Closing on 16 acres, help with tractor choice
/ Closing on 16 acres, help with tractor choice #21
What is your terrain... Is it flat ground or have steep slopes.... Tractors and sloping ground are not a good combination.... I bought a SCUT (MF CG 1715) with intention of getting a 48 or 54 inch mower for behind, and after a few trips up and down some of my property, I think I was not quite intelligent in my decision to buy tractor and "brush hog" type mower when my JD riding mower feels a lot more stable on slopes.... Your terrain will have a lot to do on how successful you can mow... Any slopes need to be accessed in up and down manner not across the slope where the is a tipping situation due to tractors high center of gravity....
Kubota B265 with Land Pride FDR2572 in steep slope. - YouTube
The Danger of Tractors on Hills - YouTube
Dale
/ Closing on 16 acres, help with tractor choice #22
Friends,
I need a little help / advice. We're closing on 16 acres this month and I believe I'll need a tractor to run a bush hog to keep the place up. It was selectively logged about 5-6 years ago and would be considered "raw land". Not much terrain / hills but lots of low lying brush and some large trees. Here's where I'm at:
Looks like slopes isn't an issue
/ Closing on 16 acres, help with tractor choice #23
Good point on the test drive. On paper the machine I bought and another were very similar but when I sat in both I figured out that the "legroom" to the pedals on the cheaper tractor would have meant I would have to hold my foot up all the time to maintain pressure on the accelerator. And the "legroom" on the backhoe was similarly short.
Friends,
Lots of great advice and points of discussion; many thanks to all! I'm still learning quite a bit and have read through this thread many, many times. Here are a few updates on what I'm looking at doing:
1) having a local surveyor to mark the property boundaries with engineer tape. This land has not been subdivided before now and I can't afford any questions on property lines (the 4 corners are clearly marked already).
2) contracting a bulldozer for clearing the property lines. I'm still waiting on a call from my neighbor to the South who is presently in the middle of building their home.
3) contracting to have 5 or 6 strand barbed wire fence installed around the S, E, and N boundaries. We'll have pipe fencing across the front (west property boundary) by the road.
4) mowing / brush hogging as shown below in green and keeping a good bit of the property as a mix of wooded and pasture. In my original post I should have mentioned that I'm not going to try to make it all pasture and then mow it. The sketch below shows my current plan on how much I "think" I need to mow.
/ Closing on 16 acres, help with tractor choice #25
I have 12.7 acres of wood and field now.
/ Closing on 16 acres, help with tractor choice #26
I just bought a GC1705 with a FEL and 60” MMM to mow this, it’s about 6 acres and this pic shows about half of what I mow every Thursday. Right now for last three years I have been using my Cub Cadet 54 inch RZTL and about 5 hours. It used to be all hay land and it is ruff going, I’m disabled so it takes me longer to mow, less then 2 acres a hour due to slow speed because of all the bouncing around.
Thanks for the suggestion; congrats on the GC1705!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 HINO 268 S/A DUMP TRUCK (A59906)
2005 HINO 268 S/A...
2011 DOOSAN G25KW GENERATOR (A60736)
2011 DOOSAN G25KW...
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
Electric Golf Cart (A56859)
Electric Golf Cart...
Cat CB24B (A60462)
Cat CB24B (A60462)
