Box Blade alternatives to EA?
/ Box Blade alternatives to EA? #1
biggziff
Upstate NY
2015 Kioti CK4010HST
Just bought a CK4010 HST (came with a loader, backhoe and rotary butter) and a Box Blade is my first needed implement. I called EA and they're 10-12 weeks lead time on anything they sell so I'm looking for suggestions on alternative brands. I'm looking for a fixed tailgate unit, 72". I want something quality so not really looking at the Tractor Supply type brands unless there is one you'd recommend.
Thanks in advance.
/ Box Blade alternatives to EA? #2
I have a land pride box blade. Excellent quality and finish. Im very happy with it. I also have the grapple they make as well, very beefy and works incredibly well. The land pride equipment I have gets works very hard and not a hiccup. Good luck in your research.
/ Box Blade alternatives to EA? #3
Thanks in advance.
Best bang for the buck would likely be a HD King Kutter "pro green", (Blain's Farm & Fleet... 72"= $829) but EA and Land Pride could be slightly better quality.
Tractor Supply, definitely...NO!
/ Box Blade alternatives to EA? #4
Thanks in advance.
I very highly recommend a ROBB as seen here.
The next best thing compared to a box blade with hydraulic actuated rippers. ;)
/ Box Blade alternatives to EA? #5
Woods Equipment makes a solid box blade. My dealer had a couple in stock. Even Kioti orange, not the mustard yellow in the pics on their web page.
That King Kutter looks good. $267 shipping to me, unfortunately.
Anyone have any reviews on Tarter Farm and Ranch brand Box Blades? Local dealer sells them.
/ Box Blade alternatives to EA? #9
Tractor Supply Company sources their CountyLine implements from Tarter.
I would shop for a heavier Box Blade than CountyLine but you know your needs better than me.
/ Box Blade alternatives to EA? #10
Do you own and use a ROBB?
He does. So do I.
Most traditional Box Blades weigh under 75 pounds per foot of width.
Most ROBBs weigh closer to 120 pounds per foot of width.
In ground engagement work weight is your friend.
/ Box Blade alternatives to EA? #11
Gearmore makes good strong box blades, a big step above TSC. They have hydraulic ripper options too.
/ Box Blade alternatives to EA? #12
YOUR LOCATION SHOULD BE PART OF YOUR T-B-N PROFILE. Implement brand availability is highly regional.
YOUR TRACTOR BRAND AND MODEL SHOULD BE PART OF YOUR T-B-N PROFILE.
Yes, by all means, keep yelling at members until they comply.
/ Box Blade alternatives to EA? #15
Tarter box blades are at the very low end of the spectrum.
If cheap is your desire, they are where you want to be.
I want to buy one and not have to worry about replacing it.
/ Box Blade alternatives to EA? #17
Also there there are two basic types, Standard and High Back:
If you have a big tractor you might like the High Back.
/ Box Blade alternatives to EA? #19
I have owned a Woods 72" box blade for about 17 years and have been very happy with it. I forget my model number, but it was not their heaviest model. If I recall, it weighs about 100#/ft. My 33 HP tractor falls in the middle of the box blade's rated range. I've also used it behind my neighbor's 50 HP tractor with no problems.
It's much more solidly built than the Tractor Supply brand.
/ Box Blade alternatives to EA? #20
Regardless of what you buy, look close to ensure you can hook it with a quick hitch. Many implements still have a plate or bolt in the way. I have a new heavy duty John Deere (Frontier) Blade and love it. On or off the tractor in less than 15 seconds from my seat. Priceless.
John Deere 4044R (A62177)
John Deere 4044R...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2007 DRAGON 130BBL STEEL (A63569)
2007 DRAGON 130BBL...
Case IH 950 Planter (A63118)
Case IH 950...
2018 FREIGHTLINER CASCADIA SLEEPER TANDEM AXLE  6X4 TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
Bush Hog BH317 Rotary Cutter (A64047)
Bush Hog BH317...
