Bead Blaster?
/ Bead Blaster? #1
Bedlam
I was wondering any ones opinion of preference for a bead blaster. I have a low budget LOL
Tire Bead Seater Tool | eBay
Seems to be 5 or 10 gallons. I wonder if anyone knows if the extra 10 gallons is worth it in operation? I also plan to add some fitting for use as a port air tank.
Also there is one that has two blast out ports in a circular fashion . wondering if anyone has this one or ideas
thanks..
here is the ten gallon one. (already is set up for port air)
1 gallon Air Tank combo Tire inflator Rim Bead seater Breaker Breaking Blaster 689744418564 | eBay
/ Bead Blaster? #2
had one for years, its a 5 gallon with the bead seating nozzle on the end, works decent for most applications, only issue is the larger truck tires on my one ton dump truck, the extra volume would help this tire size, the 5 gallon almost seats them but not quite.
I added a coupler so it can be used as a air tank, with 5 gallon it will inflate a tire to 35psi, saved a tow truck call a couple times, again a 10 gallon would hold double the air
/ Bead Blaster? #3
Sorry to suggest something portentially dangerous. But I just use starting fluid. I mean. how often do you need to do this? Any other method is hit and miss, and the starter fluid works every time. Plus, It's FUN!
/ Bead Blaster?
I have seen those videos on U Tube.. looks pretty exciting..Never tried it before..I had a small air tank but the valving in it is worn out and the replacement valve is close to the cost of a new unit so I figured that this would serve both needs. The previous poster seems to think the 5 gallon does well for seating the tire. so Im assuming that the 10 gallon is mostly mean to be used as both .. decisions decisions.. lol
/ Bead Blaster?
Just searched this. I see he has a special ''igniter LOL
/ Bead Blaster? #6
I have a 5 gallon unit,
on my 18.4-30 it took several tries to get the last one seated.
On a 20.4-42 it didn't do the trick, we fought that one for a few hours ended up
with a combination that got it, the bead blaster, a couple of ratchet straps around it
and a high flow clip on tire chuck, with the core in the stem removed.
The really fun part was it was flat again the next day,
broke it down installed a tube been working ever since.
We tried some starter fluid but it didn't have the umph to do it, just burnt.
/ Bead Blaster? #7
Starter fluid meaning Either. I keep several cans on hand although have never used it to start and engine. I get a eight foot stick with a small rag on the end soaked in diesel and use that as my igniter.
/ Bead Blaster? #8
Maybe you can still get good starting fluid (ether) in Canada most of what we get is pretty anemic stuff now days.
/ Bead Blaster?
Thanks.I presently have two trailer tires that arrived and both beads are against themselves. So I use some open ended wrenches to pry them apart and will let them sit for a few months. Sounds like the either method is a learning curve how much to put into the tire..
/ Bead Blaster? #10
It would help to have someone there to show you, It is difficult to convey.
DEUTZ MARATHON...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
Towable Light Tower (A60352)
Towable Light...
2017 CATERPILLAR 420F2 BACKHOE (A59823)
2017 CATERPILLAR...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
