zoedog2012
I think the PTO shaft is too long and not letting the 3pt all the way down.
The first photos had the blower tipped and the 3pt arms then were way up...not level. Any pushing against snow would of coarse lift the implement. The later pics at least had the arms level.
That's what jumped out at me too. No way was that going to work. The last pictures are much better. Small adjustments from that point is probably as good as it's going to get. Weight could help. A real beveled cutting edge could help. It's hard to see what it has. I think the main problem is the blower is made for a bigger tractor so the 3-point geometry isn't ideal. Lowering the lift arm attachment points on the blower would help with that.
Assuming that everything is working as it should, is it possible the blower is too high for the tractor? When lowering the blower, does the it change angle as soon as you start backing up? Could the blower frame arms be too high, pushing on the 3PT arms, resulting in an upward or downward angle? Without position control, it could easily happen. The 2060 isn't just a wider blower, but also higher. Perhaps a 1054 or 1060 would be a better fit for the SC2400. I have a C-48 on my MF GC2300, similar sized tractor, and have no issues.
View attachment 581163View attachment 581164View attachment 581165
Just to follow up and confirm:
lower tractor arms are sitting at just shy of 11 3/4" and the blower is a little more than 12 1/2" near the skids.
So it looks like I need to replace the blower.
If you make the top link longer, that will push the top of the blower away from the tractor and lift the lower tractor arms. If you put a level on the blower, you lengthen the top link until both the places you are trying to measure will be the same measurement. There is nothing wrong with your blower, your top link is just too short.![]()
This is copied from a 16 year old post from another forum. Might it be helpful in understanding this?
"Position control? I'll see if I can give you an explanation that makes sense (I've had a B7100 without it and a B2710 with it).
Without position control, the lever is centered and when you raise or lower the 3-point by moving the lever forward or backwards, it continues in an up or down movement until you center the lever again. The distance you move the lever may affect the speed with which it raises or lowers, but not where it stops. So you have to just go by visually watching to stop it where you want it.
With position control, the slot for the lever is usually numbered (1 to 8 in my case), with 1 being all the way down and 8 being all the way up. If you want to lower it to 4, move the lever there, the hitch stops at that point and the lever stays where you left it. It's much easier to make small adjustments in the height of the hitch, and if you raise it, it's much easier to lower it back to the same height again.
In other words, position control is a VERY NICE feature and I really like it, but it's not absolutely necessary."
