When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need?
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #21
I can understand that.
But I will also say that of numerous tractor dealership and independent tractor repair shops I have been in,
I can not think of a single one I would be comfortable having them rebuild a hydro. A few of the mechanics yes, but they do not have a clean enough facility.
Replacing one OK, but I also know that is should have a drain and refill after just a couple of hours on it from airborne dirt and dust.
My local dealer uses a non-local company that specializes in rebuilding hydros. Of course, they can't do so if parts are not available. If I had multiple tractors, it would matter less. Then again, I don't have a hydro - so it doesn't matter at all to me!
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #22
Just wondering what the potential repairs will be on a hydro tractor as it ages?
I dont really think this is an apples to apples comparison.
A friction clutch is a wear item by design.
Clutch maintenance usually only means keeping it adjusted correctly.
No matter what, the clutch will wear from use.
An HST is a hydraulic driven motor that drives the metal gears in the transmission.
It is not a wear item. Meaning it is not designed to wear from normal use.
Maintenance is changing the fluid and filters.
Failures are not common although they do happen.
I would think that you run the same risk with the hydraulic system as you do with the prime mover (engine). A failure in either with a high hour machine will mean the machine is scrap. Unless the owner is mechanically inclined.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #23
You do have wear parts in a HST that are designed to wear. You have swash plates, pistons, valve plates, thrust washers, cylinder blocks... The list goes on and on. So yes, after X hours, it'll either get a rebuild kit if it's still available or just dump the whole thing out.
While a clutch will wear faster or slower according to use and how it's used, the HST will wear faster/slower according to the maintenance and the quality of oil and filters.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #24
No one has said anything about wet vs dry clutches.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #25
My 32 year old Ford is a basic geared transmission. IF I ever get a new tractor (highly unlikely), I was curious as to the possible repair bills with a HST.
Then why bother asking?
I hope I don't come across as rude, but the answer is in my quote in your post. "I was curious..."
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #27
Expensive when they do go bad, I hope I never have to on my Branson with them.
On the farm one of the magnums has over 10,000 hours with no issues yet on the clutch packs,
the Puma 125 has 9000 hours and no work done to it yet as far as clutch packs, wiring issues yes a few of those.
I know the dry clutch on my IH574 would be much less expensive and a lot easier then the wet clutch packs on my Branson,
heck I could be putting the 574 back together before I had gotten to those clutch packs between removing the cab and splitting the tractor.
But most likely quite a bit less then a hydro repair.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #28
While probably not directly comparable we had a problem with our hydrostatic drive Ford New Holland skid steer when 1 side of the Cessna Aerospace Hydro drive went out several years back.
Parts and labor It was About $7000 to fix it.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #29
In case anyone was wondering why I recently bought a geared transmission this thread says it all
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #30
My understanding with HST was that if you keep the fluids clean, HST will last longer but not forever; the hydraulic pumps and motors will still need rebuilt. I'd love to know what a running average would be for different machines to reach that point is.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #31
So you can suffer through forward and reversing with a clutch and maybe install a clutch and probably not live long enough to wear out the HST?
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #32
I just love the load sensing hydro in my wheel loader for the most precise movement possible. But going anywhere far away is a challenge.
Then I replaced the manual tranny on our 6200JD with a Power Quad and Left hand reverser. I really love that reverser. But then that manual tranny was a complete piece of garbage from day one.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #33
Yep and keep my man card in my wallet where it belongs:thumbsup:
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #34
I got a tractor to do work.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #35
I didn’t know buying tools to make work easier required loosing your man card.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #36
I had previously swore by geared tractors.... now i swear at them. I cannot believe how much easier it is to move snow with my hst drive unit. I have no issues with them. Matter of fact now that my snow equipment is all removed, im gearing up to do my 1,000 hour service next month. I just ordered all parts yesterday. Picking up fluids later today. Going to switch tractor oil to Rotella 6 synthetic, but keep hydraulic using Shell Spirax S4 TXM.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #37
If you blow snow with a geared tractor going backwards, you will probably find yourself seriously challenged for the right speed. Once you can't adjust RPM, as you need it for the blower, the three backward gears you might have will all be wrong. And then, you start messing with the clutch.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #38
Depends on the model of tractor... I have tractors with creep transmissions and they go plenty slow in reverse.
BTW, I have both, hydro and gear tractors... I prefer the gear drive tractors for EVERY job except lawn mowing...
SR
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #39
Hydrostatic drives haven’t limited the reliability and popularity of skid steers and CTLs, as far as I can tell, and those machines typically have mush higher duty cycles and more severe operating conditions than a simple homeowner owned CUT.
Walk into your local Bobcat , Deere, or Caterpillar dealer and ask how many people, in the past thirty years have requested a skid steer with a dry clutch so they could have better reliability.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #40
I keep seeing this, what is a cut? simple homeowner owned CUT
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
Sweeper attachment (A61567)
Sweeper attachment...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
