Bathroom Re-model concrete foundation
/ Bathroom Re-model concrete foundation
Here's the latest. Capped the drain and vent. Probably going to do the copper 1 side at a time while I'm on 2nd shift and the wife is at work and kids at daycare. I did the concrete saw and jack hammer part while they were away today. 20190223_225027.jpeg
/ Bathroom Re-model concrete foundation #22
Don't want to be captain obvious but make shure you rap pipes with Styrofoam before you pour concrete. Great work.:thumbsup::drink:
/ Bathroom Re-model concrete foundation #23
Be sure the copper is not in contact with any concrete. The concrete will corrode the copper.
In your case I'd stay with copper since it's whats there and is a small job, but keep PEX in mind for other plumbing work.
/ Bathroom Re-model concrete foundation #24
Sounds like you got some great advice already and it looks like you are doing a very nice job. I'm just commenting so I can follow your progress and see the finished pictures.
Thanks.
I think you put down alot of tile?
Would you use self leveling goop over this thinset left after removing 2 layers of tile? Or just thinset and tile over it?
Any recommendations on radiant floor heat mats or whatever they are called?
Forgot picture for when I said "this thinset left behind"20190224_094510.jpeg
/ Bathroom Re-model concrete foundation #27
/ Bathroom Re-model concrete foundation #28
Whoops... missed this. :thumbsup:
I hope you put proper insulation around those copper pipes going through the slab. Concrete will eat up copper, fast...
They were there from when the house was built. I hope they did too.
Yes I understand the lime in the concrete will eat up copper.
I do plan to cover up the copper pipes I modify to sit below floor level, so the concrete doesn't touch it.
Got the hot water side ready today. Pretty much duplicated what was already there, just 3 feet shorter.
I am thinking actually putting concrete over this will be the last thing I do. I will leave it uncovered to monitor my handiwork until I feel confident to seal it up forever.20190224_222339.jpeg
/ Bathroom Re-model concrete foundation #31
Must be a delayed echo in here.:drink:
Eddie Walker, would you use self leveling compound over this or just tile over it?
I think you have done ALOT of remodels and tiling, figured you would know the best way.
I have used the self leveling compound once. Its expensive for what you get and kinda a pain, but it did exactly what I needed.20190224_094510.jpeg
/ Bathroom Re-model concrete foundation #33
I have used the self leveling compound once. Its expensive for what you get and kinda a pain, but it did exactly what I needed.View attachment 593663
I would scrape and/or grind it all off. For a big area like yours, renting a floor grinder would get 90 percent of it off in a few hours. Then the areas around the cabinets would have to be done by a smaller grinder, or chisel end on a SDS rotary hammer.
Thanks, I figured you would know.
This is what's left of the shower I removed. Plugged the drain/vent off where it teed off. Shortened the copper pipes below grade.
Been framing, wiring, sheetrocking and painting.
/ Bathroom Re-model concrete foundation #36
Ask around. Who do you know who has had remodeling done and has been happy with the result?
We had our bathrooms remodeled 3 years ago by a guy who had done some work for a friend.
The basement bathroom is still a basement bathroom - nothing fancy, but all the things that annoyed me have been fixed.
The main bathroom was a gut job. We replaced the bathtub with a walk-in shower with a rain shower. All new tile. Moved the plumbing. New vanity and sink. New lighting. New fan, paint, etc.
/ Bathroom Re-model concrete foundation #37
That's a very nice bathroom!!!
/ Bathroom Re-model concrete foundation #38
We just finished up doing our master bath, original from house build in 1985, sorely in need of a gut job. Glad wife didn't see that wall insert/display thing, or I'd have been doing that too ! :D
Wife and I did about everything but the glass door on the shower.
enhance
Doors I built (had a stain glass panel made for it)
enhance
enhance
enhance
enhance
/ Bathroom Re-model concrete foundation #39
That's an interesting bathtub. Do you walk into it, sit down, close the door, then start filling it up while sitting there? How long does that take? I guess the same happens when you are done? you open the drain and wait for the water to go away before you can leave it?
/ Bathroom Re-model concrete foundation #40
I get the handicap ease but I also wondered about the amount of time you have to spend stuck to take a soak.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
TAYLOR 2R MULTI-PASS HARVESTER (A64278)
TAYLOR 2R...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
1975 HOMEBUILT TR-AXLE LOWBOY TRAILER (A64278)
1975 HOMEBUILT...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
