Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #5,761
I had to install a float valve on my swingarm mower. The wall angles of the ditch I mow are constantly changing from steep to shallow and I couldn't keep up on the tilt control, missing grass in places and gouging the ground in others.
Mowing got a whole lot easier for me with float control.
/ Let's talk flail mowers #5,762
Has there been any debate here about changing Caroni knives using M10x75 bolts?
The slightly shorter size would still be long enough to catch the locknut and save a lot of wrenching.
Just curious - I am about to change knives again this spring.
Metric hex bolts, Zinc plated class 8.8 steel, 1mm x 1.5mm x 75mm - Bolt Depot
Hello LouieJunior,
I would not use the shorter metric bolts UNLESS they were fine thread and you used blue Loctite to hold the fine thread nuts in place with a lock washer as well.
Happy mowing.
/ Let's talk flail mowers #5,763
Hello LarJea,
What you are referring to is a 4 way spool valve.
Happy mowing
/ Let's talk flail mowers #5,764
leonz, I was trying to reply to powerscol's post, "Float is not needed with a swing arm mower" For some reason when I hit "reply" the quote I was referring to never came up.
/ Let's talk flail mowers #5,765
I bought this one here:
PK-AT Gas Flail Mower |
for $1600 plus tax. Should have offered less, they grabbed offer right away.
Those are imported from China and sold online for around $900 plus importing expense.
I mowed twice with it, yesterday being a long mow, around 2 hr.
It actually mows very well. I bought because of the wtland, I have to mow over puddles and mud pits. So I use SXS to pull it behind, as SXS does not care, goes anywhere.
I have 59 inch version. Not sure how wide it is with wheels.
Spoke with their tech, he swares it's same Honda engine, told me they charge him $45 to put HONDA sticker onto it, as it's made in the same factory Honda engines are.
Yes, it's a bit tight hard to turn and takes learning curve to figure how to properly pull it. I have severla tight spots in my property, around trees and fence corners, so I left that for my ol' faithful craftsman and trimmer.
But overall, it saved me about 2 hrs of mowing, as I can mow at high speed (7-8mph) and it leaves pull table smooth surface.
Goes very well over bumps in the property, I have **** for grading. My 60 '' ZTR takes 4.5 hr to do entire property with some trimming left. I did yesterday 80% of it in around 1 hr 40 min with flail.
2 things I really miss in it - gas gauge and remote shut down. You can install battery and it will crank engine with starter for you.
If you have long straight runs to mow and plenty of space to turn - that thing is great!
/ Let's talk flail mowers #5,766
Did not know such a thing was even made! Cool. Hope it lasts a long time.
Ricn
/ Let's talk flail mowers #5,767
It is VERY solid. Solid and heavy. Thick gauge steel, thick welds. Blades do not get hurt, they do indeed bounce off obstacles. 3 belts. It'll last.
Best priced I could find, otherwise, they start at $3K plus and go up higher. There'splenty of PTO driven ones, tow behinds are mostly in England.
/ Let's talk flail mowers #5,768
/ Let's talk flail mowers #5,769
If you put in a battery, a relay such as: https://www.amazon.com/AGT-Waterproof-Wireless-Universal-2-Channel/dp/B0068D0OBI/ would let you remotely shut it off.
If wires were ok, you could wire in a switch and a 2 wire cable to parallel with the shutoff switch to let you shut it off from your SXS.
Aaron Z
Thank you but my electric skill is at the level of bulb changes and very basic splicing.
I have 2 wires still taped to the mower engine, for the battery. Not even sure how they connect to the ignition switch.
that said, will you kindly draw a simple diagram of how to connect such things? Simple. Without all the electric folk secret language and hieroglyphs...
Thank you
/ Let's talk flail mowers #5,770
Thank you
Can you post a picture of the shut-off switch on the engine and (if possible) the wires connecting to it?
Aaron Z
/ Let's talk flail mowers #5,771
At work. Later tonight.
It's a regular 3 position switch with key - Off/Run/Start.
/ Let's talk flail mowers #5,772
Unmount the whole key assembly. Cut & extend the wires 10' or so until they reach the cab. Splice them back together & secure them the the mower. No need to figure out what wires do what as long as you keep them the same. You get "remote" start & stop.
/ Let's talk flail mowers #5,773
That's good idea. I can even mount switch on whatever I'm using to pull mower with and make a plug on extension.
Thank you.
/ Let's talk flail mowers #5,774
I used this very informative post to help me make a decision on a flail mower for my farm last season, and ended up with the Peruzzo Elk Cross 1600. It cost a bunch of money but it's been great to use. We're selling the farm this year so I'm looking to offload it. Does anyone have a good suggestion for a used marketplace for this type of equipment? A ditch bank flail is kind of an oddball piece of equipment and I'm not sure how much luck I'm going to have getting rid of it.
/ Let's talk flail mowers #5,775
You might update your information so it shows your location. You may have a TBN member nearby that needs this.
/ Let's talk flail mowers #5,776
Since you didn't fill in your location, it would help to know where in the world it is located.
This Flail Mower thread is a good starting place. The next place would be a post in the "Member Marketplace", "Attachments For Sale" thread: https://www.tractorbynet.com/forums/attachments-sale/
Good luck and please keep participating on TractorByNet :thumbsup:.
/ Let's talk flail mowers #5,777
I think my 1st choice would be the your buyer of the farm. Should be able to offer all the pro/cons why he needs it.
/ Let's talk flail mowers #5,778
Craigslist Farm and Garden. Ton of mowers on it.
/ Let's talk flail mowers #5,779
So I did my second full mow with my tow behind flail. One from Betstco, 59 inch.
As an anecdote, muffler fell of it in about an hour of mowing. Of course, all nuts got lost in action, so I rummaged through my garage and found some. Was more of laughter, than real problem, hope that's the last one.
I let grass grow for 2 weeks, so for me, it was tall. I normally mowed every weekend before, as even my ZTR will choke on taller grass.
This thing does not care. It went through grass like it was not there. Also, because of wetland, it went through puddles and mud with the same attitude.
On upper, flattier of my property, mow is very nice. Looks like table.
On lower, very bumpy/hillocky tier, not so nice, as mower moves up and down with terrain. So it's a bit patchy, but still more than passable for wetland.
Overall, I am very pleased with it and am selling my ZTR. Also, saved me about 1.5 hr of mowing, as I went 8-10mph, while in ZTR, lower tier, I creep painfully maybe a mile or 2 per hr.
That's good news.
Bad news: it's all hard to maneuver, of course. I have couple very tight corners, so I could not go all the way to the fence or turn around, with SxS and mower length. So some patches left, and boarders, I had to comb with my 'ol faithful Craftsman riding mower, what added another 40 min to the job. Next, mower is thirsty. Gas tank lasts about 2 hrs. Though I could never tell how well it is filled as there is no gauge.
Actually, found that it was shipped with battery, connected it yesterday, it cranks and starts right away.
Another anecdotal part - there's lots of parts on the engine stamped Made in Japan.
So if you have large open field to mow, without crooked turns and tight spots - that thing rules. Or, harsh terrain, puddles, shrubs - same, it does not care, munches thorugh everything.
/ Let's talk flail mowers #5,780
DITO!
However, you need to post pictures of the mower ON your tractor in all of it's positions. Pictures sell!
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
2016 Bobcat E50 (A64126)
2016 Bobcat E50...
Coleman Powermate Generator (A62613)
Coleman Powermate...
Lot of (4) Square Tube Gates (A66408)
Lot of (4) Square...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
