Todays shop time.
/ Todays shop time.
And for something actually related to the thread, I put door pins and bushings in my truck. For the minimal investment and effort this was I should have fixed it a long time ago. It closes like it’s supposed to now. IMG_1013.JPG
/ Todays shop time. #742
It is amazing how long I can live with something that slowly gets worse like your door hinges. Then like you said-why did I wait so long. Did you make the pins and bushings or find what you needed available ??
gg
/ Todays shop time.
gg
The pins were in good shape so I really didn’t need those. I could have made the bushings but it was $12 for a 4 bushing and 2 pin set so cheaper to buy. The roller pin that’s supposed to hold the door in position when opened was also busted. That pin was $13. And my heater motor only runs on low speed and not very good at that. I’ve had a new one rolling around in the seat for months that I haven’t bothered installing. And I’ve had a set of mud flaps for months that I haven’t bothered installing either.
/ Todays shop time. #744
You're making me feel like I am normal. Thank you.
gg
/ Todays shop time. #745
I decided to “mobilize” this side cabinet I’m planning on using for housing drill bits/annular cutters. While I was at it I incorporated an adjustable roller work support for my drill presses.
/ Todays shop time. #746
Cool idea Terry :thumbsup: ; sooo, would that be a "Cutting Edge Rolling Roller Cabinet" ? Just curious, couldn't think of a fun acronym (yet) :D ...Steve
/ Todays shop time. #748
I decided to �obilize this side cabinet I知 planning on using for housing drill bits/annular cutters. While I was at it I incorporated an adjustable roller work support for my drill presses.
Nice... but! I have a couple metal cabinets that I made plywood dollies w/casters a few years ago. They are just begging for a custom metal frame dolly. For some reason the wood base bugs me. On my list of projects to grab some scrap 1/2 or 3/4in angle and make a base frame for them. But now I seen yours, I don't feel as bad. :D
/ Todays shop time. #749
I cheaped out, Mark. The wooden moving platform was on sale for less than the price of the four swivel casters. I just cut it to size and bolted the cabinet down.
/ Todays shop time. #750
Big Barn, is that cherry wainscoting in your shop? Now you've really gone over the top. :laughing:
. Nope just fire engine red paint for the trim and slatwall.
/ Todays shop time.
I welded some bucket teeth on my backhoe and than pushed up a brush pile to test them. The teeth were a game changer to push brush. IMG_1064.JPGIMG_1065.JPG
/ Todays shop time. #753
I was thinking a manly gunmetal finish. :laughing: Or good old battleship gray, like I used on the HF dolly that the cabinet with the vacuum pump for my lathes rolls around on. :)
/ Todays shop time.
Aside from the obvious benefits I’ve also found the teeth to be a useful depth gauge with spreading loose material over a firmer one.
/ Todays shop time. #756
That makes sense!
/ Todays shop time. #757
This morning I moved my dry cut saw bench into its new resting spot. Efficiency and saving time seems to a common trait among us old retired guys.
Must be due to that “ hurry up and die” attitude.
/ Todays shop time. #759
Thank you but no, I am strictly NON profit but not by choice
/ Todays shop time. #760
I ran across a 46" square piece of 1" thick aluminum that I bolted to the top of two of the HF Titan work benches. Thought that it would be a decent surface for tacking up fab projects. I plan on drilling and tapping holes in the aluminum for fixtures and bench top tools. Will add some shelves between the two cabinets and fixing a 4x4 electrical box extension cord to the side somewhere. The vise is held down with 4-3/8" bolts threaded into the plate.
(2) UNUSED 23X8.50-16 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2019 CATERPILLAR CUV82 UTV (A64280)
2019 CATERPILLAR...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2014 Ford F-150 Pickup Truck (A61573)
2014 Ford F-150...
