Should I upgrade?
/ Should I upgrade? #1
tradosaurus
Super Member
Texarkana, TX
Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
I finally got to use my new L3301 w/bushhog and grapple.
I felt like it was underpowered when I needed to push over 3" trees. The bush-hog worked fine and I liked the small frame to get in and out of trees.
I'm wondering if I should look into to upgrading to the L4701? I would get a bit more weight (+600 lbs) and obviously more PTO hp.
I don't know if its possible given that I just signed a 5 yr 0% note on the L3301.
/ Should I upgrade? #2
That will depend entirely on your dealer being willing to work with you. The L4701 does not share the same frame as the L3301. It is larger in every dimension. If you feel the L3301 is light, then I suggest either an MX or a Grand L. If you feel it's underpowered, then I suggest a L3901.
/ Should I upgrade? #3
We had a L3800 HST and liked it a lot. We went up to a MX5800 HST to get more capacity, primarily with the FEL. With the L3800 we had no problem dealing with 3" trees, mowing with a 5' brushhog, 66" box blade, etc. Still, we are glad we have the MX5800. One significant (to us) difference is that we had R4 tires on the L3800, and as a result the rear wheels were fixed width--i.e., could not be adjusted for a wider stance. We put 4" spacers on each rear wheel and that greatly increased the stability. The rear wheels on the MX are adjustable. That and the fact that the MX is a larger, heavier tractor makes it not only more powerful but also more stable. I agree with the many posters in many TBN threads who have suggested resolving doubts in favor of getting a bigger tractor if you can afford it.
/ Should I upgrade? #4
So you want to TRADE UP for a new Tractor? - TMT - YouTube
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Heavier tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
More engine power will do nothing for you. In this application, tractor weight is everything.
My Kubota L3560, slightly physically larger than your L3301 but weighing 3,700 pounds bare tractor, is barely heavy enough to push over 3" hardwood trees. Kubota MX series is also around 3,700 pounds bare tractor but physically larger.
If you convert to an L3560 you can probably continue to use your existing implements. If you convert to an MX series you will need to consider buying an increment wider implements.
A Ratchet Rake bucket attachment grips trees where an unadorned bucket tends to slip.
A Bucket Spade bucket attachment is also useful.
Neither will meet your needs on an L3301. You need additional tractor weight.
In my opinion the L4701 is rather an orphan and future resale is likely to disappoint. Better to consider a mainstream MX, which are priced very close to L4701.
/ Should I upgrade? #5
I took out 3 non producing fruit trees last November with my 33 hp LS. It wouldn’t have much luck pulling them out by just using the bucket and fel.
I used the clamp on spade, similar to Jeff’s, to loosen up the root system first, then pulled them out nearly in tact with a chain. Barely needed to get off the tractor.
If you have the wherewithal to get a bigger tractor, that is one way to go, but finding workarounds is a lot cheaper, and at the same time, it was kinda fun to do.
/ Should I upgrade?
The MX sounds like the tractor I would need if I do upgrade.
I was considering the ratchet rake for the front bucket and might just go that route. The advantage of the L3301 is that it is small and the lower tractor weight means I'm less likely to get stuck in low areas that haven't dried out completely.
/ Should I upgrade? #7
Not necessarily. You need to compare the ground pressure of the various tractors. Just because something is heavy doesn't mean it is more or less likely to get stuck in grabby mud. Larger tractor=larger tires. I don't know the exact comparison between the L3301 and an MX, but I bet it's not that far off.
/ Should I upgrade? #8
^^^^^ X 2 ^^^^^​
/ Should I upgrade? #9
You're going to get burned if you do.
SDT
/ Should I upgrade? #10
VIDEO: So you want to TRADE UP for a new Tractor? - TMT - YouTube
In my opinion the L4701 is rather an orphan and future resale is likely to disappoint. Better to consider an MX, which are priced very close to L4701.
I agree. We carefully priced out the L4701 and the MX series. We opted for the MX because the cost of the upgrade was a relatively small percentage of what we would have spent for the L4701. Still, it is extra cost, so once again we TBNers are spending your money--although for what we think is good for you.
/ Should I upgrade? #11
I wasn't concerned with grabby mud, but part of our property has a small creek that floods with some regularity. When we only had our little lightweight Ford with R1's I couldn't mow for close to a week after the yard flooded without leaving tread patterns in the yard. Then we added a B7500 with R4's and didn't need to wait as long. The B7500 was replaced with an L3200 with R4's and the wait between flooding and mowing went down again. As we went with larger tractors, the tire contact area increased.
We were watching for another tractor with a little "more" and came upon a clean L4240 in December. It has factory A/C, more loader capacity, more HP for a larger RFM and other useful features. It has been fun in what little snow we've had this year. My one concern was how it will do on the lowland after flooding. I convinced myself that the big R4's on the L4240 had considerably larger ground contact than those on the L3200, so even with the extra weight it should work OK. Whether I lied to myself or not will be apparent after our first flood during mowing season:)
/ Should I upgrade? #12
Let me know how that works out for you. I'm looking into basically doing the same thing, transitioning to a L3560 from my L3301. The standard L line is a great tractor, but you know as well as I do how nice it would be to have a cab around these parts, and the extra stability from the added low-down weight can't hurt in these hills.
/ Should I upgrade? #13
Want more pulling power? Put chains on all four wheels, load up the bucket and put weight on the back.
Pulling with the three point would let you get lots of weight on the back balanced by a full bucket of the heaviest material you got. You have to be carefull to keep the rear hook up low with one foot on the clutch & the other one being really light on the HST forward pedal.
/ Should I upgrade? #14
Tell us how you were pushing over 3" trees. Not only is that potentially challenging or pointless to do with a tractor, it could easily cause damage. The front end loader is not a bulldozer, remember that. Same is true for larger/heavier/powerful tractors. And from my experience with the L models, you aren't going to be pushing much anyhow, since the tractor will run out of traction before it runs out of power in most cases, so being "underpowered" may not even be a factor.
I can knock over up to about a 6" pine with my L3200, which is about the same tractor as your L3301 but previous generation. I do not use engine power to do this, as that is not feasible (due to traction) and it could easily damage the front loader arms. It's all done with hydraulics. Raise the bucket to full height and angle/curl the bucket so that it's upper and lower edges are parallel with the tree. Now drive forward so that the bucket is just touching the tree but not applying pressure (use loader controls if you need to fine tune it and/or don't have the needed precision with the HST treadle). Once you are up against the tree, lower the bucket. The loader arms will move in an arc on the way down and "push" the tree over with hydraulic power, and be self limited by the hydraulic relief so that you can't damage anything. If you can't knock down a tree that way, then the tractor is too small for that particular tree. Obviously, don't use this technique if the top of the tree is rotten or has loose/hanging branches. This should only be done on trees that will not cause a hazard for the tractor/operator below.
If you had been driving up against the tree and pushing with only engine power, then it's the wrong way to do it for many reasons. Seeing as how I can knock over up to 6" pines (which have a long tap root to fight) I would conclude that you were using the wrong approach if you couldn't push over a 3" tree with essentially the same tractor.
/ Should I upgrade? #15
I was assuming he was backing over them with the bush hog. You may be right though.
/ Should I upgrade?
You guys need to remember that I've never driven a tractor until now. I'm getting on the job training.
My wife convinced me to keep the tractor.
I'm debating on whether to get a ratcheting rake or a Quick attach spade.
/ Should I upgrade? #17
Never used a quick attach spade. Done a lot of land clearing with a ratchet rake. It works well, though I thought you had a grapple? A properly used grapple will do a lot of what the ratchet rake can, in terms of clearing land. Ratchet rake is excellent for grading.
/ Should I upgrade? #18
I recommend the Ratchet Rake prior to Bucket Spade. No leverage.
Bucket Spade is very useful but better for an operator with 200 hours of experience. Bucket Spade applies considerable leverage. Imprudently used, it has the potential to damage the bucket. Wait on the Bucket Spade until you are familiar with norms of your L3301 operation.
(I have used Ratchet Rake and Bucket Spade on a Kubota 'B' B3300SU, as well as my current L3560. I have damaged neither but I am retired and never in a hurry on the tractor. In retirement life is an endless weekend.)
VIDEO: ratchet rake grading - YouTube
LINK: https://www.tractorbynet.com/forums/attachments/375397-ratchet-rake-today.html?highlight=
ARCHIVE LINK: www.tractorbynet.com&client=safari&rls=en&sa=X&ved=2ahUKEwjg19GDncvgAhUPDKwKHQ1SBrsQrQIoBDAAegQIBxAM&biw=1280&bih=644]RATCHET RAKE SITE:TRACTORBYNET.COM site:www.tractorbynet.com - Google Search[/url]
Yes.
/ Should I upgrade? #19
I have bought two RatchetRakes over the past 14 years. I was an early buyer when one could buy them direct from the factory, actually that was the only way to buy them. I've been their #1 supporter, recommender for many years and still do for landscaping. I finally bought a Pirinha for my bucket and sold my RR to my nephew. I'm more into woods work now vs home landscaping. The Pirinha will be better for the tree work since it doesn't have the dropping down section, just straight on sharp teeth which can dig at the back of the tree and can even dig a ditch/holer. The RR is better for landscaping though and I really missed it when I reseeded a small section of gravel drive turned into seeded yard but in the woods and for digging the Pirinha is king.
I bought a tree grabber/grapple type device a couple years ago and it's pretty good for grabbing 3" to some 4" trees and a couple of back and forths and the tree is out and I have it grabbed still standing and carry it to the burn pile. I got a bit aggressive with it and broke it but have now got it fixed and back to working. Titan works makes a similiar attachment for about half the price I paid for my tree grapple that has just one arm that moves and grips the tree between the one fixed arm and the moving arm. Search results for: 'tree remover'
/ Should I upgrade?
I thought about the Piranha bar but didn't want it permanently mounted. I might reconsider after reading your experience.
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2024 GD Yatian LY05A Model T Replica Electric Cart (A61569)
2024 GD Yatian...
2011 INTERNATIONAL DURASTAR 4X2 26FT BOX TRUCK (NON CDL) (A59908)
2011 INTERNATIONAL...
(2) UNUSED 9.5L-16 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED 9.5L-16...
2008 Genie S-60 (A61166)
2008 Genie S-60...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
