Got Some Beaver
/ Got Some Beaver #1
otlski
New Hartford, CT
Jinma 204, Bobcat mini Ex, Terramite TLB, Polaris quad, Cub garder tractor
So this garden tool forum was sitting here all empty... And now that I got your attention, I figured I post something to get it started.
Last summer my 82 year old diabetic friend calls me and says "Hey, you use to have beavers. Do you still have them and if not, how did you get rid of them?" I explained to him that a January rain storm over topped the frozen beaver pond, washing out the dam, lowering the water level and likely killing the beavers. My next words to my friend were "Why do you ask?" He explained that some property he was selling now has a dam and the flooding was devaluing the property. He went on about how the town and state were less than helpful.
He then said that he was going over to the property that day to take the dam out; that he could not get his tractor or mini-ex near the dam unless he partly drained it enough to dry it out a bit. I asked if his grandson was going with him and he said "no". My next words were "I would love to take a little adventure with you today, give me an hour, I will meet you there". He said "wear boots you dont care about, and are you allergic to yellow jackets or poison ivy". My reply "I will see you there".
I grabbed every tool I thought was useful. Shovel, prybars, hoe, etc, and headed out. When I got there he told me the walk in was longer and we should choose carefully what we carried. I took an ordinary shovel and this.
Rogue Hoe Field Hoe with ... | Forestry Suppliers, Inc.
Let me tell you, there was no reason to bring anything else to start manually disassembling a beaver dam than that pro-hoe. What a great tool. Its compactness allowed me swing down near my feet while being precariously balanced on beaver chew logs. It was a pry bar, an ordinary hoe for trenching, a surrogate axe for severing logs and branches. I used it to chop and loosen the pile, getting under it and almost as a shovel to scoop the loosened mud/grass/stick-log mess up.
My buddy kept asking for me to hand it across to him so he could use it. We made good progress until I told him I needed a break: that is when he checks his sugar levels ;o)
The water level noticeably dropped and with any luck it would dry out enough. We broke for the day and he said he would come back with his grandson the next day "and oh by the way, can I borrow that fancy hoe of yours?" This is a man who I have no problem letting borrow tools.
Turns out that him and his grandson went back a couple of times, enough to drop the water level to where he got a mini-ex in there and finished the job. And they all lived happily ever after - except the beavers. Honestly, I think the beavers had already moved on because they did not fix the damage we caused overnight.
So if you ever have to manually disassemble a beaver dam - that pro hoe is the tool to use.
/ Got Some Beaver #2
Well, you got my attention. If you had started hoes it would be even better....
Btw, that thing looks like a grape hoe.
/ Got Some Beaver #4
Meanwhile, my beavers are leading me to become a beaver death expert. Got another permit to pullout another beaver lodge next year, but I'm going to try and trrap the beavers myself as a friend claims they have the best tasting meat on the planet, and this guy knows how to cook, so I believe him. Anyway, good story and thanks for telling us about that tool.
/ Got Some Beaver #5
I have one, or rather the city has to access MY property to get at the dam..
IT doesn't bother me but rather a neighbor 3 houses away.. the water backs up & floods his property..
The city came out w/ a backhoe & destroyed the dam.. only to put the spoils on the bank..
GUESS what happened.?? the beaver just built it back using his OLD material..
They didn't carry it off OR trap the beaver.. typical city planning..
/ Got Some Beaver #6
In my experience the only way to solve the problem is to set traps
/ Got Some Beaver #7
Last summer my 82 year old diabetic friend calls me and says "Hey, you use to have beavers. Do you still have them and if not, how did you get rid of them?" My next words to my friend were "Why do you ask?" He explained that some property he was selling now has a dam and the flooding was devaluing the property.
Wow this friend sounds amazing that at 82 he is still spry enough to get around that well, much less to be able to do that much work.
I sure hope that in 10 years that I will still be able to work like that as I do now.
/ Got Some Beaver #8
When I was a teenager, getting some beaver... or even seeing some, had an entirely different meaning..... :)
/ Got Some Beaver #9
Wow, Eric - do let us know how it tastes! I have a real beaver problem myself, as you may recall reading about here on TBN. Had to hire Tree Experts to cut down 17 big Poplar and white birches that the beavers had almost chewed their way through, and which were threatening my giant boat house up at the cottage.
The little bu___rs are still checking the boat house out on a constant basis, and I have had to install a radio and an LED light running 24/7 in order to keep them from stuffing all their sticks under the walls of the boathouse and making a big mess!
I must admit, though, I never thought of eating them! Well, there is a first time for everything. You first.
/ Got Some Beaver #10
Not to mention how you were going to cook it so it tasted good..!
/ Got Some Beaver #11
View attachment 581904Beaver well cooked isn't that bad but can still be a tad greasy. I have a family of beavers down on the far end of my little lake. They built and maintain a very fine dam on the outlet. It has had a very beneficial effect on controlling the water level. If you look closely - the dark spot inside the red circle is their house.
/ Got Some Beaver #12
I had the beaver problem at the other place,---BUT not for long!! They kept plugging the creek. The govt. dnr?, I think it was called, kept dumping the animals off the I-74 bridge onto my property!! After a few calls to them and some heated talk, along with a few bangs, they got the message that I wasn't one to mess with so they stopped dumping them and my problem went away.
These departments are S'POSED to protect us people, NOT create problems for us!
I have an actual letter about this problem.---It's very funny and actually true!--- I'm not sure how to post it! thanks; sonny580
/ Got Some Beaver #13
Beaver and wine are a good combination. But it was always hard to get wine when I was a teenager. :D
/ Got Some Beaver #14
Sonny - to post a document to a social web site - TBN. You need a scanner - you know - printer, scanner, fax machine. You scan the document and have it loaded onto your desktop. Then - just like loading a picture onto your post on TBN - click on the insert image icon - direct it to your computer - click on the page when it show up on the icon and it will load up as an attachment to your post. Its easier, quicker, faster to actually do, than to explain.
/ Got Some Beaver #16
I have a creek running across a corner of my farm. For the last 4-5 years beavers have been trying to secure a dam. This creek gets bank full (15ft) deep several times a year. Always washes out their dam. They try a different spot with same results.
They put educated human engineers to shame. :)
/ Got Some Beaver #17
Easier to take a picture of it.
/ Got Some Beaver #18
It just might be - I don't know if my ancient flip phone takes pictures. I DO know how to do it by scanning.
Besides - and I'm not being contrary here - I make phone calls with my flip phone - - I use my camera to take pictures. Just old school.......
/ Got Some Beaver #19
I have a copy of the letters in my doc. files on this computer, so will have to try a copy/post deal.
/ Got Some Beaver #20
Am I the only one getting the BigMouth Inc Eager Beaver River Tube ad from Amazon at the top of the page.....???? [[[ :) ]]]
2020 INTERNATIONAL MV607 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2020 INTERNATIONAL...
Grace Quick Attach Tree Puller (A66408)
Grace Quick Attach...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
2001 Mack CH613 Water Truck, VIN # 1M1AA18Y21W144276 (A65563)
2001 Mack CH613...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
MERRITT ALUMINUM HEADACHE RACK (A64277)
MERRITT ALUMINUM...
