Stuck in the mud
/ Stuck in the mud #1
thoner7
to-20 Ferguson and Kubota m5400 with Quickie loader
I have a new to me Massey Ferguson 150, which is a mid 1960s, 45 horse diesel machine. 2 wheel drive.
I'm afraid to admit that its just too heavy for my wet ground. With a front loader and loaded tires it's just much too heavy. I get stuck almost every time I drive it.
My old to-20 never got stuck. It's much lighter but it also seems to plant it's power to the ground much better.
So I'm looking for solutions and tips....
The biggest issue is the front tires sinking in.
I 've found some 8 and 10 in wide wheels with the proper bolt pattern for the fronts, in both 15 and 16 inch diameter s. But I'm struggling to find a tire that would be roughly 12" wide and the same diameter as the stock fronts (about 24"-26" going by memory) A small truck tire or R4 type tire perhaps? Even something from a small compact tractor or lawn tractor. Filling it with foam might help with the load rating, right? The tire size labeling is what gets me.
On the rears, wider tires wouldn't be too much trouble I don't think, but again could mess my diameters up. It's easy to swap rims on the wheels.
There's so much weight in the front, because of the loader I assume, I find myself spinning my rears tires in situations my to-20 would not have. So while I could lose a ton of weight by filling the rear tires with air, I don't know if that would help much at all..... but it would lighten the machine.
It's not a quick attach loader (obviously, it's old) so I'm not sure it's feasible to take off and on each time I need it .... with some quick attach hydraulic hose I might be able to Jerry rig something though.
Any help is much appreciated. Thanks!
/ Stuck in the mud #2
Just a thought... but what kind of ballast are you running? Hanging maybe 1,000 lbs or so off of the rear 3 point will further plant the rears, but will also lift weight off of the front wheels and may help you with the pizza cutters in front by providing some lift so that they do not cut in as easily or as deeply.
That rear hung ballast essentially is trying to rotate the frame around the rear axle... or tries to "wheelie" the tractor... add enough weight out back and you theoretically would stand the machine on the rear axle.
/ Stuck in the mud #3
Have you looked at 11L-15 tires or other tires that are used on most hay balers or for floatation. Also, since it is 2wd you could put pretty much any tire that would fit on the front even if it is one size bigger or smaller without throwing the center of gravity of too much. If you go with 16” rims it would shift the center of gravity more toward the rear of the tractor to give more traction but the 3 point hitch would lose an inch or lift. If you find the right bolt pattern and offset on the rim, you can also use wide 15” truck tires. I have used them on hay trailers and that has help keep them from sinking into the mud a lot.
/ Stuck in the mud #4
I think Rock Crawler is right. It's not that you're too heavy, it's that you're too light...on the rear tires.
Adding rear ballast will lighten the front and give you traction at the wheels that need it.
/ Stuck in the mud
Thanks for the input. The rear ballast is antifreeze in the tire tubes. The ballest box is a good idea, but it wouldn't help me when bush hogging, which is when I need it. Plus, I really need to shed weight. I sink into the mud more than just spin tires.
/ Stuck in the mud #6
Flat out wrong tractor than. Just flip it and get something useable. You can spend time and energy trying to polish a turd, but at the end of it.... At best... You'll have a shiny turd that is still a P.O.S.
/ Stuck in the mud #7
Not trying to be wise @ss... can you wait until the ground dry's or is it a must to travel on?,back drag the soggy areas it will dry faster.
/ Stuck in the mud #8
Why are you concerned with tire diameter on a 2WD tractor?
I had one that I put larger diameter rear tires on:
/ Stuck in the mud #10
Liquid in rear tires plant rear tires better (traction), but it is not ballast, ballast hangs off rear of tractor and use weigh to cantilever weight off front making front end lighter.... Its the old playground teeter totter syndrome...
Dale
/ Stuck in the mud #11
This is one of those cases where the OP's location might be useful. I don't know if he lives in a tropical swamp, or maybe in the NW where it rains for 8 months, then is dry for 4, etc.
Bruce
/ Stuck in the mud #12
Bruce
Maybe. But if it ain’t fit to drive on, it ain’t.
/ Stuck in the mud #13
But is it wet short term or long term? Is it hard when dry, or only when frozen? Rainy season? Flood? Swamp? Muskeg?
Bruce
/ Stuck in the mud #14
Do your front tyres need to be the same diameter as the existing tyres?
A larger diameter will roll more easily in soft ground and stay on top better. As long as there are no clearance issues I would go for the extra diameter, and they are probably more readily avalible.
/ Stuck in the mud #15
Dale
Loaded rear tires ARE ballast, only they do not take the load off the front axle. The front axle is the pivot of the teeter totter. 3pt ballast helps move the pivot to the rear axle.
Give me a choice of using a loader on a non ballasted tractor or one with loaded rear tires and I'll choose loaded rear tires. I know weight on the 3 pt is better yet. But loaded tires are ballast, just not the best.
/ Stuck in the mud #16
Have you looked at 11L-15 tires or other tires that are used on most hay balers or for floatation. Also, since it is 2wd you could put pretty much any tire that would fit on the front even if it is one size bigger or smaller without throwing the center of gravity of too much. If you go with 16 rims it would shift the center of gravity more toward the rear of the tractor to give more traction but the 3 point hitch would lose an inch or lift. If you find the right bolt pattern and offset on the rim, you can also use wide 15 truck tires. I have used them on hay trailers and that has help keep them from sinking into the mud a lot.
If getting 11L-15 tires, do not get implement tires, get those made for tractors and get 8ply. IIRC there are also 12L -16 tractor front tires.
/ Stuck in the mud #17
How hard would it be to drop your loader?
/ Stuck in the mud
Lots of replies to answer....
I'm in Western NY. I live on a hill with heavy clay. In the high spots it's already quite hard. The low spots I've avoided completely. With this new machine it may only dry out enough in dry years to actually drive there.
I say it's rock hard but I still get stuck lol. There are little spring on the hill and I guess I'm finding new wet spots I never knew existed before. I guess I'm just surprised that the wider tires of my new machine dont handle its weight better.
I didn't want to get totally different diameter fronts bc I didn't want to risk throwing off any steering angles.
Removing the loader...I might be able to do that if I made some alterations to it. Hard so say. It would never be much of a quick change.
If wider tires help that's maybe my most realistic option. Or just ditching the tractor completely.
/ Stuck in the mud #19
Here is a wild idea...attach a couple of caster wheels to your loader bucket edges and float the fel to put the loader weight on the caster wheels and take the loader weight off of the front axle???
/ Stuck in the mud #20
I vote for wider front tires :thumbsup:.
2021 John Deere 835M Gator (A63116)
2021 John Deere...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A64279)
2000 CATERPILLAR...
2010 Unverferth 1225 Rolling Harrow (A63116)
2010 Unverferth...
HYDRO TEK PRESSURE WASHER (A63569)
HYDRO TEK PRESSURE...
