Buying Advice tractor options
/ tractor options #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Is there an avail options list for Kubota L2501 tractor, Im wondering what my options are as far as I know there is a possibility of adding a brushguard, a more comfortable seat, maybe floormats are avail?
Id like to know what is avail and at what cost.
Im hoping to gather this info myself versus relying on the dealer to inform me.
/ tractor options
Go to the Kubota site and build one
https://apps.kubotausa.com/configurator/BuildMyKubota.aspx?pgId=1&bmId=1060&sId=125
Of course they list only the options they sell which doesn't include all of the non-Kubota branded stuff out there.
Thanks, I seen a you tube video where he mentioned a more comfortable seat or deluxe seat with arm rests, I didnt see it on the Kubota site?
Also my B series has rear wheel weights, I think they are a big help in the sand I have to deal with, Kubota site mentions wheel weights but no picture, are these possibly the same and would you say they would be a wise choice?
It also is telling me that adding a front loader and grille guard isnt possible? I am pretty sure Ive seem it on You tube so Im assuming it has to be fact?
Can someone explain to me the rear remote hydraulic valves??? Would I already be getting these since Im ordering with a backhoe?
On the loader package they offer 2 options
1- HEAVY DUTY FRONT LOADER PACKAGE
2- HEAVY DUTY FRONT LOADER W/2-LEVER STYLE COUPLER
What are the differences? Im getting a quick disconnect bucket, safe to assume thats option 2?
Im also needing a grapler yet I see none listed?
On the backhoe they offer a rubber stabalizer, Im assuming that would be helpfull on a hard surface but useless on sand?
/ tractor options #4
Weight is always a good thing when harrowing or pulling a turn plow or doing loader work where your bucket will be full of heavy material that you will be moving such as gravel or limerock, imho loaded rear tires usually do the trick for the loader work , for the other work mentioned wheel weights in conjunction with loaded tires is a bonus for traction when needed. Charlie.
/ tractor options #5
If you opt for a Backhoe very few would also install wheel weights. Backhoe is 600 pounds, cantilevered well to the rear, with adjustable reach for additional counterbalance leverage if needed.
The Backhoe will only be off when you intend to mount a Three Point Hitch implement.
Personally, I would not "load" the rear tires with a Backhoe order. Others would. Too much weight for sand.
I suggest you order Kubota's rear/center drawbar for L2501 for dragging trees, etc.
Yes. Kubota terms industry standard SSQA "two-lever coupler".
I recommend three aftermarket options:
Ripper Tooth for Backhoe:
Talon Ripper Tooth
Ratchet Rake:
Ratchet Rake, LLC - Tractor attachment, Bucket attachment, Loader, Kubota, Landscape rake, Brush remover, York Rake, Harley Rake, Rock Rake, Tractor rake attachment, Construction attachment, Fire safety, Home fire safety, Fire prevention
A pair of 5/16" Ken's Bolt-on Bucket Hooks:
Ken's Bolt on Grab Hooks <<Kubota Hooks>>
/ tractor options #6
Thanks for that link jeff9366 I just ordered two of those bolt on hooks for my little guy.
/ tractor options #7
WIth regards to the factory grille guard and the FEL - I guess Kubota isnt smart enough to figure out how to both on this machine yet :(. Either that or they need to get a new web developer. You can probably find something after market. The L2501 is one of the most popular tractors out there right now.
/ tractor options #8
Also you are going to need a third function to run a grapple(+$1,000 or so);in a pinch you can run hoses to the rear to use as rear remotes.Your dealer should be able to give you info on "LandPride" grapples or go to the aftermarket.
/ tractor options
I appreciate all the comments and links, is there any one place where remote hydraulic valves dos donts uses, installations ect ect is explained in kid terms.
I know nothing about this other than what Ive been able to find doing a search of this site and Im still confused because the posts are assuming the basic terminology is already understood ( which its not )
/ tractor options #10
In some cases, the FEL option includes an integrated grille guard, so the separate one isn't needed.
There's really no reason to keep the BH on full time if you have the rear tires loaded. Mine comes off easily enough, not sure about the K units.
/ tractor options #11
Exactly this. Mind, the stock Kubota guard is designed for large impacts only, so you might want to take it somewhere and add some expanded metal to ward off sticks or other small debris.
/ tractor options #12
Yes you get rear Hyd connection with the BH, and as others have said, don't need to load the rear tires with the BH, and no need to add rubber pads - they are so you don't tear up asphalt and you can bolt on a chunk of rubber tire tread your self.
As far as the seat - this would be a dealer question - he may have something available or be willing to swap them out for a nominal cost. There are aftermarket options too if you don't like the standard one.
The grappler - that could be the BH Thumb and a mechanical one is what you get with the BH77 (a hyd one is very nice but $$$ 1000 or more. As far as a grapple, for the front those are nice but also $$$ and you need another valve and Hyd lines on the loader to use the grapple.
Since you are getting the QA bucket you might want to have the dealer add another set of remote hyd connectors on the loader at the bucket. This way you can add a grapple later (you can find them used).
The 2501 doesn't have a rubber deck and has the center hump - some options are stair tread rubber or anti slip, or modify a rubber car mat. I would live with it for a bit then decide.
Carl
/ tractor options
I went by my local Kubota dealer today and peeked they the fence, all fel models had a grille guard
/ tractor options
Carl
Thanks Carl, you and everyone have been a great help
/ tractor options #15
If money is a big deal; usually is K&M offers a variety of seats at reasonable prices. Several companies offer grapples cheaper than the top brands. At the recommendation of our dealer, we passed on LP and got "no-name" Loflin and a Titan tree puller. I "usually" buy top of the line, but have backed off on recommendation of knowledgeable users.
As to the third function valve, we have one on our L5740 and control one off the rear remotes and Ken's Bolt on sell a diverter package. We keep meaning to build our own, but not enough time and the rear remotes work fine. Position of your levers will influence that decision.
2016 CHEVROLET COLORADO PICKUP TRUCK (A66091)
2016 CHEVROLET...
2001 John Deere 7710 (A64911)
2001 John Deere...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
2016 Chevrolet Tahoe Multipurpose Vehicle (MPV), VIN # 1GNLCDEC0GR387273 (A66738)
2016 Chevrolet...
