What did you do to or on your Mahindra today?
   / What did you do to or on your Mahindra today? #641
Had the tractor out the other day getting it ready for mowing season.
   / What did you do to or on your Mahindra today? #642
I have been wanting to install some sort of clock on my tractor for a long time. I finally gave in and bought a Trail Tech clock/volt meter and installed it today. Trail Tech stuff is typically used on off road vehicles, atv's etc. and is made to withstand outdoor use well. I just used the double side adhesive pad to stick on the instrument cluster where it's easy to see. I finally won't have to stop what I'm doing, stand and pull out the cell phone just to check the time anymore. Simple and convenient!
   / What did you do to or on your Mahindra today? #643
Cool. I'll have to check into those
   / What did you do to or on your Mahindra today? #644
Check out Trail Tech's website. The one I got for my tractor is the most simple and cheapest because that was all I needed. They have much nicer units that could replace or serve as an entire instrument cluster with all sorts of options.
   / What did you do to or on your Mahindra today? #645
Moved 150 yards of fill dirt and constructed three drainage basins over the weekend.
Before:
After:
Still need 75 more yards.
   / What did you do to or on your Mahindra today? #646
That looks really good! That's alot of dirt. What tractor do you have what size?
   / What did you do to or on your Mahindra today? #647
eMax25, but it doesn’t think so. This is the biggest job I agreed to undertake. The timing and duration was just right.
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
