Good morning!!!!
   / Good morning!!!! #94,732
Congratulations David. You'll be very pleased with your LS.
My 2017 XR4155HC came with 3 remotes standard. I've got FIT-Rite hydraulic upper and side link cylinders and I wanted the 3rd remote for my LP 96" rear grader blade "angle" cylinder. I generally get as much "tilt" from my hydraulic side link, as I need.
Pics ...... when you take delivery.
I got my TnT from Brian years ago for my Kioti. Hoping it is a good fit for the LS. I want the 3rd for my flail with hydraulic shift/offset.
   / Good morning!!!! #94,733
Send Brian an email David. He'll be able to let you know if your old cylinders will be appropriate for your LS.
I'm sure you already know to move your adjustable manual side link over to the left side, to get you even more tilt adjustment.
   / Good morning!!!! #94,734
Good idea.
I’ll have to look and see what I have for reference. Likely will still use even if not optimal, as long as functional.
I was a bit surprised to see Tilt on the right as I’ve always had on left.
   / Good morning!!!! #94,735
Now that tractor is just waaaay to clean. :)
   / Good morning!!!! #94,737
48° F and going to a high of 59. Wind WSW 11 gusting to 17 mph. 40% chance of rain.
Around here 40% is the new 100%.
I have only one job for today, put a new screw in one of my emergency triangles.
That will be my personal job list caught up.
Tuesday is the day I go south and back to work. After Monday my presence on here will be limited to the weekends and rain days.
Have a good day all
   / Good morning!!!! #94,738
62 going to 86 and probably storms this afternoon.
Ron, great new dog. My parents had one like that and loved it.
David, exciting to hear about your new tractor. You certainly will get good use of it with all of your projects.
Kyle, how does your water level work?
I won free tickets to a very nice festival yesterday, about an hour away. Rassawek has everything from wine, bourbon and moonshine tastings to steamboat and helicopter rides...lots of classic cars, artists, old timey equipment and sawmill, bateaux, 3 bluegrass stages and bar-b-q and ribs. One of our friends was an exhibitor so we surprised her when we showed up.
Welcome - Rassawek Vineyard
   / Good morning!!!! #94,739
61 high of 84 storms later then much cooler Monday almost fall like
Nice tractor choice Sodamo
Festivals always fun and free to boot
New tires came in for wifes car LTX m&s had great luck with these in years past
Prayers for Toppop and all others
   / Good morning!!!! #94,740
Roy, hope the new switch fixes the zt. Dealer told me to engage pto at low rpm to prolong the pto clutch life.
The dealer was out of stock for the switch, so I ordered a couple. I planned on pulling the old one out and seeing if I could do something with it...but no need. The PTO engaged as advertised! I'll still get the two spares though.
So, finished mowing and did the trimming.
I engage at about half throttle (on the ZTR)...never at full RPM. I've had enough PTO's (tractors) to know how to minimize any shock. I don't have a rotary cutter any more (use a flail mower instead), but when I did...the 4520 has plenty of torque at low RPM to keep running while spinning up a cutter's blades.
3pt 28' Hydraulic Fold Scratcher (A57148)
3pt 28' Hydraulic...
Toyota LPG 7FGCU20 3,400 lb. Capacity Forklift, S/N 86163, Dual Mast, Tilt, 80" Reach, 19,871 Hours (A59076)
Toyota LPG 7FGCU20...
Air Jack Hammer with hose and Bit (A59213)
Air Jack Hammer...
UNUSED FUTURE HYD MINI AUGER (A58376)
UNUSED FUTURE HYD...
Kubota L4701 (A53317)
JOHN DEERE 348 SQUARE BALER (A58216)
JOHN DEERE 348...
