check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,178
- Tractor
- 2009 Kubota BX25
Hello, my fellow TBNers, I am afraid we have a problem with our septic system. We have a system whereby sewage gravity feeds into a nice concrete 2-chamber settling tank, then the effluent gravity feeds into a 4' diameter pump tank, which pumps it uphill to the leeching field. Works great, but just today we were sitting here and all of a sudden the pump tank alarm went off, and stayed in alarm condition. (Strange, because no water was being used at that moment.)
Went outside and confirmed that the pump was plugged in and that the receptacle was live and working. Checked the power cord that goes to the pump for continuity (at the receptacle end, and it showed open. But with an AC pump tank motor, would it show a small amount of impedence if it is okay, or does that depend upon where the armature stopped last time it was on?
We also checked the (extension) cord all the way from the receptacle to where the (short) pump cord plugs into it, and no obvious breaks.
By the way, the pump tank alarm works with a float, like a shutoff float on a sump pump. if the float floats up too high (e.g., because the pump is not working and the pump tank is filling up too much), the alarm sounds off.
I can't think of anything else, other than digging up the tank and pulling the pump, which would be a big pain because we are in the middle of winter and the ground is frozen solid. So guys, and ideas at all would be much appreciated!
James
James
