Rounded off drain plug
/ Rounded off drain plug #1,402
No sacrasm and it is not morning, not even in Texas. Kando will get it done, be patient.
I am kinda old already.
Am beginning to worry if I will EVER see the end of this story.
Holding off for Easter weekend which will (hopefully) see us off work to give us plenty of time.
/ Rounded off drain plug #1,405
/ Rounded off drain plug #1,407
I left this thread for a long time since it didn't seem to be going anywhere. But I almost had one of my own the other day to add. Older ATV, drain plug for the transmission is 1/2" hex head, but you can't even see it. You have to feel for it from the bottom through about a 1-1/2" hole through the frame. Found it and got a socket on it, but ..... slipped. Tried again, same thing. Went and got a different socket, repositioned myself as best I could to get the most uplift on the ratchet and ability to turn it more squarely and ....... success!!! Broke it lose, pulled it out with no further issue. Hope I don't ever have to do it again since I didn't replace it.
/ Rounded off drain plug #1,408
I had to replace cracked exhaust manifolds. I didn’t break any bolts but they must’ve been off before because they had 2 bolts already broke. I drilled them and tried to use an easy out. I broke an easy out one and the other wouldn’t come. I didn’t feel like pulling the head off for further work so I just mounted it with 6 bolts.
/ Rounded off drain plug #1,409
https://www.homedepot.com/p/Sunex-1-2-in-Drive-Pipe-Plug-Socket-Set-8-Piece-2841/303158439?cm_mmc=Shopping%7CG%7CBase%7CD25T%7C25-1_HAND+TOOLS%7CNA%7CPLA%7c71700000034127224%7c58700003933021546%7c92700031755124841&gclid=CjwKCAjwkcblBRB_EiwAFmfyy_hSS8JxrOQbAB0jT528VO8twpXi1PuPd0JpevyTb-CL0my2BL8o6RoCmx0QAvD_BwE&gclsrc=aw.ds
I ordered this set of square female/male sockets tonight. The bleeder plug in the center on the 1950's in-ground single post car lift is a 7/16" square male. It is recessed about 8" and the square head is still square and I want to keep it that way. A crows foot may have worked but I do not want to risk it since It may not have been out in many years. I liked this set because it comes with a storage box to make it easier to keep the set together is a drawer of seldom used special tools. There are cheaper options but without the right tool a 30 second job can become long by days, weeks, months. This thread has been thought provoking.
/ Rounded off drain plug #1,410
I should probably invest in one of those but I’ve never found a real need for one. The only recessed square holes I’ve encountered were either 1/2 or 3/8 and a ratchet worked fine. I did have to buy a set of female Torx sockets for removing vehicles seats.
/ Rounded off drain plug #1,411
I had to replace cracked exhaust manifolds. I didn稚 break any bolts but they must致e been off before because they had 2 bolts already broke. I drilled them and tried to use an easy out. I broke an easy out one and the other wouldn稚 come. I didn稚 feel like pulling the head off for further work so I just mounted it with 6 bolts.
Have you tried a left hand drill bit?
I pretty much gave up using easy outs a long time ago, because they often break, leaving an even worse problem.
A left hand bit (using the largest size possible without damaging threads) will heat the remainder of the bolt thread, as it also tries to back it out, and will often remove the bolt without even needing to use an easy out.
I have a complete set of left hand bits to 1/2"
/ Rounded off drain plug #1,412
I did not get that lucky. My plan was to use a long extension upside down with a wrench on the male square end but have not come up with a 7/16" drive ratchet set yet. :) If my 21 year old son wrenches professionally or not he may need them a few times over the next 50 years.
/ Rounded off drain plug #1,413
Kando says he has a buddy helping him out over Easter weekend so in the pool for when the plug finally comes out I'm going with Saturday, April 20th at 3:11 PM.
/ Rounded off drain plug #1,414
When that plug finally comes out dust and moths will also.
/ Rounded off drain plug #1,415
What year?
/ Rounded off drain plug #1,417
Oh come on, have faith in Kando :confused2:
/ Rounded off drain plug #1,418
/ Rounded off drain plug #1,419
2008 Ford F-150 Ext. Cab Pickup Truck (A61568)
2008 Ford F-150...
2015 Ford Transit 350 Sewer Viewer Van (A61568)
2015 Ford Transit...
2018 BMW X1 28I SUV (A61569)
2018 BMW X1 28I...
2006 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2006 CATERPILLAR...
2023 PJ Trailers 23ft Equipment Trailer (A61165)
2023 PJ Trailers...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
