Bead Blaster?
/ Bead Blaster? #1
Bedlam
Ford and Kiotie
I was wondering any ones opinion of preference for a bead blaster. I have a low budget LOL
Tire Bead Seater Tool | eBay
Seems to be 5 or 10 gallons. I wonder if anyone knows if the extra 10 gallons is worth it in operation? I also plan to add some fitting for use as a port air tank.
Also there is one that has two blast out ports in a circular fashion . wondering if anyone has this one or ideas
thanks..
here is the ten gallon one. (already is set up for port air)
1 gallon Air Tank combo Tire inflator Rim Bead seater Breaker Breaking Blaster 689744418564 | eBay
/ Bead Blaster? #2
had one for years, its a 5 gallon with the bead seating nozzle on the end, works decent for most applications, only issue is the larger truck tires on my one ton dump truck, the extra volume would help this tire size, the 5 gallon almost seats them but not quite.
I added a coupler so it can be used as a air tank, with 5 gallon it will inflate a tire to 35psi, saved a tow truck call a couple times, again a 10 gallon would hold double the air
/ Bead Blaster? #3
Sorry to suggest something portentially dangerous. But I just use starting fluid. I mean. how often do you need to do this? Any other method is hit and miss, and the starter fluid works every time. Plus, It's FUN!
/ Bead Blaster?
I have seen those videos on U Tube.. looks pretty exciting..Never tried it before..I had a small air tank but the valving in it is worn out and the replacement valve is close to the cost of a new unit so I figured that this would serve both needs. The previous poster seems to think the 5 gallon does well for seating the tire. so Im assuming that the 10 gallon is mostly mean to be used as both .. decisions decisions.. lol
/ Bead Blaster?
Just searched this. I see he has a special ''igniter LOL
/ Bead Blaster? #6
I have a 5 gallon unit,
on my 18.4-30 it took several tries to get the last one seated.
On a 20.4-42 it didn't do the trick, we fought that one for a few hours ended up
with a combination that got it, the bead blaster, a couple of ratchet straps around it
and a high flow clip on tire chuck, with the core in the stem removed.
The really fun part was it was flat again the next day,
broke it down installed a tube been working ever since.
We tried some starter fluid but it didn't have the umph to do it, just burnt.
/ Bead Blaster? #7
Starter fluid meaning Either. I keep several cans on hand although have never used it to start and engine. I get a eight foot stick with a small rag on the end soaked in diesel and use that as my igniter.
/ Bead Blaster? #8
Maybe you can still get good starting fluid (ether) in Canada most of what we get is pretty anemic stuff now days.
/ Bead Blaster?
Thanks.I presently have two trailer tires that arrived and both beads are against themselves. So I use some open ended wrenches to pry them apart and will let them sit for a few months. Sounds like the either method is a learning curve how much to put into the tire..
/ Bead Blaster? #10
It would help to have someone there to show you, It is difficult to convey.
/ Bead Blaster? #11
I used to be big into rock crawling. I ran 38-14.50's and always had the pressures very low for the best grip. I didn't have the cash for bead locks, so I just kept a can of starting fluid in my spare parts box alongside my spare axle shafts, u-joints, and tie rod ends. The nice thing about using starting fluid was that ya didn't even have to take the wheel off the truck to reseat the bead, and only rarely had to jack the wheel off the ground.
It didn't take much. Usually spray into the entire circumference of the tire cavity as quickly as you can. Once you have made it all the way around back to where you started, spray a "tail" or fuse from the bead out to the tread of the tire so that when you light it your hand isn't near the bead. You will want to light it pretty quickly after spraying...within a few seconds. Works like a charm on truck tires, but honestly I have never tried it on a large tractor tire.
/ Bead Blaster? #12
I expect I'm going to be trying this soon. I have a pair of rear tires ordered for my 4310 and the pic looks like the beads are practically touching each other unmounted. Not wanting to put spreaders in and let them sit long enough for them to relax the other way.
/ Bead Blaster? #13
I bought the $100 5 gal from HF. Nice unit but added some air valves and fittings to be used with it. Haven't used it but a couple of times on 8" lawnmower tires. Not really setup for that.....use on larger tires. Also there is a learning curve and a helper to hold the tire, or a tire changer that will hold it still helps too. Buttttt in time it will become a great asset.
I have used Ether on several occasions in the past.....works but scared me every time I used it.....use too much and BOOM.
/ Bead Blaster? #14
My only is advice is to sneak up on the amount of ether you need. Don't see how much ether you can use on the first try. :thumbsup:
/ Bead Blaster? #15
Guess im just old school
I use a ratchet strap all the way around the middle of the tread.
Most of the time thats all it needs. Sometimes a little help with a big hammer on the sidewall seats the bead.
/ Bead Blaster? #16
That's what I usually use on 8-12" rim, fat tires, and sometimes a pair with the ratchets on opposite sides and the hammer. I think the blaster is easier on larger diameter wheels.
/ Bead Blaster? #17
I've done it it with perfect results on ATV tires. They will come shipped flat/strapped together and no amount of ratchet straps etc worked.
Laid it out in the yard 3 squirts and boom, on the bead.
If you do try this method, I highly recommend you REMOVE the STEM from the valve first so there is an exit path for pressure in case you use too much ether.
/ Bead Blaster? #18
I really doubt that would make much difference considering the volume of gas in the combustion, the steepness of the explosion front, and the size of the exit hole, but it makes you feel good....grin.
/ Bead Blaster? #19
Using ether or wd-40 is a very dangerous way to mount tires and it has caused fatalities in the past.
This jd mule has drop center wheels and unless you have a large number of tires tools to use it
will be better for you to hire a farm tire installer to do it as they will have a hydraulic bead
breaker and the tire irons need to dismount the tires quickly and more efficiently than you
could do by yourself.
I mounted tires of all types and sizes up to 18.00-25 mining tires with 32 ply for a living and
I will tell you that it takes a lot to mount them and dismount them. and paying a farm tire
distributor to dismount the old tires and mount the new ones on the machine will be much
more cost effective for you as they will have all the tools needed to accomplish this in one morning.
It will be much easier to just hire a farm tire distributor to take care of this for you and I can tell
you from personal experience that it will cost you less money and you will have the tractor back
the same day to use it as changing tires with few tools will turn into a long drawn out process and
you will damage the tire beads and or the rims.
Tree Boom Skid Steer Attachment (A61572)
Tree Boom Skid...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
Unverferth 1225 Rolling Harrow (A63116)
Unverferth 1225...
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
Hydraulic Auger Bits (A61572)
Hydraulic Auger...
