Best way to remove 3’ of bed rock to burry septic tank?
/ Best way to remove 3’ of bed rock to burry septic tank? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
So I need to install a septic tank and the bedrock isn’t much over 2’ deep maybe 3’ tops. I could add some dirt to the top but not enough. Is something like that in the range of Dexpan or a handheld jackhammer? Should I look into renting a mini excavator with a rock breaker? Any other ideas? This system has to be inspected so burying anything besides a proper tank isn’t an option.
The bed rock is 2-3 feet below the surface but I need a hole 6’ deep. The top foot of the rock is pretty soft so if I’m lucky I’ll be able to dig 4 foot deep but I haven’t started that project yet. As to the thickness I have no idea. That doesn’t really matter.
/ Best way to remove 3’ of bed rock to burry septic tank? #4
I had the rock here blasted. $2400/day.
If that isn’t an option they make skid steer and excavator mounted hammers. Because of the underground nature of the rock I’d go for the excavator. Renting one for a day vs hiring it done will be close in cost- get quotes for both.
How’s the leach field?
It’s only like 30 feet from other houses so I don’t think blasting is an option. I think the leech will be fine.
/ Best way to remove 3’ of bed rock to burry septic tank? #6
Have you talked to the plumbing/septic inspector to see how they handled other similar situations?
Sand stone.
/ Best way to remove 3’ of bed rock to burry septic tank? #9
It sounds like a civil, wastewater, or septic engineer should be involved.
They’ve already given the specs I have to meet for the leech field. They don’t care how it gets buried.
/ Best way to remove 3’ of bed rock to burry septic tank? #11
where is this going to percolate or drain to?
/ Best way to remove 3’ of bed rock to burry septic tank? #12
Sounds like a jack-hammer job to me, just make believe your riding a Harley...............
/ Best way to remove 3’ of bed rock to burry septic tank? #13
Re: Best way to remove 3 of bed rock to burry septic tank?
I would get a quote and possibly hire it done. You would want to clear the rock deeper than just the minimum to lay a bed of sand in order to set the tank level. Rather than setting the tank on jagged rock creating voids and high pressure points on the tank bottom.
A small excavator with a hydraulic hammer would make short work of it.
I’m still recovering from a broke ankle. I can operate my backhoe but the man behind the jackhammer won’t be me. One of my buddies has a jackhammer. I might try to get him to try it before renting a mini excavator.
/ Best way to remove 3’ of bed rock to burry septic tank? #15
Get it blasted. They can do small charges and not disturb the house. You still have to dig it out with an excavator.
I’ve got a full size backhoe to do the digging but I don’t have a rock hammer or the hydraulics to run one so I’d have to rent the whole machine. I’ll check into the blasting option but I don’t have high hopes in finding someone to do it.
/ Best way to remove 3’ of bed rock to burry septic tank? #17
.................................... I’ll check into the blasting option but I don’t have high hopes in finding someone to do it.
Only 30' from other houses, blasting bedrock? I don't think you are going to like the cost even if you can find a licensed contractor to do the blasting.
Hope you have good neighbors. Even small charges will be felt from the vibration of the blast. Then someone could be looking for a freebee to repair their long ago cracked drywall, ceiling plaster or whatever.
I don’t either. I figure somewhere on the $500 range to rent a mini with a rock hammer. I hope the mini is up for the job. I watched a 320 cat hammer all day to put in a culvert at gas station they’re building.
/ Best way to remove 3’ of bed rock to burry septic tank? #20
Sandstone does break well in layers,
2016 FORD EXPLORER SUV (A64280)
2016 FORD EXPLORER...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
KMC Peanut Inverter Blades (A64119)
KMC Peanut...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
