LEADED vs UNLEADED
/ LEADED vs UNLEADED #61
Leaded gas was phased out starting in 1975 and was illegal to use except for low lead aviation fuel only used in airplanes since 1996. If some people like the fire department in Fried1765’s district chose to flaunt the law that was enacted due to health hazards due to lead in the atmosphere that is up to them. Obviously they have no concern for the law or the health of the people in their community.
Sure..... I understand!
Fire departments generally ..."have no concern for the law or the health of the people in their community"
Makes me wonder why with "no concern" they (the fire departments) also run the ambulances.
So confusing!
/ LEADED vs UNLEADED #62
According to Mother Jones and the EPA, leaded avgas is to be phased out by 2019.
They have been promising to do that for decades. The can just keeps getting kicked down the road.
100LL is really only 96 octane, if you use the automotive standard of R+M/2, to determine octane.
Most piston aircraft are low compression, so they don't even need that kind of octane. They can easily run on regular octane unleaded.
There are also 96 octane unleaded fuels available, for the engines that need it.
A ton of testing has been done. And a lot of aircraft are already running unleaded.
But apparently, no one in the government is willing to finally make the call.
/ LEADED vs UNLEADED #63
Are the miles shorter in 2018 than they were in the 1970痴 ? Something like how telephone books use smaller print in 2018 than they did on the 1970痴 .
That's got to be it; it couldn't have anything to do with cars being built better than they were 40 years ago.
/ LEADED vs UNLEADED #64
Maybe, maybe not...
My engine engineer said the single biggest impact to longevity has been the evolution of motor oil and lubricants in general... the specs met today are very impressive and beyond imagination not all that long ago...
Not to add fuel to the fire... he was only stating the single across the board significant change...
/ LEADED vs UNLEADED #65
I believe the changes in ignition started the increase in gasoline engine life, the fuel injection system on gasoline cars was the major leap foreword in engine longevity, better faster easier starts, less raw gasoline washing down cylinder walls and diluting oil. :2cents:
/ LEADED vs UNLEADED #66
The rich mixture setting for takeoff is what counts . 100LL is actually 100/130 octane .
/ LEADED vs UNLEADED #67
Depends on your state but yes, itç—´ definitely illegal and you should be eligible to a portion of the $10,000 fine for turning them in.
Tetra Ethyl lead is bad for humans for sure.
The Lead in gasoline story was featured on the newer Cosmos series (A Grave threat) in short story form
Clair Patterson ( The Most Important Scientist You've Never Heard Of)
long read
The Most Important Scientist You’ve Never Heard Of | Mental Floss
An eye opener for sure
/ LEADED vs UNLEADED #71
From here:
Avgas - Wikipedia
"100/130 avgas has an octane rating of 100 at the lean settings usually used for cruising and 130 at the rich settings used for take-off and other full-power conditions."
Yes, using aircraft octane performance ratings you can get those numbers.
If you test the exact same sample, using automotive octane ratings, (R+M/2 method), you get like 96 octane. Which is doable now in unleaded.
The vast majority of aircraft are low compression, and do not need high octane fuel. So, even if they kept 100LL for the high compression engines, 80% of the lead could be eliminated, by switching the rest to regular unleaded.
/ LEADED vs UNLEADED #74
From here:
Avgas - Wikipedia
I feel now that I must confess.....
In my lifetime I have burned several million of gallons of 115/145.
There..........now I feel better.
/ LEADED vs UNLEADED #77
I read today, there is 2 grams of lead in a gallon of 100LL. That is much more than I expected, and I have spent a lot of hours cleaning lead out of aircraft spark plugs.
If you use what I believe to be a conservative figure of 150,000,000 gallons of 100LL burned per year, in the US, times 2 grams, and convert to pounds, it comes out to 661,386.79 pounds of lead each year?
No wonder the EPA keeps complaining about it.
/ LEADED vs UNLEADED #78
Yep. Avgas is the largest lead polluter in the country by far. I think people that burn it in their small engines should re-think it just on that alone. It's just not necessary.
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
(5) FOSTER 10' X 20' STEEL MATS (A64276)
(5) FOSTER 10' X...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
