New to mowing hills... what are safest mowing patterns?
   / New to mowing hills... what are safest mowing patterns? #11
We see tractors that rolled but to my knowledge we never get an investigative report of exactly what caused the roll over, only the steep hill must have been the culprit. It would be interesting to know how many under inflated tires on the low side rolled from the rim on hills that were borderline too steep to begin with. And let's not forget the torque to drive the bush hog.
   / New to mowing hills... what are safest mowing patterns? #12
Do you know what the degree of slope is on your steeper sections?
   / New to mowing hills... what are safest mowing patterns? #13
Sideways or up-down, keep the roll bar up and safety belt fastened!
   / New to mowing hills... what are safest mowing patterns? #14
How long are the steep parts? Would it be practical to back uphill, shift over a row, come back down and repeat?
That's what I do on some steep parts of my property, but we're only talking about 150' or so.
Do you have any flatter land to turn on the top?
It takes time to be comfortable with a new tractor on slopes, suppose you know your land so dangers as ditches, holes and bumps is accounted for?
Flatter land: sometimes yes, sometimes no. But the “yes” places are a new and helpful idea to me.
Good point. I know I will need a beater (someone to walk ahead of me) first time through. There ARE some large rocks still in our pastures that get lost in the tall grass. Fewer ditches, since we do not have cows. GOOD point, though, thanks!
I think I COULD do that AFTER I’ve learned to operate the tractor on more flat land first. Question: can one mow in reverse? And, will the bush hog stay in a straight line if I am backing up a steepish hill?
   / New to mowing hills... what are safest mowing patterns? #18
Nice looking place.
Good idea about walking the area you are going to mow, before hand. Also, your tractor probably has some documentation about slope capability, that you might want to review.
   / New to mowing hills... what are safest mowing patterns? #19
Mark any danger with a stick or pole and paint it so you see it, very cheap safety precautions.
   / New to mowing hills... what are safest mowing patterns? #20
Widen the track and you gain stability, those small tractors are quite low.
This video shows what can be done with low center of gravity and wide track.
AEBI TP 48 im S?enberg - YouTube
AEBI makes tractors that are specifically for steep hills. So while this shows what can be done and is incredible, it isn't comparable to the tractor he has.
2006 GMC C8500 Altec DM47 47ft Digger Derrick Truck (A55852)
2006 GMC C8500...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2015 Ford F-550 Altec AT40M 40ft. Bucket Truck (A55852)
2015 Ford F-550...
1998 Transcraft (A56469)
1998 Transcraft...
