Stick or MIG
/ Stick or MIG #21
I began welding professionally using SMAW (stick) and after a few years welding pressure piping, I learned TIG then MIG. Some exotic metals can only be welded with TIG but for the average Joe homeowner, stick rod will do all you need to do. It is by far the cheaper of the processes since you only need a power source and welding electrodes.
Many folks claim stick is harder to use than MIG but if you go to a welding school, you will learn stick rod welding first because it really is the basic process in welding which all other processes build upon. It really is easier to learn to make strong, solid welds with stick than with any other process. MIG seems easier because you dont have to contend with arc length since the machine does this far you and with auto wire feed that makes it seem easier, but in fact it is much harder to learn to make good welds with a MIG than with stick.
When I taught welding at a local college, I always told the students that you can put more metal on with a MIG in 5 minutes than you can grind off in 30. MIG is notorious for improper fusion at the base due to not having the machine set correctly. While it may look pretty, it could be a very weak weld. I would never recommend using one of the 110V machines, you just cant get enough amps to properly fuse anything more than really thin gauge sheet metal.
Unless sheet metal is all you are going to be working on, stick (pun intended) with SMAW machine. I recommend E6010 and E7018 for DC welding(Buy only a DC machine or combination AD/DC). With 3/32" and 1/8" rods in each of these, you can weld just about anything on a farm.
E7018 is the hardest rod to get an arc started but it makes the smoother weld. You have to hold an extremely short arc length with it which sometimes might cause it to freeze to the puddle if you have a power fluctuation, but dont give up on it.
/ Stick or MIG #22
As a retired professional pipe welder;this is excellent advise.Go DC stick.
/ Stick or MIG #23
I have always hear that it is hard to make a bad stick weld look good, but the prettiest mig can be just window dressing with no substance.
/ Stick or MIG #24
What he said ^^. I have welded plenty with a Lincoln AC "buzzbox" but I sold it in favor of my little Everlast PA160 DC only welder. I also TIG with this same welder. Stick for everything heavy and TIG the really light stuff. I have looked hard at MIG welders, and they sure have their place, but I just don't seem to need one as I can TIG the sheetmetal. Sure it is much slower, but it sure is pretty. :)
DC stick welding with a good 7018 rod makes some nice pretty welds with very low spatter. Low cost, good penetration and good looking welds. What is not to like. Sure it takes a bit more skill to get it done. But is easy enough to learn if you will "stick" with it.
/ Stick or MIG #25
For the price of the one you listed I would get ahold of Mark Lugo on here with Everlast and see what he has in a stick machine, they are great machines.
/ Stick or MIG
/ Stick or MIG
I learned how to weld with stick years ago and haven't welded in 30 years and recently I decided to build a couple of implements instead of buy them. I needed a welding machine, so I bought a stick machine going with what I know plus the upfront cost of a decent stick machine fits my needs and it will not be used much. Too much else on the property development project list....
MIG's by far are easier for me to use because of my dwindled stick skills but buying/renting a gas cylinder on top of paying for a decent MIG machine just took them out of the picture for me.
That's exactly why I decided against MIG.
/ Stick or MIG #28
Amazing how many folks dont know the virtue of the stick. A few years back I had to modify a snow plow frame for the plow Id bought from my neighbor to fit my truck. He asked if I knew someone who could weld and I said well yeah I can. What kind of welder do you have he asked and I told him a stick welder. Oh dude - you need a mig for this job - 5/16 plate steel lap welding. I told him well let me run a bead and then you can tell me what you think. So I ran a good hot root pass - the slag pealed off by itself - and he looked at it said Oh that should hold. I told him 2 more passes and thisl be done. Then i said you know,, a plow frame has alotta stress on it and it has to be done right,,,
/ Stick or MIG #29
I linked to the one that I bought at the end of last year, the PowerArc200STi. I have been very happy with it.
Aaron Z
/ Stick or MIG #30
Lots of variables. Thick metals outdoors (bad conditions) - stick. Thin metals under 3/8 (indoors) with time of essence ie production- mig. Bad metal condition (rust, dirt, grease, etc.) stick. 7018 stick - strong, good looking welds - hard restarts. Mig (GMAW) gas bottles. Flux core - lots of splatter but good outdoors. Buzz box/tombstone machines (transformers) - heavy current draw heavy machines. Inverter mig/stick machines relatively light. I could go on - and on.
2014 Bayliner 18ft Boat with 2004 Venture 18ft T/A Boat Trailer (A59231)
2014 Bayliner 18ft...
SY225C SY225C9C5KL EXCAVATOR (A59823)
SY225C SY225C9C5KL...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
30 Gallon 180psi Portable Air Compressor (A59317)
30 Gallon 180psi...
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
500BBL WHEELED...
