Pro Loggers - More advice needed
/ Pro Loggers - More advice needed #41
Good for you. A learning experience well earned.
Best thing I learned is being retired and having no time limit on most things makes them go easier.
/ Pro Loggers - More advice needed #43
Way to go - looks harmless now :thumbsup:
I'm a little dense so I don't get the pallet thing ???
gg
I think the pallet thing is a reference to a classic TBN thread asking about pallets out in a field. Quite ridiculous, but it went on for thousands of posts.
These “how to cut this tree” threads are great for armchair quarterbacking.
So what was OP’s exact method?
/ Pro Loggers - More advice needed #44
LD - being retired, as I am also, does have its advantages. HOWEVER - I'm still quite able to do stupid things - just slowly. :thumbsup: :laughing:
/ Pro Loggers - More advice needed #45
Pro loggers are responsible for the pallets in the first place.
Starting at the top, with battery op chainsaw, trim back to firewood size. (2"-4" dia,)
Pull out & chip all branches trimmed & laying in the way up to firewood size. 2"-4" again depending on how I feel as I pick it up & how straight it is.
Cut non weight bearing branches and remove from area.
Gather & chip all small stuff exposed.
Cut weight bearing trunk as high up as comfortable & with foresight to being able to move them. (With gas chainsaw)
Wrap a chain around split & cut portion of remaining trunk & remove with truck.
Repeat for final half of trunk.
9' tall "stump" will be cut after clean up & removal of remaining Red Oak that is in the way.
Is that what you wanted to know?
/ Pro Loggers - More advice needed #47
What color clothes were you wearing and did you hydrate properly pre and post operations?
Spray King Pull Type Sprayer (A63116)
Spray King Pull...
Agline ADM110 Hay Mower (A64047)
Agline ADM110 Hay...
53ft Dry Van Trailer (A61165)
53ft Dry Van...
2022 KOMATSU PC130-7 EXCAVATOR (A62129)
2022 KOMATSU...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
1997 GMC GMT-400 SINGLE CAB TRUCK (A62130)
1997 GMC GMT-400...
