Todays shop time.
/ Todays shop time. #761
I ran across a 46" square piece of 1" thick aluminum that I bolted to the top of two of the HF Titan work benches. Thought that it would be a decent surface for tacking up fab projects. I plan on drilling and tapping holes in the aluminum for fixtures and bench top tools. Will add some shelves between the two cabinets and fixing a 4x4 electrical box extension cord to the side somewhere. The vise is held down with 4-3/8" bolts threaded into the plate.
That is a cool surface. Nice find and repurpose!
/ Todays shop time. #762
4570man--Do you have a business and sell bowls commercially or just a fun thing?
/ Todays shop time.
I sell a few cutting boards and take a few other commissioned builds but the wood turning and woodworking as a whole is only a hobby.
/ Todays shop time. #764
nicely done. Let us know over time how durable the surface is. What do you have to do to maintain that finish?
That is one big chunk of aluminum. Very impressive. Is there a grade number for that aluminum, an alloy of some kind or
pure aluminum? Aluminum can be soft or extremely hard. Guessing you have the latter.
/ Todays shop time.
I finished building a wood stove I started over a year ago. IMG_1228.JPGIMG_1229.JPG
/ Todays shop time.
No my woodlot is in the city limits and they don’t take kindly to burning debris in an open fire. When I started the project a year ago I intended on converting the wood splitter to electric and moving it inside but I doubt I’ll do that now, so it’ll just be used to burn splinters and warm up by.
/ Todays shop time.
It’s 3/8 thick but I hope not.
/ Todays shop time.
I was cutting some strips for a table top and hit 2 different bullets in the woods. Luckily the soft lead didn’t hurt the blade/knifes. And this was the trial run of my new to me Oneida cyclone dust collector. Here’s how the filter looked after sucking three 30 gallon barrels of chips. I’ll be interested to see what happens with it and the drum sander but so far I’m impressed. IMG_1301.JPGIMG_1302.JPG
/ Todays shop time. #771
Beautiful wood! Ambrosia Maple?
/ Todays shop time.
Yes. It all came from a tree on a flip house I had a couple years ago. Here’s 2 other tops I made from it. The second table is a makeup table I gave my sister for Christmas. IMG_1270.JPGIMG_1306.JPG
/ Todays shop time. #773
Very nice! Have you turned any bowls and vases from it also? The complexity of the pattern is especially enhanced by the curves. :thumbsup:
/ Todays shop time.
No I sawed the whole trunk log and there was no figure in the top of the tree. It went to firewood. The best figure is at the bottom of the tree. Here’s some bowls I turned for a smaller trees that had even more color. And again there was only about 8’ that was nice with the bottom 4’ being a lot nicer.IMG_0964.JPGIMG_0931.JPG
/ Todays shop time. #775
No I sawed the whole trunk log and there was no figure in the top of the tree. It went to firewood. The best figure is at the bottom of the tree. Here’s some bowls I turned for a smaller trees that had even more color. And again there was only about 8’ that was nice with the bottom 4’ being a lot nicer.View attachment 588843View attachment 588844
It is spalted as well? That's a neat looking figure.
Good workmanship.
/ Todays shop time.
Good workmanship.
Maybe a little. There’s a very fine line between spalted maple and worm food. Sure if you were dedicated you could epoxy soak it and use some of the overly spalted stuff but I’ve never went through that expense and trouble. Here’s a piece that’s got quite a bit of spalting but I haven’t done anything with it yet.IMG_1312.JPG
/ Todays shop time. #777
Some of you may have seen a few of these pics in my “Hooker-Bender-Weekend” thread.
Problem:
Solution:
Moving Day:
Result:
/ Todays shop time. #779
Thanks, Mark!
/ Todays shop time. #780
I'd love to do that in my barn but I'd need another barn first!
Looks awesome, nice job.
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
(6) SHANK RIPPER BEDDER W/AUTOMATIC SHANK TRIP (A64280)
(6) SHANK RIPPER...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61574)
2014 Crossroads RV...
2025 Forks and Frame Mini Skid Steer Attachment (A61572)
2025 Forks and...
