Tractor backhoe - homemade
/ Tractor backhoe - homemade
2nd boom assembly
/ Tractor backhoe - homemade #1,143
Did you end up using the Hardox or is it regular mild steel?
Wear parts are gonna be Hardox, the rest is S355MC. It will be fine, no worries
/ Tractor backhoe - homemade #1,145
is it fairly easy to push that sheet of steel around the curve, or did you have to put a pipe wrench on the handle of your clamps ?
And what was the wall thickness of top and bottom plates, 8 or 10mm ?
It's a small curve but it was quite hard to bend. I have to make a hydraulic shop press...it would come in handy many times. Its 8mm plate, 180 mm width, approx 2 m lenght. Why do you ask? Rk 525 had 10 mm but I think it was too much...
/ Tractor backhoe - homemade #1,147
I ask because at work, we never work with steel thinner than 15mm in booms. That is, for machines from 30 to 250 ton operating weight 😅
But i am thinking of building my own backhoe as well, the Bobcat attachment i modified for tractor use, is too limited for any foundation digging.
Well, now I'm sure this is too thick...;). What size of bh do you plan to build?
/ Tractor backhoe - homemade #1,149
8mm is more than 1/4 thick. I don’t think the boom on my 310 is any heavier. Making a boom ridiculous overkill has no benefits and plenty of negatives. Upwards of 15mm on the boom would result in something his tractor couldn’t even move.
/ Tractor backhoe - homemade #1,150
8mm is ~5/16" that's pretty thick.
Aaron Z
If you compare this one with rk 525, it had 10 mm top and bottom plates, 8 mm side plates and larger profile height. I managed to reduce the weight of the machine by 400 kg by now. When it's finished I plan to take it to drive on scale to measure the weight of complete machine
/ Tractor backhoe - homemade #1,152
8mm is pretty thick, as noted by others. You should use some heat with an O/A torch while bending. It does not need to get very hot. I once built a 13" wide bucket for my home-built CADDigger, and it called for 1/4" plate, bent around some side plates. I was surprised that I was able to bend it at all with 2 cheapo come-alongs and a torch.
Now I know better. 3/16" plate would have been fine, with wear plates where needed. With all those fine gussets you made, BF, you can go thinner on the carcass. Sometimes even 1/8" is enough, esp with exotic steels, wear plates, and gussets.
Looks great.
/ Tractor backhoe - homemade #1,153
8mm is more than 1/4 thick. I don稚 think the boom on my 310 is any heavier. Making a boom ridiculous overkill has no benefits and plenty of negatives. Upwards of 15mm on the boom would result in something his tractor couldn稚 even move.
I didnt propose 15mm for his backhoe, i was just wondering how easy it is to bend 8mm into the shape of the boom, because at work, we work with substantially heavier material which is bent with a press. For what im thinking of building, i'm unsure if i want 6 or 8mm, i could build it lighter with 6mm and a higher cross section, but have more risk of getting local cracks where cylinder brackets are welded to the top and bottom plates of the boom.
With 6mm i wouldnt need brake pressing a dozen steps to create a radius like we do at work, but what i understand from Bfreaky, 8mm is too strong to clamp into a curve..
/ Tractor backhoe - homemade #1,154
...just to clarify once more: at work we build booms for 30 to 250 ton exvavators, but i am thinking of building a backhoe for myself, which would compare to a 3 ton excavator. Which is a machine size of which Bfreaky has more experience with, than me 😉👍
/ Tractor backhoe - homemade #1,155
What page or year is the finished BH on?
/ Tractor backhoe - homemade #1,156
Page 20/21 I believe.
That was the first one that BFreaky built. He is now on a second one that will be improved.
Renze, it's not too hard to bend, you just have to use 2 really large clamps with trapezoid thread and press the plate every 20 cm step by step and it works. If that fails you can always use small hydraulic jack with O frame. That was my plan B in case clamps couldn't do it.
Thick parts for kingpost and boom no.3.
/ Tractor backhoe - homemade #1,159
CAD, wow! Sure wish I could grasp this dam* computer "thing":laughing:
As usual, amazing BF:thumbsup:
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2018 John Deere 8345R MFWD Tractor (A63109)
2018 John Deere...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
2022 Timpte 1424 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1424...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
