What did you do to or on your Mahindra today?
/ What did you do to or on your Mahindra today? #641
Had the tractor out the other day getting it ready for mowing season.
/ What did you do to or on your Mahindra today? #642
I have been wanting to install some sort of clock on my tractor for a long time. I finally gave in and bought a Trail Tech clock/volt meter and installed it today. Trail Tech stuff is typically used on off road vehicles, atv's etc. and is made to withstand outdoor use well. I just used the double side adhesive pad to stick on the instrument cluster where it's easy to see. I finally won't have to stop what I'm doing, stand and pull out the cell phone just to check the time anymore. Simple and convenient!
/ What did you do to or on your Mahindra today? #643
Cool. I'll have to check into those
/ What did you do to or on your Mahindra today? #644
Check out Trail Tech's website. The one I got for my tractor is the most simple and cheapest because that was all I needed. They have much nicer units that could replace or serve as an entire instrument cluster with all sorts of options.
/ What did you do to or on your Mahindra today? #645
Moved 150 yards of fill dirt and constructed three drainage basins over the weekend.
Before:
After:
Still need 75 more yards.
/ What did you do to or on your Mahindra today? #646
That looks really good! That's alot of dirt. What tractor do you have what size?
/ What did you do to or on your Mahindra today? #647
eMax25, but it doesn’t think so. This is the biggest job I agreed to undertake. The timing and duration was just right.
/ What did you do to or on your Mahindra today? #651
Nice SimpleSimonn. Were you putting in a new road or filling in a trench?
/ What did you do to or on your Mahindra today? #653
It does look really good!
/ What did you do to or on your Mahindra today? #655
Your ROPS needs to be up for protection for you the driver. Safety first!
/ What did you do to or on your Mahindra today? #656
no, I was just grading my lane- after a winter of rain and mud, I grade it once a year- I really should put down clam shells- another part of the lane is partially covered with them, and I don't have to grade there! Better than stone, and available in this area.
/ What did you do to or on your Mahindra today? #657
Well, I read somewhere that if you don't use your seat belt, you can put it down; but if you DO use your seat belt, you MUST have it up- besides, the land is flat here, and if I did have it up, I might catch it on some of the trees around here.
/ What did you do to or on your Mahindra today? #659
Another day at the office.
YRLqJXAK67RwWgrzYH64cFz7ySOK-gV_941XSl-EDJuzJsq7MFj3kSTNIadZ1MYMnOyZt_X7PPYM4ZZnDq2M8BbEF86ef82xg9jhtGBFpHN4Kpr00tC3xN9hlXY3kVZwpmu7wvsxGHQSr1hVZ5QEPNZvLxmS9MF8fkrs2LtR5NFkpv2UoVVX_6I4ZZK1tvsbtNcOkczLd4u2azxk4XCOeF1hGcYlpKgJMGyTHJF7ASBle9_jPYroVwLAYiZsjBj0-LRtcAbiAY95nyl03IQA_NX95u-87zg-lSKtJLFZrX0oFv556Oea6bjVWt9j46iyfwnv7TNWva9Si2vQjnGXtpvDaf_J2tvAmGCf90VBligImqw02OCbH1OjcSTPidPwOEMZfY0dNTyTQKr-IDQ63lvnyNrc6cUggWL3mpXkgm5zJC7f_0KJGDNuHdDOdMXhxn_oWAqnswP0ysHEB7ANh13vvm7tad5Y-VFZ8ONMsFCJKllo7vFNoancBicruwl-7FPHfTAw2lYZknMRyl4C75Bc0wgvuUAfzOtlvc_v5ZFHl5psqTzirt-mi5euL5qLTruCLt9E-7XmVpIS7yVZ-fW8nPW5AyyQOY4DC-8BmkUV_xy4cZtHQC2SPjISvhwcbQfcUTbnzA1WZ-MABwigSLPmwNfslkbh=w500-no-tmp.jpg
