Grapple What's needed for a grapple?
/ What's needed for a grapple? #1
eubie5
Gold Member
Greenville Indiana (southern Indiana)
kubota bx2380
Self explanatory-will be buying a scut within the next 6 months with a fel. Really falling in love with the idea of also buying a small grapple with it.
My questions is-when you swap out the bucket with the grapple, are the existing hydraulic connections not enough? Is that what the "3rd function" is for? I guess, the tractor hydraulics do the lifting and curling, but 3rd function is to open and close the jaws?
One of the tractors I'm looking at is the RK24, which comes with a set of rear remotes. Could you run lines from the grapple to the back and use the rear remotes?
Sorry if these are stupid questions. I've had a bx1800 for 15 years, but I've never had a fel.
REALLY looking forward to an upgrade as soon as i pay off the wife's car.
Thanks in advance for any answers.
Sorry, forgot another question. What are some of the better grapples for the subcompact?
I know being a sub, the lifting capacity comes into play, so the grapple can't be too heavy, or that eats up alot of the tractors lifting abilities.
Thanks
/ What's needed for a grapple? #3
Existing hydraulics are not enough. You need a method of running a 3rd function.
Yes, 3rd function is for opening/closing grapple.
Yes you can run grapple off rear remote. Not very handy because of location of lever. But doable.
Cheapest method is to use rear remote.
Next cheapest is diverter valve. This diverts the curl function to 3rd function by depressing an electrical pushbutton.
Most expensive is true 3rd function. Electric over hydraulic valve is installed. Two buttons on the joystick handle. Open to open, one to close grapple.
/ What's needed for a grapple? #4
Thanks
Cheapest and least heavy is to add a grapple to your existing bucket. Google search for suppliers.
/ What's needed for a grapple? #5
If you are looking at new RK tractors just have them add the grapple and 3rd function in the deal.
/ What's needed for a grapple? #7
Here is the way they work.
If you get a FEL (ie Front End Loader) it will come plumbed with 2 sets of hydraulic lines. 1 set is for lifting and lowering the FEL arms. 1 set is for curling whatever is attached to the FEL in and out. Usually this is a bucket attached to a SSQA mount.
So if you get a grapple, you will want a 3rd set to open and close the grapple. I do recommend SSQA if it doesnt put your lift capacity below a # you are trying to reach.
I also concur, have the 3rd function added by the dealer if possible.
Additionally, if possible get true 3rd function. Some configurations use a diverter, so you hit a switch to divert flow from say the bucket curling to the grapple. This of course means you cant use bucket curl and grapple functions at the same time. Not ideal, but not impossible to live with either. The worst in my opinion is using a rear remote valve for the 3rd function and NOT actuating it with a switch on the loader control. You have to take your hand off the loader control joystick, move the remote valve lever forward or back to actuate grapple, then move hand back to joystick. Try and get true 3rd function if you plan on using the grapple a bunch.
/ What's needed for a grapple? #9
I use the rear remote lever. BUT, I extended its length, and it is so strategical placed in front of the joystick, I can actually operate with my fingers while operating the joystick with my hand. Not many tractors are built like this, Most will have the rear remote lever somewhere behind the joystick lever, usually by your rear hip. So, not so convenient. In fact, probably not convenient at all. But it is cheap. A true third function would be best if you can afford it. And if you can have the dealer set it up before delivery, Well, that would be nice. :) I did it all myself, and I am very satisfied with the way my setup turned out. But it probably would not be the best for most tractors.
/ What's needed for a grapple? #11
I understand that, just wanted to know exactly what a 3rd function was and what it's used for with the grapple.
Yes the third function is to open and close the grapple clamp.
In the absence of a true third spool some people install a diverter valve that shifts the hydraulics used for the bucket curl to close and open the grapple clamp. Not sure why you would need to perform both functions at the same time but some folks seem to think the diverter valve is a limitation. My understanding is the RK thrid function is a true third spool when ordered through them but make sure when you order if that concerns you.
I will be outfitting my JD4310 with a grapple next year. It has an unused third spool but I will most likely install a diverter valve and save the third spool to use for a hydraulic top link. I think a button on the loader knob will be more convenient than another lever and I don't see any reason to use the clamp and curl simultaneously.
Some factory setups will have a twist function on the loader control for 4in1 buckets or grapples. Not sure how the RK system works but that would probably be the most convenient way to operate a third spool valve.
/ What's needed for a grapple? #12
Keep in mind that especially with a smaller SCUT the the total flow of fluid will be low as say compared to a 40 HP CUT. What I am saying is even if you have a "true" 3rd function electric over hydraulic valve installed, you likely will not have enough flow from the power beyond port on the loader to operate if if you are using the curl function on the loader valve. The loader valve will be "upstream" of the 3rd function valve, and will likely use most if not all of the flow from the hydraulic pump. My point is a diverter valve installation will likely result in about the same operation in reality as the 3rd function. Neither likely to curl and clamp at the same time.
/ What's needed for a grapple? #13
And whether the clamp function of a grapple jaw must operate at the same time as the curl function is somewhat a moot point for a homeowner. Yeah I can see it on a skilled operator on a bobcat, sure, but a homeowner typically does not "need" to operate both functions at once. I typically open the jaws before I approach say a pile of brush.
Now I drive up and curl down, coming down on the pile and crushing it down as much as I can to pack the jaws, full of material, THEN close the jaws. At this point I am not actually using fluid "upstream" in the loader valve so the fluid flow is passing out the power beyond port on its way to "downstream" valves and on to the three point lift and into the tank.
After the jaws are closed, I will lift and curl the wad and move on the drop point. Some would argue that second to close the jaws is lost operation time, and I guess so, if you are making money with your machine, but if you are cleaning up your yard, it is no big deal. My rear remote stick is very convenient to operate with my joystick hand, and is adequate for me.
/ What's needed for a grapple? #15
^^^ exactly how I do it.
/ What's needed for a grapple? #16
I use all 3 functions together every time I use my Grapple. But, as James mentioned, gpm flow comes into play. I have enough flow to power all three at once.
/ What's needed for a grapple? #17
Yeah, but you have a "big boy" tractor. Many little SCUTS are doing good just to operate the lift cylinders, most won't run lift and curl at the same time.
/ What's needed for a grapple? #18
my 60 HP won't lift and curl at the same time. Maybe because it is a self leveling loader?
/ What's needed for a grapple? #19
Yep. Even my Kubota L4400 struggled with that.
/ What's needed for a grapple? #20
I believe it's in the valving. Not an expert at all but that's what I've understood from other hydraulic discussions here on TBN.
2018 HINO 268 4X2 S/A 26FT BOX TRUCK (A69167)
2018 HINO 268 4X2...
2011 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2011 INTERNATIONAL...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
Gem 500/200 Gal Herb Tank On Trailer (A64911)
Gem 500/200 Gal...
