Tractor backhoe - homemade
/ Tractor backhoe - homemade
2nd boom assembly
/ Tractor backhoe - homemade #1,143
Did you end up using the Hardox or is it regular mild steel?
Wear parts are gonna be Hardox, the rest is S355MC. It will be fine, no worries
/ Tractor backhoe - homemade #1,145
is it fairly easy to push that sheet of steel around the curve, or did you have to put a pipe wrench on the handle of your clamps ?
And what was the wall thickness of top and bottom plates, 8 or 10mm ?
It's a small curve but it was quite hard to bend. I have to make a hydraulic shop press...it would come in handy many times. Its 8mm plate, 180 mm width, approx 2 m lenght. Why do you ask? Rk 525 had 10 mm but I think it was too much...
/ Tractor backhoe - homemade #1,147
I ask because at work, we never work with steel thinner than 15mm in booms. That is, for machines from 30 to 250 ton operating weight 😅
But i am thinking of building my own backhoe as well, the Bobcat attachment i modified for tractor use, is too limited for any foundation digging.
Well, now I'm sure this is too thick...;). What size of bh do you plan to build?
/ Tractor backhoe - homemade #1,149
8mm is more than 1/4 thick. I don’t think the boom on my 310 is any heavier. Making a boom ridiculous overkill has no benefits and plenty of negatives. Upwards of 15mm on the boom would result in something his tractor couldn’t even move.
/ Tractor backhoe - homemade #1,150
8mm is ~5/16" that's pretty thick.
Aaron Z
If you compare this one with rk 525, it had 10 mm top and bottom plates, 8 mm side plates and larger profile height. I managed to reduce the weight of the machine by 400 kg by now. When it's finished I plan to take it to drive on scale to measure the weight of complete machine
/ Tractor backhoe - homemade #1,152
8mm is pretty thick, as noted by others. You should use some heat with an O/A torch while bending. It does not need to get very hot. I once built a 13" wide bucket for my home-built CADDigger, and it called for 1/4" plate, bent around some side plates. I was surprised that I was able to bend it at all with 2 cheapo come-alongs and a torch.
Now I know better. 3/16" plate would have been fine, with wear plates where needed. With all those fine gussets you made, BF, you can go thinner on the carcass. Sometimes even 1/8" is enough, esp with exotic steels, wear plates, and gussets.
Looks great.
/ Tractor backhoe - homemade #1,153
8mm is more than 1/4 thick. I don稚 think the boom on my 310 is any heavier. Making a boom ridiculous overkill has no benefits and plenty of negatives. Upwards of 15mm on the boom would result in something his tractor couldn稚 even move.
I didnt propose 15mm for his backhoe, i was just wondering how easy it is to bend 8mm into the shape of the boom, because at work, we work with substantially heavier material which is bent with a press. For what im thinking of building, i'm unsure if i want 6 or 8mm, i could build it lighter with 6mm and a higher cross section, but have more risk of getting local cracks where cylinder brackets are welded to the top and bottom plates of the boom.
With 6mm i wouldnt need brake pressing a dozen steps to create a radius like we do at work, but what i understand from Bfreaky, 8mm is too strong to clamp into a curve..
/ Tractor backhoe - homemade #1,154
...just to clarify once more: at work we build booms for 30 to 250 ton exvavators, but i am thinking of building a backhoe for myself, which would compare to a 3 ton excavator. Which is a machine size of which Bfreaky has more experience with, than me 😉👍
/ Tractor backhoe - homemade #1,155
What page or year is the finished BH on?
/ Tractor backhoe - homemade #1,156
Page 20/21 I believe.
That was the first one that BFreaky built. He is now on a second one that will be improved.
Renze, it's not too hard to bend, you just have to use 2 really large clamps with trapezoid thread and press the plate every 20 cm step by step and it works. If that fails you can always use small hydraulic jack with O frame. That was my plan B in case clamps couldn't do it.
Thick parts for kingpost and boom no.3.
/ Tractor backhoe - homemade #1,159
CAD, wow! Sure wish I could grasp this dam* computer "thing":laughing:
As usual, amazing BF:thumbsup:
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
30 GALLON AIR TANK W/HOSE (A62131)
30 GALLON AIR TANK...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
