TMGT
Elite Member
Picked up a large drill press the other day, wasnt really looking for another one but this one showed up on Craigslist cheap and nearby so I figured it was worth looking at.
The ad had a couple pictures but not much info, could it really tell what make/model but it looked to be a decent size.
Turned out to be an older Enco branded Taiwanese unit bit its built pretty well, it's a 27.5" swing, power feed and 5hp. It's quite the beast, but needs a repair in the table to column mount casting.
Apparently the collar was put on upside down from the beginning and eventually cracked, nothing major. I have it appart and will be repairing it once I get it cleaned up.
Torn between using 55ni rod or brazing, I think once the collar is flipped over it qont be putting as much stress on the joint so hopefully it shouldn't break again.
Couple pictures of the press when I brought it home and the cracked area.
