4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,207
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
It is amazing how long I can live with something that slowly gets worse like your door hinges. Then like you said-why did I wait so long. Did you make the pins and bushings or find what you needed available ??
gg
The pins were in good shape so I really didn’t need those. I could have made the bushings but it was $12 for a 4 bushing and 2 pin set so cheaper to buy. The roller pin that’s supposed to hold the door in position when opened was also busted. That pin was $13. And my heater motor only runs on low speed and not very good at that. I’ve had a new one rolling around in the seat for months that I haven’t bothered installing. And I’ve had a set of mud flaps for months that I haven’t bothered installing either.
Nice... but! I have a couple metal cabinets that I made plywood dollies w/casters a few years ago. They are just begging for a custom metal frame dolly. For some reason the wood base bugs me. On my list of projects to grab some scrap 1/2 or 3/4in angle and make a base frame for them. But now I seen yours, I don't feel as bad.I decided to �obilize this side cabinet I知 planning on using for housing drill bits/annular cutters. While I was at it I incorporated an adjustable roller work support for my drill presses.
Nice... but! I have a couple metal cabinets that I made plywood dollies w/casters a few years ago. They are just begging for a custom metal frame dolly. For some reason the wood base bugs me. On my list of projects to grab some scrap 1/2 or 3/4in angle and make a base frame for them. But now I seen yours, I don't feel as bad.![]()
I welded some bucket teeth on my backhoe and than pushed up a brush pile to test them. The teeth were a game changer to push brush. View attachment 585636View attachment 585637
. Nope just fire engine red paint for the trim and slatwall.
I The teeth were a game changer to push brush. View attachment 585636View attachment 585637
Aside from the obvious benefits I’ve also found the teeth to be a useful depth gauge with spreading loose material over a firmer one.
This morning I moved my dry cut saw bench into its new resting spot. Efficiency and saving time seems to a common trait among us old retired guys.
Must be due to that “ hurry up and die” attitude.
