Comparison Opinions needed between these two
/ Opinions needed between these two #1
Bedlam
I wonder how many people have bought and use either of these products and might offer an overall opinion. I was planning on the Lowes one but then found the tractor supply.around here the tractor supply is about 10 dollars difference. Not much of a concern...Just wondering how dependable each one is. (this is replacing a 38 year old Craftsman that only ever had a belt replacement) (well built!!) thanks
https://www.lowes.com/pd/Kobalt-60-Gallon-Electric-Vertical-Air-Compressor/1000542193
DeWALT 6 Gallon Air Compressor 155 PSI, DXCM61 at Tractor Supply Co.
/ Opinions needed between these two #2
The dewalt has a far better review score. That's about all I can say. I've transitioned off of air. Everything I could do with air around the house I can now use battery tools. Quieter, less maintenance, more portable.
/ Opinions needed between these two #4
Kobalt is 2 stage I would rather have that myself. I assume that is why the 175 psi rating
Dewalt just has 2 cylinders
/ Opinions needed between these two #5
I would think either would work. I would go with the Dewalt based on the reviews.
/ Opinions needed between these two #6
How many cfm do you need, and at what psi do you need it?
That is the question the OP must answer.
The rest is just "How much does a pile of horse feathers weigh?"
Good point. I have gotten by with just around 120 or 130 PSI for years even able to run the tire machine. But I feel more PSI would help with that tool.I think either one would be enough CFI I only had a shortage of CFI when I had a sand blaster. I don't use that much if at all. And actually I plan to put also have my old craftsman inline also.So would think that the two running on a rare occasion would be fine.
Heck just fixing all the leaks will help. LOL
/ Opinions needed between these two #8
One has a longer warranty than the other as well. Something to consider.
/ Opinions needed between these two #9
You can spray automotive paint, or sandblast with "battery tools"?
/ Opinions needed between these two #10
The Kobalt is two stage, has good reviews, and puts out 11 cfm at 175psi.
That is 20psi. more than the DeWalt, meaning your air supply will last longer before the compressor must restart.
If you are a veteran, when you buy this compressor from Lowe's you will get a 10% discount.
Neither of these is anywhere near the same quality as a 5HP Quincy Pro, but neither costs $2200+ either.
/ Opinions needed between these two #11
Everything I need to do. I don't need to paint or sandblast. And if, by some chance I did need a quality finish, I have several powder coat shops within an hours drive.
/ Opinions needed between these two #12
Those stats are terrible. 11 cfm is a joke. And it's actually 10.7 for the Kobalt, according to the specs online. The 175 psi is a useless stat. Its cfm that does the work. The Dewalt shows 11.5 @ 90 psi, which is also poor, but they don't even tell you what the cfm would be at 155.
Take a hard look at the Quincy compressors, over either one of these. Much better stats, much higher cfm at the high psi range too.
/ Opinions needed between these two #13
Ah yes....powder coating....the most despicable coating ever invented.
/ Opinions needed between these two #14
OH ....absolutely DO look at the Quincy compressors.
I have the 5HP Quincy Pro, but..... check your wallet.
Best price I have seen for the 5HP Quincy Pro (has pressure lubrication) is $2200 plus shipping, direct from Quincy, Ill.
The Quincy QT-54 (not the same quality as the Pro) is $1400 online with free shipping.
/ Opinions needed between these two #15
Local store here, small chain of stores, Runnings sells the Quincy brand compressors. I got the QT-54 on sale for less than $1400.
/ Opinions needed between these two #16
It works well enough and it's cheaper than buying a compressor with way more CFM than I'd ever use in my day-to-day repairs. For small stuff I could probably take it to a local small OEM and have them add it to their paint line, as long as I'm not picky about color.
/ Opinions needed between these two #17
ingersoll rand!
mine is over 35 years old and works as good as it did 35 years ago
/ Opinions needed between these two #19
I'm in the HF camp too, but mine are smaller. Little pancake one for remote site (filling tires, quick hit with an impact tool), then the 21 gal. 2.5 HP 125 PSI I use all the time. Keeps up with my blast cabinet so don't need any more than that. Loud as a train is only complaint.... For $150, I absolutely love it! - earplugs are cheap :)
/ Opinions needed between these two #20
Mine's the 5 hp 2 stage. 15.2 cfm @ 175 psi, 15.7 cfm @ 90 psi.
Got it on sale for just south of $1400
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2023 Global Trailer (A61568)
2023 Global...
DEUTZ MARATHON...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2020 ASV RT65 (A60462)
KUBOTA RTV 900 UTV (A62130)
KUBOTA RTV 900 UTV...
