Clearing land for my building and yes more math problems
/ Clearing land for my building and yes more math problems #11
Google Earth will let you do all sorts of measurements, drawings and experimenting to see what works best for you before starting any site work.
/ Clearing land for my building and yes more math problems #12
Good advice so far.
I'll add. Unless your terrain lays perfectly you will eat up a lot of real estate landscaping for drainage. I'd be very surprised if you get by with half an acre.
I like Chris idea of scaling everything.
I also like Jstpssng's idea of Google Earth. But to get the most benefit from that you need to be computer savvy. It will however with basic skills get you a printable aerial photo of your property.
When setting my house and shop I visited the County Assessor Office. She printed two aerials for me. One was 1" = 100'. The other was 1" = 200'. Worked great for orientation and association with surrounding area. You'll easily see your neighbor's proximity. No computer knowledge required.
Keep us posted on your progress.
/ Clearing land for my building and yes more math problems #13
I had a bit of time to poke around before dinner...
Jason - your county has an online tool that is easy to use (it's the same one used where I live). There is some information there that might be useful to you in your planning (property boundaries, zoning, etc.) . If you can figure out how to take pictures on your phone/camera and upload them as attachments to a post on TBN you're computer literate enough to use it :)
Geocortex Viewer for HTML5
Here's the latest aerial/satellite photography of your property from 2017 overlaid with the land contours (labels in feet). So you can see a 16 foot elevation difference between the northwest corner and southeast corners of your property. Not much else to see in the aerial view except trees.
It used to be that if a property was shielded from the road by trees or something else that people couldn't really know what you were up to. That has all changed with detailed aerial/satellite photography available to everyone, including the folks setting our property taxes. Forget putting up a building without a permit - the view of our property is so detailed I can see the BBQ on the back deck of our house.
Chris
/ Clearing land for my building and yes more math problems #14
There are other important factors in deciding where to put it .
Is this the main house or is that coming later ?
Is there a view or a breeze you would like to capture ?
Is there a wet spot or a rocky spot you would be better to avoid ?
Is there a sunny spot where solar panels will work better ?
How far do you need to bring power in ? Extra poles are expensive .
Is a long driveway going to be expensive ?
Do the neighbors kids have dirt bikes and barking dogs etc etc .
Tough to reply on my phone on McDonald's internet, I'm going back home tomm. Thanks for the replies and I'll have better response tomm
/ Clearing land for my building and yes more math problems #16
Chris
Good stuff Chris!!!
I have heard several times that Google, and others I'm sure, are applying for governmental approval of "real time" photos. Real te based on the last pass of the satellite. Very contriversial subject.
/ Clearing land for my building and yes more math problems #17
I think you are going about this all wrong. You need to put feet on the ground and start looking around for the ideal spot for your buildings based on access, utilities and view. I've taken out tens of thousands of trees and I don't miss or even remember a single one. When I'm in my planning mode, I carry a measuring wheel with me to figure out how much area that I need to open up, and a roll of orange marking tape to tie to branches so I can see what I'm doing.
You said 4,000 square feet, but didn't give dimensions. If it's 50x80, I would take out at least everything around that area so that no trees hang over the building, and even better if you can take out everything that might fall onto the building if it falls over during a storm, or if it just gets mad at you. Trees can be vicious!!! For me, that's 30 to 50 feet of open area around the building, or 110x140 as a minimum starting point. Remember that when you are clearing the area, to not get sentimental and try to leave or save a tree that you all of a sudden "must have." It's a tree that will attack your building sooner or later, or even worse, die on you two years after you start construction and then cost you big money to have it removed by a pro so it doesn't damage your building.
/ Clearing land for my building and yes more math problems #18
as the above poster stated you need boots on the ground. You need to find the high areas of ur property and start with building there so water can drain away. That is the most important part. Don't make this super complicated. I think you are over thinking this. The only area you will want to over think is the size of ur pole barn. I wish mine was bigger is a general consensus here.
/ Clearing land for my building and yes more math problems #19
ABSOLUTELY EXCELLENT advice!
/ Clearing land for my building and yes more math problems #20
Yep. Approaching that half acre mentioned earlier.
The topo map offered earlier will quickly tell you the high/low areas.
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
2008 Ford Explorer SUV (A60352)
2008 Ford Explorer...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2018 DRAGON 150...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
