Rounded off drain plug
/ Rounded off drain plug #1,423
Have you tried a left hand drill bit?
I pretty much gave up using easy outs a long time ago, because they often break, leaving an even worse problem.
A left hand bit (using the largest size possible without damaging threads) will heat the remainder of the bolt thread, as it also tries to back it out, and will often remove the bolt without even needing to use an easy out.
I have a complete set of left hand bits to 1/2"
Set your drill press up with a reversing switch and you have a hole set of spare bits. I do not have a reversing drill motor that has enough power to back out a really stuck bolt; but, my 1/2" battery powered hammer drill works pretty good, some times.
Ron
/ Rounded off drain plug #1,427
I’m pretty sure we’re going to make it to 1500. I had my doubts of it happening 500 post ago though.
/ Rounded off drain plug #1,429
make it
/ Rounded off drain plug #1,430
to 1500
/ Rounded off drain plug #1,431
easily.
/ Rounded off drain plug #1,432
Counting down to the big weekend. You Kan DO it!!
/ Rounded off drain plug #1,433
Geez you guys, after the plug comes out we have the after math of that......
/ Rounded off drain plug #1,438
Some must not be the outdoor types to still be running up the counter with Spring outside. :)
/ Rounded off drain plug #1,440
I have been outside since 8 AM, just came in to eat some lunch and read some internet.
Bet I have been in the woods today more than you....
Generac Guardian Ultra Source 15,000W Portable Gasoline Generator (A61567)
Generac Guardian...
43024 (A59228)
43024 (A59228)
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
2016 INTERNATIONAL LF687 T/A 6X2 SLEEPER TRUCK TRACTOR (A59908)
2016 INTERNATIONAL...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
Adams 5 T Fertilizer Spreader (A63118)
Adams 5 T...
