rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,946
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I understand some industrials have inching clutches (mine does but, it hasn't worked from my first day of ownership)
Do any tractors have inching clutches?
I don't know of any tractors that do, but some true TLBs have an inching function that you use to move the tractor forwards or reverse very lowly when you are sitting with the chair reversed in the backhoe position. It's handy & keeps you from needing to turn the chair back around to move a foot or two.
Our JD310SG TLB doesn't have it, not even sure if it is an option on the SG. The Kubota M59 does have the inching function and it works fine. Funny thing is that it isn't even mentioned in their sales brochure at the time. I had to look at the operator's manual to see what that lever did. I didn't know it had that function when we bought it.
For those saying, "What's an inching function?" It's just a lever you can reach easily without having to turn the chair back around from the backhoe position. Mechanically it isn't anything extra in the drivetrain. It tends to be a series of cables that advance the throttle just a little bit while simultaneously engaging the transmission... Notorious for getting out of adjustment and tricky to adjust. I bet your JCB is just out of adjustment because if the tractor works, the inching function almost has have the potential to work too.
rScotty
