Backup Generator
/ Backup Generator #141
And Hino engines not available in NA, New Holland and all have manufacturer ID removed and have a Generac Engine # only. Many like the Hinos were models not sold in NA. They were the first to do this in the large gen market. Parts support for the large units was poor, items like water pumps for $4700 on a 5L diesel with 3 week delivery is not the norm for commercial emergency generators.
Not going to argue, just stating what I’ve seen over the past 25 years... They are the butt of all jokes in the business.
The point I was making however was that for most people these or any other cheap brand will serve the purpose and in the long run will give the most bang for the back.
/ Backup Generator #142
My 2 cents :2cents: on 1800rpm vs. 3600rpm:
As with most things electrical:
Although we rate electrical things in "Amps" or "Watts", their rating (or lifespan really) is really a function of Heat (temperature) & Time (exposed to that heat). Sort of like something made of fiberglass or plastic that does/doesn't get exposed to the sun.
Example: A transformer may be rated for 30kva with a expected lifespan of 30 years, but if you run it at 15 kva it may last 60 years, or if you run it at 50kva, it may last 5-10 years, or a few months (depending on ambient temps). Same with cables. Same as how (thermal) breakers operate. Same with generators.
Often a generator manufacturer will say (for example): "This model is a 125 kVA "Stand By" generator (used for temporary outages), and this model here is a 100KVA Prime Power generator, and this model here is a 80KW Continuous Power generator. And it's the same generator!
/ Backup Generator
The Kubota engine (D1005-BG) in the CMD generator set is rated in the Kubota spec sheet at 9.8/13.1 (kw/hp) standby and 8.7/11.7 continuous.
/ Backup Generator #144
Equipment life is directly related to load and especially temperature.
Typical large alternators have a 30,000hr insulation rating for class F insulation but that is at 80C. At 120C that will be down to 12,000 and at 200C it’s down to 1000hrs. You might think things don’t get that hot but remember where the windings are packed into the stator with no airflow, they actually do see these types of temperatures at 30C ambient and 100% load. That heat is drawn off and dissipated by the statue frame if the ambient temperature is within specs. Like not putting it in a box. These alternators are rated in temperature rise of 80, 100, 120C temperature rise meaning windings will be 80C or higher above ambient at full load.
Larger engines are generally rated in hp/hrs and major maintenance and overhaul events are largely based on fuel used. While it’s not ideal, diesel units use fuel in direct proportion to load and a lightly loaded unit will use about the same amount of fuel as a smaller unit with more load between about 20 and 80% of rating. If you control the ambient temperature so the intake temp and coolant temp are maintained a larger unit can run nights with light load with little issue. Running at higher load for an hour or two will clean it up again if necessary. Issues with wet stacking and carbon buildup result from hundreds of hours on light load or like I said low temperatures.
Gas units also use fuel in direct proportion to load but are a little less linear and it won’t hurt them at all to run lightly loaded for the number of hours a home owner would put on. Most people would never see the payback of multiple units trying to save a little fuel. Get something that you can afford and will run under 80% most of the time.
Having a second, small generator is handy however if your main unit fails or you need light and power to get it going or repair, carry it out back to run your tractor block heater etc.
/ Backup Generator #145
If someone is afraid to leave their tractor running, that's fine, don't do it... BUT that doesn't mean every one is...
My tractor runs at 1,900 at pto speed, is THAT, that much worse than 1,800?? I look at things like that BEFORE I buy a tractor, not complain about it later when I bought something I'm then afraid to use.
My tractor will power my whole house on less than one gallon an hour, yes that is a bit more fuel, but my tractor AND pto generator cost me less than a stationary diesel generator would have cost me, and I have a tractor to use when it's not generating!
SR
Im not afraid to use my tractor or leave it running. Its inconvenient as you must refuel, you must check fluids and using it as a generaotr ties it up for other things like snow removal. My Generac 16kw NG is a blessing, can be 20 below, power goes out and I never have to go out in the cold to set up or fuel.
But still a tractor is okay as a power backup station but not off grid. Unless thats all you need it for, I suppose if someone bought a diesel tractor and no implements from an auction just to use as a power station-that could be a great idea if the price was right. Lets say it didnt even drive but the PTO worked, could tie it in to a 55 gallon drum of diesel...thats an idea.Maybe even buy one of the old Army deuces, it has a PTO in front that way you can just run a generator and use K1, N2 or gas even-whatever available.
/ Backup Generator #150
/ Backup Generator #152
yea ok, but it doesn't explain how the isuzu is doing it with 3 cyl and is almost identical to the 9.8k kubota
/ Backup Generator #153
It’s not uncommon for those Kubotas to run 70-80,000 hours and 50,000 would be typical. Longest I’ve seen an Isuzu run is about 40,000 and 30,000 is typical (which is still pretty good). Either one would be excellent for home use but parts are a little easier to get for the Kubotas.
There are lots of both of these engines running continuously on mountain tops all over western Canada and they are both great engines. Kubota is more conservative in their ratings in favour of longevity.
/ Backup Generator #154
ok but can you explain the fuel usage?
/ Backup Generator #155
Bigger engine running one more piston and crank journal, bigger fan, possibly higher oil pressure will have some impact. Plus you are taking their numbers as gospel but it could be they used bare engine numbers gross on one and net on the other or engine hp/hr vs kwh from the alternator and we don’t know if all other factors were the same like fuel btu rating, elevation etc.
It’s not possible for two similar engines to be that different in efficiency so either take it with a grain of salt or ask for details of how they got their numbers. If you want to do like for like comparison get the engine model numbers and pull the manufacturers data sheets with the EPA ratings. They will have an accurate value for the bare engines using standardized defined test parameters.
/ Backup Generator #156
A little silly to worry or argue about longevity of a back up generator. I put about 40-80 hours a year on mine. Longest expected outage would be 100-150 hours. If one is good for 30,000 hrs and the better one goes for 50,000 hrs....who cares? If I live another 30 years, a 3000 hr unit will never wear out.
/ Backup Generator #157
At 80 hours a year, a 50,000 hour generator will yield you 625 years. Eat healthy and exercise :thumbsup:
/ Backup Generator
Picked up the generator at the Sacramento Fedex freight terminal today. That is not the pallet it was shipped on. The original pallet was broken into splinters and the cardboard wrapper was ripped apart. Amazingly not a scratch on the machine. Three Fedex warehouse guys spent 40 minutes getting the machine off the destroyed pallet and onto the new one so it could be loaded safely in the trailer. All is well that ends well.
This will have to live in my garage for a while, I have not started to build the enclosure yet. The steady rains seem to be over now so should be able to get going.
/ Backup Generator #160
Sweet, did it come with an exhaust ?
BTW I called CMD to get shipping cost to Detroit,, $488.00 so $500 for you not so bad.
2007 Mitsubishi Fuso FE84D 10ft. Box Truck (A66736)
2007 Mitsubishi...
Palfinger ILP 3300 3,300lb Truck-Under Lift Gate (A68183)
Palfinger ILP 3300...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
