Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #5,921
How often do you guys sharpen your flail knives? Does sharpening make that much of a difference?
Never.
I've beaten up my old Ford 917 with Ys over rocks, dirt & brush. Some of the knives are noticably rounded & worn on the ends. I have yet to sharpen them & it still cuts fine. Sharpening may give a better cut quality on turf, but I mow fields, not lawns. I put new knives on it when I got it & only replaced a few when mangled by rocks or the well head incident.
I havent touched up the hammers on my newish Peruzzo either. Its hit some rocks as well, but I'm more careful with a $7k flail as opposed to the 917 I paid $100 for. I know the hammers have a rounded edge now & arent sharp, but it handles brush & grass as well as ever.
/ Let's talk flail mowers #5,922
Never.
That's kind of what I thought. I have never sharpened mine either, on my Vrismo or Titan. Both have always cut fairly well. Just wondering if it was worth the effort. I am cutting fields as well, twice a year. Who the heck mows their lawn with a flail mower?
/ Let's talk flail mowers #5,923
I mow my lawn with a 9' flail mower on the back of my 70 hp tractor. Takes me 5 minutes. Then I do the trim with a self propelled push mower and gas trimmer. I don't live on a golf course, as long as it's green, it's good. Wife is happy with it. I also cut my fields with it. So I have a lower standard then most for my lawn, and a higher standard than most for my fields.
I also don't sharpen my y blades. They don't fly up to level either :laughing:
Lnk
/ Let's talk flail mowers #5,924
That would be me.
Our lawn is a former pasture from earlier sugar cane field. It gets cut either with my flail or wife’s 54” Craftsman mower. Sometimes we even mow together.been cutting it about 14 years so looking decent, especially from down the road.
I don’t sharpen either.
/ Let's talk flail mowers #5,925
My experience is that a flail mower cuts better than a brush hog but neither are as good as a finish mower, whether run on the back of a tractor or something like a zero turn or riding lawn mower. But hey, if it works and is quick...more power to you guys.
/ Let's talk flail mowers #5,926
Leonz Thank you for the reply. I noticed you did not mention woodmax or bestco in your response. They fit the budget, do Mascio Peruzzo or Delmorino come in around 3K-ish?
I bought the Kubota because the prices I was quote for a forestry machine to go in were close to two years worth of payments on the L3560!
If you go to Google and search for "tractorbynet betsco flail" there are some useful posts on this website. There are also a fair number of references on other websites.
/ Let's talk flail mowers #5,927
I do. And what took me 4.5 hr every weekend before, takes me now 2.5 hr every other Saturday. But I do not have those Godzillas you tow behind, with PTO. I have modest 59'' powered tow behind one.
There's difference between cutting and ripping grass. Sharp is sharp. Even mower sounds less strained.
/ Let's talk flail mowers #5,928
I sold my ZTR. I believe, outside of bumpy area, where noting cuts even, flail cuts better. Literally like a table flat surface. Drops down clippings, that's true, but I do not care. I'm in farmland, it all looks good.
/ Let's talk flail mowers #5,929
So now I have some questions:
With these sales people being "just plain wrong"
1. Could you provide a photo or video of your sharpening set-up?
I have a 30+ year old WEN wet well drum grinder; I do not have a smart phone to take pictures
2. How many flail owners use your method for sharpening cutters.
3. What make and model flail mower do you use?
I use my fathers second Mathews company Lawn Genie( I also owned his first 36 inch cut lawn genie after he traded it in on the 48 inch unit which I now own.
4. What cutter and how many does your flail have?
My Lawn Genie has the heavy duty tapered side slicers with the oval mounting holes. Sadly they do not sell them anymore as they are the perfect side slicer knife.
The spring tensioned mounting system has a wide loop that allows the side slicer knive pairs to become airfoils and clip the lawn and brush evenly like a rotary finish mower.
My flail mower rotor has a tool less mounting system and I have 64 mounting stations that also accept a thatching blade. I have to buy 64 thatching blades to replace the old ones as they look like butter knives on both edges now since I replaced them in 1992.
5. How many acres do you maintain with your flail?
We mowed up to seven acres with the 36 and 48 inch lawn genies and picked up leaves every fall and anytime we mowed when the grass got away from us when it rained.
I replaced the old wheels and bearing sets with new ones from palmetto tire and wheel.
I realize these are a lot of questions, but I am searching for answers[/QU
We only want to help you not get in your way so feel free to ask questions.
/ Let's talk flail mowers #5,930
I am not real picky about the lawn, as long as it is green and reasonably even after it is cut I am happy. I want to use the flail to cut the biggest part which is about 6 acres if I can just get it to stop leaving the uncut tire strip, not looking for a golf course cut.
/ Let's talk flail mowers #5,931
Try mowing more often,,
if the grass is the correct height when you start,, it will look great after cutting,,
I mowed 4 acres yesterday,, not a tire track,,,
/ Let's talk flail mowers #5,933
If you mow in a spiral pattern that will also let you overlap and eliminate any flattened grass and the grass will recover quickly.
/ Let's talk flail mowers #5,934
Hard to believe you guys use your flails to do your yards, I've a little 48" JD rider for that. If I were to get out my flail, and my L3540 tractor that runs it, to do my yard, I'd have tire tracks and torn up spots all over the place!
/ Let's talk flail mowers #5,935
My flail is almost always connected to the deutz. Open gate,start tractor, do some laps, done.
/ Let's talk flail mowers #5,936
Depends on the yard Ours is about 6 acres. I don’t use the flail in the dogs yard, about 28x20.
/ Let's talk flail mowers #5,937
The setup: Four acre yard to mow on a 100F summer day. Choices: 72" Hustler Super Z open station zero turn mower or 84" flail on Case 55C with A/C cab. You do the math. :) Vic
/ Let's talk flail mowers #5,938
The A/C cab is nice, but a 72" Hustler would likely get the job done quicker, and better.
/ Let's talk flail mowers #5,939
1. I am not using tractor. Side by side.
2. I have **** for grading and 1.25 acre of wetland. I pulled mowers out of mud pits several times too many. And, had to wait till mid June to actually be able to mow where puddles were, while grass is waist high by then. With side by side and 59 inch tow behind, I am done twice as fast and finally mowed over puddles and mud pits.
Not every mower is a tractor tow behind Godzilla, tearing lawn apart. I have zero tracks after mow.
/ Let's talk flail mowers #5,940
Ok ok, I guess that all makes sense.. my "yard" is maybe a little over an acre without a lot of real open space , lots of stuff to go around. I got a couple fields I do with the flail and I guess I don't really care if they get tore up a bit.
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A61165)
2007 Chevrolet...
UNUSED 250 GALLON FUEL TANK (A62130)
UNUSED 250 GALLON...
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
300 GALLON FUEL TANK (A62130)
300 GALLON FUEL...
UNUSED INDUSTRIAS AMERICA F12T HYD TILT LAND LEVEL (A62130)
UNUSED INDUSTRIAS...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
