Rounded off drain plug
/ Rounded off drain plug
Dang it, Kando... I thought when I opened this thread this time, you were going to reveal a miracle!
Too cold for miracles, and I need to do laundry. Um, another excuse here.
/ Rounded off drain plug #788
I have a couple Knipex Cobra pliers too... they bite extremely well. A perfect tool to put on your xmas list! You know... for the guy that is hard to buy for. :D
Friiend is a roving tool guy and has a 31 foot truck chock full of stuff and somehow, coincidentally, I stock his favorite evening beverage. No tools on my Christmas list, he's already beat everyone to it. :p I am short on socks and underwear, nobody brings that stuff around the shop.
/ Rounded off drain plug #789
Friiend is a roving tool guy and has a 31 foot truck chock full of stuff and somehow, coincidentally, I stock his favorite evening beverage. No tools on my Christmas list, he's already beat everyone to it. I am short on socks and underwear, nobody brings that stuff around the shop.
You could be a politican. Even rich people envy you. You have alot of beneficial influence. I dont like one of my neighbors. I need you or the snap on man to move in.
/ Rounded off drain plug #790
Post #800 will soon be in the rearview mirror.:wave:
/ Rounded off drain plug #791
The pliers I prefer would work just as well, but they are kinda pricey....KNIPEX Tools LP - KNIPEX
Nope!
That job is now WAY BEYOND the capability of "water pump" pliers.
Water pump pliers might have been a good original try.
NOW....Pipe wrench ONLY....and a high Quality pipe wrench....largest possible to fit in available space.
/ Rounded off drain plug #793
/ Rounded off drain plug #794
Do you have one of these? They’re pretty expensive but it’s a handy tool. IMG_0721.JPG Here’s a tool that would have helped the op. It’s an adjustable wrench for square pieces. IMG_0722.JPG
/ Rounded off drain plug #795
Or use the correct tool for the job, a bolt extractor which covers the bolt head and bites in when turned counterclockwise. Get a set and have them. This will remove a bolt with a head that is completely rounded. Good luck...
I got this above set for lug nuts for $64.
On this drain plug the 1/4 - 3/4" set may be required but the nut option would let one get in a tight spot and use a long boxed end wrench to turn it.
/ Rounded off drain plug #797
^^^^ We have 800
/ Rounded off drain plug #798
Turbo sockets!
I brought that up too.
/ Rounded off drain plug #800
Your wife/SO would have to be able to appreciate unannounced driveway parties, loud noises (fireworks, cannon shots, un-muffled engines)and other assorted foolish nonsense we come up with. The crew has been known to head out on very short notice too. Apparently we are very difficult to live with when we have down time between projects. :D
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2017 Mercury SeaPro 115HP Outboard Boat Motor (A61574)
2017 Mercury...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
