractor applications first, then determine bare tractor weight necessary to safely accomplish your applications.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Heavier tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second and (narrowly) rear wheel ballast third.
A quality dealer, reasonably close, available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after seven years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
Twenty-five horsepower tractors vary from 1,800 pounds bare tractor weight to 2,800 pounds bare tractor weight. A 2,700 pound bare weight tractor will be enough for maintenance on your land if you are a patient operator.
Clearing stumps and trenching for a culvert is work for an excavator. The wear and tear you will inflict on a 2,700 pound bare tractor weight tractor will exceed the cost of bringing in an excavator which is designed for this work. Have all the stumps removed from your paths. Twenty-five horsepower can only spin a light-duty 60" Bush Hog. Hitting stumps with a light-duty Bush Hog regularly will have it in the shop for new, straight blades every six months. Nor will the light-duty Bush Hog gearbox survive repetitive stump contact.
Tractor Loaders on 2,700 pound bare weight compact tractors are designed primarily for lifting. Tractor heavy work should be accomplished via Three Point Hitch mounted implements. Tractor are designed to PULL.
I want to haul in some gravel or lime rock and distribute it out over the driveway. YES
/ New Member With Implement Questions #3
The land was tangled yaupon and other assorted brush. I can walk through anything, but this stuff was impenetrably thick. I mention that to give you an idea of the root mess that lies beneath the surface of the cleared areas.
I do not understand the past tense 'WAS' used here. Is Yaupon a problem or not?
A moldboard plow, either a single 14" or a double 12" will turn up all roots. Another option would be a three tine or four tine Field Cultivator, which will comb out considerable trash. PHOTOS
MORE: https://www.tractorbynet.com/forums/attachments/339095-dirt-dog-all-purpose-plow.html?highlight=
You will probably need to use Southern Ag Herbicide's Crossbow, Rural King's Crossroad or Gordon's Brush Killer in a one gallon sprayer to kill regrowth after six months. These are combinations of 2,4-d and Triclopyr.
Then go over the plow rutted land with a PTO-powered Rototiller to smooth it in preparation for seeding. For the light tractors you are considering a Rototiller will be more effective than a Disc Harrow. A Rototiller is also heavy, compact Three Point Hitch counterbalance for heavy FEL lifts.
The mulcher took the yaupons and other brush down to ground level. Now I have to eliminate the root network. Last weekend I spent some time spraying brush killer on some of the regeneration growth. I'll do some reading on a moldboard plow. Thanks for that info.
/ New Member With Implement Questions #5
Moldboard Plow will INVERT the soil. Everything deep will be brought to the surface, with the deepest soil/roots on top. There the sun will dry out the roots, killing about everything. Almost nothing but trees have roots growing deeper than 6" to 8".
Downsides:
Land will be rough after plowing.
Dig a pilot hole to determine how deep your top soil is. You do not want to mix infertile subsoil into fertile top soil. Moldboard plows for compact tractors come in 12", 14" and 16" increments for this reason. 12" is the classic "sodbuster" plow. But if thin top soil is not an issue another 2" does not hurt.
It takes some experience to become a proficient plowman. Faster to learn a single-bottom plow than a two or three bottom plow.
/ New Member With Implement Questions #6
I agree with Jeff and second the decision on an excavator for stumps. It sounds like you could use around a 5-10 ton machine. The bigger the quicker it will pull up stumps. If you have the room for it, a 20 ton will pull them out in seconds. It is all about weight and counterbalance...these huge machines have all you need. If you dont have room for it, then a smaller mini-ex at around 5-10 tons would get the job done. If it is really tight you might get by with a skid steer and a tree stumper, but they take a bit to get used to as well.
For tractors Jeff has you set. You need weight for moving dirt/plowing. You need HP for a mower. Do you need/want a cab?
I would say somewhere around the Kubota L series size. Other brands include Deere, Mahindra, RK, LS, Kioti, New Holland (its an LS), Massey Ferguson, Branson...and I probably missed a few. As Jeff mentioned find a good dealer that has in house service and longstanding business.
/ New Member With Implement Questions #7
Dranrab
A Box Blade is for transporting dirt short distances and leveling where you deposit dirt. (Cut off high areas, transporting spoil to fill low areas.) Moderate to long learning curve but skill worth having. Good in both fields and dirt roads. Final smoothing often accomplished via backdragging FEL bucket. Good Three Point Hitch counterbalance for heavy FEL lifts.
Land Plane/Grading scraper transports material only incidentally to leveling. Very short learning curve. "Recovers" gravel as it levels gravel roads.
Plows invert soil.
Disc Harrows and Rototillers do not invert soil, both mix soil, re-burying a portion of Yaupon roots. Light tractors operate Rototillers much better than Disc Harrows. Sometimes fresh roots wrap around Rototiller tines. Research 'L' shape tines Vs 'C' shape tines.
Parabolic tines on a Field Cultivator actually pull out roots, corms and other trash which then must be disposed of, usually my burning. Short learning curve. Deepest potential penetration, controlled by operator. Levels a little during operation.
Foundations do not comprise large areas. Backdragging FEL bucket for smoothing will suffice. Have the ROPS up and seatbelt fastened.
/ New Member With Implement Questions #8
I recently put a 12 inch culvert at my daughters house the driveway had been in for 2 yrs so it was hard packed rock .I was able to dig it out with the fel by starting at one side and take small bites took about an hr and i was surprised my 2810 was able to do it. so it can be done.
/ New Member With Implement Questions #9
Ifh you get a box blade you can use it to rip out roots also by lowering the shanks and tilting forward ,not ideal but it will work and your only buying one implement.
/ New Member With Implement Questions #10
Ifh you get a box blade you can use it to rip out roots also by lowering the shanks and tilting forward ,not ideal but it will work and your only buying one implement. I would get clutches on tiller and brush hog much easier than shear pins. Older cultivaters around here are fairly cheap so that is an option.
/ New Member With Implement Questions #11
Exercise caution with box blade and down rippers to tear it roots. Bigger roots will tear up a light duty box blade. Something has to give... the root first... then the box blade
... then the tractor. (Ask me how I know)
/ New Member With Implement Questions #12
True & true.
However, Box Blade shanks behind a 2,700 pound tractor will penetrate only 4" to 5". Box Blade shanks "snap" many more roots than a Field Cultivator, which rakes more roots out. This is related to 45 degree angle and thickness of Box Blade shanks Vs. parabolic shape of Field Cultivator tines, which move through dirt in horizontal orientation.
RE: PHOTO #2; I broke off one Box Blade shank off doing this cleanup. You can observe the Box Blade dragged out a lot of roots but a spring-protected Field Cultivator removes more, partly because it penetrates twice as deep.
I have both implements and plenty of experience combating Yaupon.
I am looking at a JD 3025, a Kioti 2610, a Mahindra 1526 and a few others in that class. They'll be fine for my intended use. I know the Mahindra and Kioti dealer. He's the brother-in-law of my best friend. He gave me a fair price on both of those machines. He's also the nearest dealer at 12 miles from my land. I am going to watch for decent used deals for a few more weeks before I commit.
I may have left the impression that I was going to be hitting stumps regularly. The few stumps are cut flush with the ground. I know where they are and will mark the area with orange paint before I begin work. I figured I might somehow accidentally hit one at some point. In the short term they will remain where they are. My question was about the function of clutches in bush hogs and tillers. Do I understand that they help prevent damage to the PTO and the implement correctly?
Dranrab
Plows invert soil.
I will likely end up with a tractor that weighs about 2500 pounds sans FEL and implements. I have used garden tillers before and found it maddening how often I had to clean debris out of the tines. It really wraps up in there good. I figured it'd be a bigger pain dealing with it on a large PTO driven tiller.
I paid a bud of mine a couple hundred bucks to come in with his 45HP Kubota and use a box blade with those ripping shanks over the main areas. He did some damage to it.
/ New Member With Implement Questions #17
My question was about the function of slip-clutches in bush hogs and tillers. Do I understand that they help prevent damage to the PTO and the implement correctly?
Yes. Properly adjusted slip clutches, re-adjusted periodically, will slip when the implement collides with an obstruction, ameliorating shock to tractor and implement.
Operating a Bush Hog, if you roll over a low stump with the blades and center "stump jumper", the stump may still slam into the rear turned down or riveted-on portion of the deck, which in theory keeps debris from flying out. Once this skirt is bent, the blades may then collide with the bent skirt. To the best of my knowledge, no light duty Bush Hog is available with preferred chain shielding front and rear.
/ New Member With Implement Questions #18
I have minimal rototiller experience so do not rely on this reply.
Few roto-tiller operators report more than infrequent root raps. Probably because a PTO rototiller is so much more powerful than a walk behind tiller they usually chop or shred roots.
A reciprocating saw deals with my infrequent ((Bush Hog and Disc Harrow)) root raps quickly.
T-B-N has a number of respondents who rototill commercially in really tough conditions. Hopefully one or more will reply.
Thanks for all your help Jeff. I really appreciate it.
/ New Member With Implement Questions #20
...I have used garden tillers before and found it maddening how often I had to clean debris out of the tines....
It all depends on what you're tilling...if a plot has not been cultivated for a while and has been allowed to grow wild it is more than likely you will get some wrapped up vines and they tend to catch other debris...
Best to mow with mulching blades prior to tilling or be prepared...There has been a few threads on the topic and the general consensus is to keep a nice sharp linoleum knife (large hook blade) handy...that and a pair of hand loppers make short work of even the hairiest bird nests...
2014 Mercedes-Benz GL 450 4MATIC AWD SUV (A61574)
2014 Mercedes-Benz...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
Caterpillar 214-224 Wheel Type Excavator Service and Parts Manuals (A63117)
Caterpillar...
2019 CHEVROLET EXPRESS 3500 PASSENGER VAN (A59912)
2019 CHEVROLET...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
