Carry All
/ Carry All #21
Add a hydraulic top link and lower the pins on the carryall to make it a dump carryall.
Great idea. I need to get a hydraulic top link on my tractor.
/ Carry All
If you want to slide under a pre stacked pallet of hay what /pine said is true - forks are better. Did you consider a pair of clamp on forks for your bucket ? Same money as a carry-all.
gg
I did. The issue is hook up. When my back is out I can't lift more than a few pounds without causing more issues. So the forks would be a no go at that point. I can, however, hook up implements with the quick hitch on the 3 point.
The hay is small squares so currently stacked in a way that I cannot just pull under a pallet and move it.
If I am not having back issues what I do is put three long ways on the bucket, then two the other way on top of that and the one long way on top of the stack. My wife cannot stack them that high on the bucket.
However if we had a pallet on the ground she could stack them a couple three rows high. I could then use the tractor to lift that pallet and move it from storage to the stall barn to feed the horses.
I am also thinking then the ability to move pallets around with other stuff on them will save me some time and labor with other random tasks and I am sure stuff I have not thought of at all yet.
I do not have an SSQA set up or I would just by forks and be done with it.
A set of 3 point hitch forks that was quick hitch compatible would work probably even better. I could always throw a piece of plywood over a pallet if I needed something with a solid platform base for any reason.
Off to play with google.
/ Carry All #25
Being you're limited to weight, this probably won't work for you, but maybe others can get some ideas, if they want to build their own. It has a multitude of uses, from easily hauling 8 bales of hay, to cleaning horse stalls, and dumping on a pile, picking rocks up out of a field, and dumping in a wash, with out leaving the tractor. Hauls a good bit of firewood, and I can stock a good sized pile making several rounds, dumping in a pile, to be stacked later. I even used it for weight on the back of the old Massey 180, using it as a roller to roll the fill for the horse barn, and shop. I just backed my dump truck up to it, and dumped a load of fill material on it. What stayed on was my weight. When I was finished, I simply hit the hydraulic remote to dump it.
It's definitely earned it's keep around here, and sure has saved a lot of work, and time.
/ Carry All #26
Very nice. I like that :thumbsup:
gg
/ Carry All #27
I used the TSC CountyLine carry all frame. You might get some useful ideas from the one I built. Here are a few pics:
IMG_4981 - Copy.JPGIMG_4982 - Copy.JPGIMG_5005 - Copy.JPGIMG_5022 - Copy.JPG
/ Carry All #28
Welcome to TBN mpsmith60. Very nice job on that carry-all. Well thought out !
gg
/ Carry All #30
My carry all.
/ Carry All #31
mpsmith60- nice concept, nice work.
Tomtint, Looks good. If you have a receiver hitch on that Sprinter, and a 2" stub off the back of your carryall, it would be a good way to carry dirty/stinky stuff on the highway!
/ Carry All #33
View attachment 586632View attachment 586633View attachment 586634View attachment 586635
I made one very similar (how different can boxes be?) only using plywood. I made a 3 piece drop in tailgate with handholds cut it. On mine I made a hold-in bar to keep the sides from spreading and letting my tail gate out. I mainly haul firewood and it can put quite a bit of out pressure on the sides. I may have to add tool holders to mine now. Thanks for the idea and pictures.
Doug in SW IA
/ Carry All #35
Here's my carryall. Put a pallet on the bottom part and then built up from there. Back tail gate can be opened in 2 parts.
Ralph
/ Carry All #36
/ Carry All
This combines the info about my carry all build based on the TSC frame into one post. Here are a few pics:
Also here are the links to the YouTube videos showing what the carry can do and how to build it:
Versatile Tractor Carry All for My Kubota Tractor - Part 1 - YouTube
Versatile Tractor Carry All for My Kubota Tractor - Part 2 - YouTube
Let me know if you find any of the ideas useful.
Wow that is a nice design. I am thinking build something like that but in such a way it would be like lifting a pallet. That way I can set it down and use the carry all to pick up a pallet of "stuff" as well.
/ Carry All #38
Thanks! In fact, you can pick it up with pallet forks. They will slide right underneath on either side of the frame bottom. I've been considering adding some brackets and guides to the underside for pallet forks to make sure it stays on the forks while carrying uneven loads. I have several more enhancements in mind and I'll probably make a third video about them.
/ Carry All #39
Excellent videos. I’ve got the frame, I want to finish it this year. Best build video I’ve seen.
