FEL Build Questions.
/ FEL Build Questions. #41
Is it better to mount the hydraulic from the front of that or the bottom?
Don't understand your question.
Do you mean the hydraulic control valve?
Yea I realize now that was kinda vague.
I'm taking about the curl cylinder. I was going to use a single one mounted in the center of the cross bar support. So the question is on that curl cylinder would it be better to mount the cylinder from the front face of the support so it basically runs at 90deg on that support and sits on it or on the bottom so that it is straight out from it.
/ FEL Build Questions. #43
That will affect the curl and dump angles. So you just have to play with the geometry of that to achieve whatever angle you want. It's a somewhat of a time consuming job. Took a while on mine to figure out.
/ FEL Build Questions. #44
This is how Kubota did it:
From an image search
/ FEL Build Questions. #45
Any hydraulic cylinder has more power pushing out than drawing in.
That is due to the shaft restricting volume.
In some cases manufacturers prefer to oversize to compensate while I think others pass on the damage risks onto the user.
(An extended shaft is more liable to damage than a cylinder body.)
/ FEL Build Questions. #47
Looks good, but you have one major flaw... that ~3" strap metal you have going from just under the frame mount for the cylinder is going to be under compression while lifting, strap metal does NOT hold under compression, it needs to be angle at the least but ideally square or round...
/ FEL Build Questions. #48
I agree with this. Could use some narrow tubing like 1x2in which would be stronger then the flat bar that you have
I could weld an angle iron on the side maybe. The ends are bent to make it work already. Plus no room to add thicker material. But an angle iron piece between the upright and bottom put on to make a triangle should work.
Well it is functionally done. Need to add the angle on the straps and then paint. It moves really well and can lift the front end off the ground a few inches. 20190702_174113.jpg
/ FEL Build Questions. #52
OOPS,, :eek: The cable ties,,,
the white ones degrade quickly ( I mean REALLY quick!! ) in sunlight,,
plan on swapping the cable ties to black ties soon,,, :thumbsup:
Otherwise,, your work looks great!! :cool2:
Thanks I'll get black on after the paint job.
/ FEL Build Questions. #54
:thumbsup: Look's straight from the factory.
Thank you sir.
Appreciate all the help. Now I can put the welder away, for a few days at least.
/ FEL Build Questions. #56
Have you used the loader to do any real work yet?...if not, the first time you do you need to huff on your fingernails and buff them on your lapel...:thumbsup:
Great job...!
Lol not "real" work. Done some test lifting and digging in the yard. Its going out to the hunting camp next to get some real work done. We have to fix the road and do 2 culverts.
iDrive TDS-2010H...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
