Best way to remove 3’ of bed rock to burry septic tank?
/ Best way to remove 3’ of bed rock to burry septic tank? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
So I need to install a septic tank and the bedrock isn’t much over 2’ deep maybe 3’ tops. I could add some dirt to the top but not enough. Is something like that in the range of Dexpan or a handheld jackhammer? Should I look into renting a mini excavator with a rock breaker? Any other ideas? This system has to be inspected so burying anything besides a proper tank isn’t an option.
The bed rock is 2-3 feet below the surface but I need a hole 6’ deep. The top foot of the rock is pretty soft so if I’m lucky I’ll be able to dig 4 foot deep but I haven’t started that project yet. As to the thickness I have no idea. That doesn’t really matter.
/ Best way to remove 3’ of bed rock to burry septic tank? #4
I had the rock here blasted. $2400/day.
If that isn’t an option they make skid steer and excavator mounted hammers. Because of the underground nature of the rock I’d go for the excavator. Renting one for a day vs hiring it done will be close in cost- get quotes for both.
How’s the leach field?
It’s only like 30 feet from other houses so I don’t think blasting is an option. I think the leech will be fine.
/ Best way to remove 3’ of bed rock to burry septic tank? #6
Have you talked to the plumbing/septic inspector to see how they handled other similar situations?
Sand stone.
/ Best way to remove 3’ of bed rock to burry septic tank? #9
It sounds like a civil, wastewater, or septic engineer should be involved.
They’ve already given the specs I have to meet for the leech field. They don’t care how it gets buried.
/ Best way to remove 3’ of bed rock to burry septic tank? #11
where is this going to percolate or drain to?
/ Best way to remove 3’ of bed rock to burry septic tank? #12
Sounds like a jack-hammer job to me, just make believe your riding a Harley...............
/ Best way to remove 3’ of bed rock to burry septic tank? #13
Re: Best way to remove 3 of bed rock to burry septic tank?
I would get a quote and possibly hire it done. You would want to clear the rock deeper than just the minimum to lay a bed of sand in order to set the tank level. Rather than setting the tank on jagged rock creating voids and high pressure points on the tank bottom.
A small excavator with a hydraulic hammer would make short work of it.
I’m still recovering from a broke ankle. I can operate my backhoe but the man behind the jackhammer won’t be me. One of my buddies has a jackhammer. I might try to get him to try it before renting a mini excavator.
/ Best way to remove 3’ of bed rock to burry septic tank? #15
Get it blasted. They can do small charges and not disturb the house. You still have to dig it out with an excavator.
I’ve got a full size backhoe to do the digging but I don’t have a rock hammer or the hydraulics to run one so I’d have to rent the whole machine. I’ll check into the blasting option but I don’t have high hopes in finding someone to do it.
/ Best way to remove 3’ of bed rock to burry septic tank? #17
.................................... I’ll check into the blasting option but I don’t have high hopes in finding someone to do it.
Only 30' from other houses, blasting bedrock? I don't think you are going to like the cost even if you can find a licensed contractor to do the blasting.
Hope you have good neighbors. Even small charges will be felt from the vibration of the blast. Then someone could be looking for a freebee to repair their long ago cracked drywall, ceiling plaster or whatever.
I don’t either. I figure somewhere on the $500 range to rent a mini with a rock hammer. I hope the mini is up for the job. I watched a 320 cat hammer all day to put in a culvert at gas station they’re building.
/ Best way to remove 3’ of bed rock to burry septic tank? #20
Sandstone does break well in layers,
Pair of Assist Wheels (A64119)
Pair of Assist...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
(8) 10" X 52" CHANNEL IRON (A64280)
(8) 10" X 52"...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
