3-Point Hitch Converting cat 1 to cat 2....box grader
/ Converting cat 1 to cat 2....box grader #1
inode
Tennessee
Kubota M7060HD12
Can I set this cat 1 box grader up to work with a cat 2 quick hitch? I’ll be using it with my Kubota M7060.
/ Converting cat 1 to cat 2....box grader #2
Not likely. Further, the 7060 is capable of turning that box blade into scrap before you can get your foot on the clutch.
/ Converting cat 1 to cat 2....box grader #4
I agree with RickB, way to small and light duty to be using behind an M7060. Save yourself the hassle and frustration and get a unit that belongs behind a tractor of that size and capabilities. ;)
/ Converting cat 1 to cat 2....box grader #5
If the width is right just slide on bushing over the cat 1 pins and be happy, you won't tear it up but probably not wide enough
/ Converting cat 1 to cat 2....box grader #7
A couple of my Cat II implements are narrower than my rear tire width. Doesn't bother the operation, one bit, in my opinion. However, and a BIG, however - unless you are exceedingly careful - Rick B's post #2 WILL happen. Do yourself a favor and get a CatII box blade. You are NOT saving money getting a CatI implement.
/ Converting cat 1 to cat 2....box grader #8
I have an Cat 1 box blade that came with my old L4630. I bushed for use with my M6040 and have had no issues with it.
Of course, I mostly use it for snow removal which is pretty light use.
The minimal amount of earth moving I do won't ever damage it.
/ Converting cat 1 to cat 2....box grader #9
The Cat II quick hitch is the real show stopper here. Of course if the OP has torches and a welder anything is possible.
/ Converting cat 1 to cat 2....box grader #10
Inode, it appears you already own the box blade. Yes, a higher HP tractor could cause it to bend, however, if you watch what you're doing and go slow you can easily determine what will damage it before it happens. Spend $10 and buy a couple of bushing for the 3pt pins and one for the top link and see how it does. CountyLine Category 2 to 1 Lift Arm Bushing at Tractor Supply Co.
/ Converting cat 1 to cat 2....box grader #11
Yes, fruitcakes, my Land Pride RB 3596 was class I. It was FANTASTIC for snow removal on my driveway. However - after spring rains and my driveway sets up as concrete - a totally different story. Realistically, it was not even heavy enough to become damaged. Great sparkler light show in the evening - that's about all it was good for.
So - in that rare, almost non-existent event in this part of the world - a used implement of homeowner size was sold. It went so FAST - the first caller off Craig's list offered $50 over asking price if I would hold it for him. He was there within an hour - it sold for $50 over asking price.
I now have a ClassII rear blade. Rhino 950 - 96" & 1100 pounds. It cost a bloody fortune, new, but will do summer maintenance on my mile long gravel driveway. My tractor - 2009-Kubota M6040 @ 10,100 pound with grapple and rear blade attached.
The box blade was given to me. I thought I’d use it before purchasing a class II. The blade is 5.5’ and my m7060’s rear tires sit at 6’ in width. In moving it around, I’d guess it weighs 500-600 lbs. I had been looking at a Land Pride BB3584.
/ Converting cat 1 to cat 2....box grader #13
Unless you are going to do a lot of grading it will do fine
/ Converting cat 1 to cat 2....box grader #14
Take it easy, keep throttle down, and what you have will work fine. Just take your time. Enjoy. Merry Christmas
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2015 Ford F-550 Utility/ Plumbing Truck, VIN # 1FDUF5GYXFED42880 (A65563)
2015 Ford F-550...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
L6060 Kubota For Sale
