Snow "Soft" edge for snow removal?
/ "Soft" edge for snow removal? #1
Jabroni
Central MA
Kubota BX24
As a new BX24 owner, and coming from a typical lawn tractor, I'm completely unfamiliar with what's available as far as accessories. What I was wondering is if there's a soft edge available that attaches to the loader bucket that would easier on the driveway. I was thinking of something like tire tread material. Anything like that?
/ "Soft" edge for snow removal? #2
There was a post a while back..(two years, I reckon) which described how a guy used horse matting (for the stall floor) cut in a strip and bolted to his blade.
It was pretty tough and pretty cheap!
/ "Soft" edge for snow removal? #3
I used 1/2" strips of UHMW Polyethylene bolted to my loader bucket, rear blade and snowblower. Ordered them from McMaster-Carr. Didn't see much wear and no marks on over 350 feet of concrete driveway last winter. The loader bucket has a bolt on cutting edge I replaced with the plastic. It's almost July; you thinking ahead or is it winter there?
/ "Soft" edge for snow removal? #4
I looked at my bucket last night and can't say I saw any noticeable wear from this season. Allot of it has to do with the surface you are clearing and your angle of attack. This past winter we had ice that I would not have been able to get up without the cutting edge.
Jdengr said:
..... It's almost July; you thinking ahead or is it winter there?
:D It's been cold up here but not that cold! Just thinking ahead. It'll be here before you know it.
/ "Soft" edge for snow removal? #6
Plow rubber from Rubbercal - some angle iron and some welding...
/ "Soft" edge for snow removal? #7
Jabroni,
I made this cheap and simple snow pusher. The wood doesn't damage the surface and when the wood wears down I just reverse it, then replace it. I do quite a few drives and there is actually little wear.
Use that float feature.
Wow, both clever ideas! Nice job. I've got plenty of time to work on one too. Thanks!
BTW, my dealer told me last week that Curtis is about to announce a plow blade for the BX24 that will attach to the FEL. Detach the bucket, and the plow will fit right in.
/ "Soft" edge for snow removal? #9
I don't like it cause which ever one i needed the other one would probably be on the loader arms.
I like my both always ready to go system way better.
FEL on BX23
Front Blade on BX1500
/ "Soft" edge for snow removal? #10
Jabroni,
I like the snowpusher made of wood. I'll try to make one for the next snow. I was able to deal with 24" the past weekend with only a FEL and rear blade. A similar snowpusher would have helped a lot. I'll try to remove the toothbar and use the same holes as attachment points.
Great design.
/ "Soft" edge for snow removal? #11
I had to wait almost 3 years but finally got the chance to try the rear blade with a piece of TSC stall mat attached.
It definitely moves far less gravel, though time will tell how long it lasts. But then again, I’ve got enough left over for many more pieces.
/ "Soft" edge for snow removal? #12
I bought a Frontier (Deere) front blade that mounts to the loader (QA bucket comes off, blade goes on. It works well if the snow is cleared before it freezes...after freezing, the blade trips pretty frequently.
There's a rubber strip (about an inch and a quarter thick) that replaces the steel cutting edge...does a good job and doesn't tear up the asphalt
/ "Soft" edge for snow removal? #14
View attachment 582483View attachment 582484
thanks will be going to TSC to get the stall mat for my 6.5 meyer plow.
42 bucks:thumbsup:
/ "Soft" edge for snow removal? #16
Below is what I have :
urethanestore.com
Snow Plow Blades - Holes Not Included
Thickness x Width: 1"x6"
Length: 60"
Sandwiched it between the cutting edge and the plow like psvines pic on my Bx2763.
Works amazing.
/ "Soft" edge for snow removal? #17
Posts 11 thru 16 -- those are great answers to a common problem all of us have when scraping driveways (paved or stone) with our tractors.
I added wide strips of hard poly to the underside of my bucket used for clearing driveways (do not have a blade in use for that purpose...) I bolted the strips on using carriage bolts imbedding the round bolt heads in the material. Not perfect but works fairly well. The TSC stall mat material has to be a great find for this kind of application.
I'm wondering if that might work on the scraping/cutting edge of the snowblower too ?
/ "Soft" edge for snow removal? #18
Generally you can angle a snowblower up so the cutting edge isnt hitting the ground & it floats on a bit of snow. The geometry of a blower cutting edge is pretty parallel to the ground. On a blade the cutting edge is pretty perpendicular to the ground.
/ "Soft" edge for snow removal? #19
True, good points. And over the years I have found that the angle of the snow blower (best being very slightly upward rather than digging in) is THE major factor.
/ "Soft" edge for snow removal? #20
urethanestore.com
Length: 60"
Works amazing.
FORD DIRT SCOOP (A62131)
FORD DIRT SCOOP...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
2842 (A62131)
2842 (A62131)
25026SFL (A61569)
25026SFL (A61569)
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
24in pin on excavator tooth bucket (A61307)
24in pin on...
