Tach/Electrical Issue
/ Tach/Electrical Issue #61
I have the same problem you're having, mine started slow at first, the neutral light was the first thing I remembered not lighting up, now I'm in the same boat you're in. Hope you get your machine fixed, Mine is still not working,
/ Tach/Electrical Issue #62
I checked my fuses and I only have .3 volts on the bottom 3 fuses, I think they are the lights, inst. panel and panel lights, Got to do a little more digging to see why no voltage to these fuses.
/ Tach/Electrical Issue #63
So did anyone ever get their tractors fixed?
got mine fixed today, it was the relay under the hood, the blue one on the far right hand side, I would like to thank everyone that has commented on this and without all your help I was about to take it in to the dealer and would has cost me an arm & leg. Thanks again for all the good suggestions. Steve
/ Tach/Electrical Issue #65
I'm having an similar issue with my 2011 ct235. No headlights and the tach/dash worked intermittently and finally quit. Does anyone have wiring diagram? The dealer gave me a parts breakdown that shows all the relays but none of look like they relate to the dash. Thanks.
I'm having a very similar problem on 2013 CT235 Could someone point me in the right direction and which relay I should be looking and replacing? Anyway to determine it is the relay by troubleshooting? I have checked the battery and ground connections and this hasn't helped. Thanks in advance!
/ Tach/Electrical Issue #66
Me too. 2011 (I think) CT235 with 415 hours. A couple times this month I'd go start and no solenoid click. But subsequently key off and on and it would click. Yesterday, I lost power to my rear accessories circuit. Then a few hours later I lost headlights and gauges. Have signal lights, horn, turn signals. Looked for shorts underneath and under the hood... Nothing. Will be checking this far right side (facing the firewall from the front) relay in the engine compartment and hope this will prove the culprit. Will update tomorrow.
/ Tach/Electrical Issue #67
Anyone know where the switched power relay is on the CT235? On the fire wall from right to left when facing from the front, the fuel sender is beside the OCU. Then the fuel pull relay, the starter relay, and the pre-heat relay. No switched relay as is according to the CT335 right beside the fuel sender.
/ Tach/Electrical Issue #68
I assume this is it? Directly above the Flasher Unit on the left side beneath the instrument panel shroud. IMG_20190626_102951.jpeg
/ Tach/Electrical Issue #69
I assume this is it? Directly above the Flasher Unit on the left side beneath the instrument panel shroud. View attachment 610536
Can not make out wire colors in the photo, 4 wires at the Switched power relay are Black (grd), Red (battery), Red/white strip (switch input), Red/Blk stripe (out to dash & lights).
/ Tach/Electrical Issue #70
Thanks for the insight. It ceased being problematic but I'm sure it's not the last I've heard of it.
/ Tach/Electrical Issue #71
Ok, just got home but I'm seeing Black, red/black, what looks like red/Grey (unless that's dust on it but I cannot reach it, and another right rear rust just looks black from this angle and I really can't get to it. That's a nylon nut holding the relay up there and I'm sure I can get an angle wrench up there if need be, but at the moment the issue has repaired itself.
/ Tach/Electrical Issue #72
My CT235 acted similar to this about a year ago. It was an intermittent problem for a long time with same symptoms. After while of troubleshooting I was able to locate the problematic relay under the dash on the right hand side of the tractor near the fuse box. The relay was not under the hood, but was located under the ignition near the fuse box. On the electrical schematic diagram from the repair book the relay is labeled as the "switched power" relay. In other documentation including the repair book and on bobcat parts it is labeled as the "ignition" relay. Go to bobcat parts online to the Electrical System 2 Group which shows the problem relay as item 13, G: Ignition relay. I was unable to post the link.
Ok, just got home but I'm seeing Black, red/black, what looks like red/Grey (unless that's dust on it bu near the t I cannot reach it, and another right rear rust just looks black from this angle and I really can't get to it. That's a nylon nut holding the relay up there and I'm sure I can get an angle wrench up there if need be, but at the moment the issue has repaired itself.
/ Tach/Electrical Issue #73
Will look there as mine has begun acting up again. I am also unable to determine what exactly that 20A relay is on the left side under the dash above the flasher. The workshop manual for the CK35 I have doesn't even show a relay as being there.
/ Tach/Electrical Issue #74
This might help you with some locations.
/ Tach/Electrical Issue #75
That's great, if I could find it. That Ignition Relay, is that hidden up behind the shroud surrounding the gauges and accessible from the engine side or do I have to disassemble the dash to get to it?
/ Tach/Electrical Issue #76
Is it visible without removing anything from the cab above the fuse box? I can't see a relay there.
/ Tach/Electrical Issue #77
If I recall correctly, I don't believe it is visible without taking of the "Cover, Instrument Lower" shown on the bobcat parts site under Instrument Meter Cover Group.
/ Tach/Electrical Issue #79
Will look there as mine has begun acting up again. I am also unable to determine what exactly that 20A relay is on the left side under the dash above the flasher. The workshop manual for the CK35 I have doesn't even show a relay as being there. View attachment 612116
Kioti electric and Bobcat electric are different. That's why the CK35 manual is no help. As far as I know everything else is the same.
/ Tach/Electrical Issue #80
How the heck do you get to it? If I take those two bolts off the lower shroud on the steering wheel side, and the two upper ones on the engine side, will the shroud lift up?
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
UNUSED JCT 96" PUSHER BOX (A65055)
UNUSED JCT 96"...
UNUSED JCT 60" CLASS8-8000 LB CAP PALLET FORKS (A65055)
UNUSED JCT 60"...
2017 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 INTERNATIONAL...
2007 Freightliner B2 School Bus (A64556)
2007 Freightliner...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
