Shop Walls
/ Shop Walls #21
Don't know if you've ever thought of this, but what about using cement board for the bottom 2-3'.
Solves the water issue, the fire issue, the ding issue. It's pretty strong. You can paint it, caulk the seams.
Just a suggestion. (might be a bad suggestion, but at some point all of the ones you don't pick will be bad too!):2cents:
/ Shop Walls #23
I too thought of cement board, but if you did damage it, you would have a job repairing it. Plus, mounting stuff to it isn't ideal.
/ Shop Walls #24
40 Gallons! Woa! I知 thinking about doing the same thing in my 40x50. Was going to try using an airless but did not expect to need that much. Wow. I guess I have my work cut out for me.
My ceiling took a lot of paint, painted over the exposed closed cell foam, and scissor trusses, the Graco sprayer was great at sucking the paint right out of the 5 gallon bucket.
/ Shop Walls #25
Hi,
I'm building a shop area and would like the bottom 2 feet of the walls to have durable wall covering. Drywall and peg board will go on the upper parts of the walls.
But I would like something durable on the bottom 2 feet to resist damage from rolling carts, tires, etc that may hit the walls.
I was thinking about plywood, MDF, 2x6's installed like shiplap, but without the lap.
Not a fan of OSB since there may be dampness on the concrete floor. MDF may have the same issue with dampness.
Any ideas for an inexpensive durable option?
Thanks,
Doug
If the keyword is "inexpensive" then OSB is always going to be your best choice. Rip a sheet in half and you can cover 16 linear feet for less then $10. Nothing else will even come close.
If appearance is a consideration, look into Smart Siding. It's a higher grade OSB then the normal construction stuff and the appearance side has a wood grain stamped into it that looks like T1-11 siding, but a lot nicer.
/ Shop Walls #26
I left my OSB unpainted because I know how much paint it sucks up and I'm OK with the looks. If I felt it had to be painted, I would have gone with a different option. Probably metal liner panels like I have on the ceiling.
/ Shop Walls #27
I went with OSB and painted it white. Looks? Fair to poor, it does suck up the paint. It is a shop though and good enough for me. Mine is also OSB every where, wall and ceiling.
/ Shop Walls #28
Hi,
Thanks,
Doug
You might consider MDO.
>>MDO is produced with a high-quality thermosetting resin-impregnated fiber surface bonded to one or both sides under heat and pressure to create an exterior-grade plywood panel. Specially selected veneer directly beneath the fiber overlay provides a smooth surface that is ideal for painting. MDO is manufactured with waterproof resins that meet or exceed all veneer-grade, adhesion, and construction requirements. Sign writers find MDO is ideal and the panels of choice for Exterior Signs.<<<
MDO Medium Density Overlay | Anderson Plywood
TBS
/ Shop Walls #29
TBS
Neat stuff, but at $48/sheet it must be injected with gold flake.
/ Shop Walls #30
I'd probably use OSB or T-111.
/ Shop Walls #31
I think when I ever get to finishing my shop, I will use moisture resistant drywall on the bottom 8' portion of the walls. And then use 4 x 8 sheets of 22 - 28 gauge galvanized sheets over them. I will pick the gauge when I see what the cost at the time is.
A little salty but it will hold up very well.
I worked in a shop with this type of finish and as much as I thought weld arc flash would be bad, it never was an issue.
/ Shop Walls #32
Hmmm. I really like this idea. Quite a bit cheaper than diamond plate and close to the look and function I’m going for.
/ Shop Walls #33
if you do go this route, and you have wood construction ( I Have standard 2x6 wall studs 14' tall) and if you plan on making sparks, especially welding and or cutting, make sure make sure you protect the bottom plate with a sheet metal angle (or something) underneath the drywall, so no hot embers roll up and start the wood on fire.
:fiery:
/ Shop Walls #34
I've been thinking of doing something similar and I have been considering using Zip Board. It's supposed to be weather-resistant so I assume it would handle dampness. It's about $25 a sheet so it's more than OSB but still not ruinous. I don't know how well it takes paint. I'm also not sure which face I want to look at.
/ Shop Walls #35
I’ve looked into this stuff. I think it’s basically Exposure 1 rated, same as OSB sheathing. It will stand up to some water but will eventually swell. And eventually is probably within 1 year.
/ Shop Walls #36
:fiery:
Good point. Thanks.
/ Shop Walls #38
Local rink was replacing the boards - got some pieces of this 1/4" plastic puckboard, turn the scuffed side to the wall, and install. White shiny very durable plastic.
/ Shop Walls #39
Hi,
Thanks,
Doug
My definition of inexpensive is probably different from your definition. My Morton stables has 2"X8" tongue and groove with the bottom board being ground contact. It looks nice and has absorbed a lot of impact from 1500# horses hooves without any damage. I used Menard's as an example for pricing. You could use 20' sticks with the bottom treated and the 2 above it not treated. That would give you your 24" height and 20' of wall length for $100.
https://www.menards.com/main/buildi...nd-groove-treated/1111260/p-1444422142679.htm
https://www.menards.com/main/buildi...ellow-pine-lumber/1028887/p-1444422743797.htm
My walls are 8' tall but this gives you an idea of what it would look like.
/ Shop Walls #40
When I get that far, I'm going to buy 12"x12" porcelain tile, and do the bottom 4' of the walls with them.
HD has them for a buck a piece, all the time.
2020 CATEPILLAR 289D3 SKID STEER (A65056)
2020 CATEPILLAR...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
Unused HLA BRB84 84in. Hydraulic Rotary Pick-UP Broom Skid Steer Attachment (A66734)
Unused HLA BRB84...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2011 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2011 Dodge Ram...
2006 Hummer H3 4x4 SUV (A66738)
2006 Hummer H3 4x4...
