Portable Air Compressor
/ Portable Air Compressor #1
wcampbell47
Texas Coast
ASV RT75 HD track loader
I hauled a portable gas powered air compressor in the back of my truck for a long time to meet the need of airing up a low trailer tire and/or changing a flat with an air wrench. I replaced the compressor, air wrench and air hose with the following.
VIAIR portable 12 volt air compressor. 4P-Automatic Portable Compressor | VIAIR. So far has served me well and aired up low tires on already loaded trailer. 70 psi no problem. Works on tractor tires as well.
Switched to a battery powered wrench as well.
If you pull trailers often you know you run across under inflated tires frequently. This helps in a pinch.
/ Portable Air Compressor #2
Thanks for sharing. :thumbsup:
/ Portable Air Compressor #3
VIAIR makes great compressors. I've had the 450-RV model for two years now and it does an amazing job. 100% duty cycle and can be run 40 minutes before resting. I bought it because when towing I like to keep tires aired up to spec and that little thing has never let me down. A lot more money than most of the China made compressors available right now, but the way it's made I imagine it'll still be airing up tires long after I'm gone.
/ Portable Air Compressor #4
Interesting. How much does it cost?
/ Portable Air Compressor #5
My wife recently purchased a new car.
No spare but a can of 'fix a flat' and a portable compressor.
Fortunately there was also a card for roadside assistance, (never used to date).
I have her compressor!
Vermeer SC30TX Smart Sweep Stump Grinder (A62679)
Vermeer SC30TX...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59914)
2007 TRAILMOBILE...
F-250 Super Duty 4WD 6.2 (A63689)
F-250 Super Duty...
