Got started putting 1948 Allis Model B engine back together.
/ Got started putting 1948 Allis Model B engine back together. #1
Gale Hawkins
Super Star Member
Murray, KY
1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
This has been a hot summer project and summer left yesterday so we got the sleeves back into the block and got the crank finished today and the pistons loaded. Hope to get the head on tomorrow.
At age 3 in 1954 I played on Dad's Model B and started driving it when I was 5 while he was picking corn by hand.
I have no way of knowing what age it was but this 1948 is very similar except it has like a 50 year old Wood's belly mower on it. I bought it non running. It turned out the nearly empty bottle of Liquid Glass stop leak in the tool box had made its way into the crankcase. The bearings were nice and shiny but very thin. I have learned so much about this 19 HP engine over the summer. The machine shop saved the crankshaft and head. I cleaned up the sleeves and pistons and we are reusing them. I had to find a used rocker arm due to the Liquid Glass in the motor oil.
I am looking forward to hear the 70 year old tractor run.
I am looking at replacing the distributor points with an electronic version. As anyone done this with old gas tractors and what was your results?
/ Got started putting 1948 Allis Model B engine back together. #3
Did it on a 1953 Ford jubilee and a 1959 case 200 worked great in both cases.
/ Got started putting 1948 Allis Model B engine back together. #4
Changing a B over to points is a good thing. Wonder who converted it from magneto to a distributor? (Happens all the time, but all the older B models came with a magneto. I like the mag because you don't have to keep a fresh battery in them, just jump them off and go, or hand crank them.
The serial number located by the gear shift on the transmission will tell you the age of it. There are other ways to tell a general range of years, but serial number is fastest. Tractordata dot com has a serial number listing for it.
David from jax
/ Got started putting 1948 Allis Model B engine back together. #5
Keep the points!!!! ---the transistor crap will throw off the timing and everything else!!!! ---- been there and had to go back and replace the whole 9 yards!!! thanks; sonny580
Thanks for the heads up on the points because we're discussing doing that.
Do you know the why of this issue?
It is currently running a 12 factory looking generator but seems to have come with a magneto originally.
David from jax
Since the distribution shows little wear yet the governor weights and pins was worn so bad that I replaced them with tight used ones I am guessing the change over came related later in life.
I have worked it about 5 hours but today we put the skin back on it and got the lights wired. Now it is read for the Veterans Day parade Sunday week.
We got rid our our Model B in 1957 or 1958 for a Jubilee Ford (600) and I never thought I would own the tractor like I played on when I was 3 and started driving when I was 5 when Dad was picking corn by hand and got tired of getting off and on it. :)
The oldest son got put to work early but I guess it has paid off over the last 60+ years in one way or another.
/ Got started putting 1948 Allis Model B engine back together. #10
That is a real nice lookin B!!!
With that belly mower: it's not just a parade queen. It can work!
/ Got started putting 1948 Allis Model B engine back together. #11
transistorized ignitions, if properly timed, they are better than points.. yes, it does need to be properly timed with a timing light.. and as far as magnetos go, magneto's are the most reliable, that's why aircraft piston engines use them, nothing else..
/ Got started putting 1948 Allis Model B engine back together. #12
I love it gale Hawkins! I am also learning a lot about Allis Chalmers. I just bought a 1955 CA that I am going to restore.
Thanks Paystar. I think later models B, C CA's had the same 125 cubic inch engine perhaps.
Well coolant started to getting into the crankcase. Head gasket proved to be fine. Sleeve O rings proved to be fine.
Sleeve #4 cracked around the two lower O ring grooves. We had reused the old sleeves and pistons. After the first 5 hours we changed the oil and it was free of coolant so not sure when it cracked. That is a very thin area of the sleeve.
We have the old sleeves out and the block washed out with gas as of late last night so after a dry inspection we plan to order a new sleeve, piston, rings rod bearings and sleeve o-rings set.
The shop owner let me clean up and hone the old sleeves so I got a lot of first time experience going that deep into an engine. Wish this had not happened but on the redo we are going to revisit the steps. For some reason one rod bearing had a small hot spot showing. They were all at .002 clearance per Plastic Gauge. The crank looks clear rod wise. We did not drop the crankshaft caps.
I wanted to go with the standard 3 3/8" bore but it looks like the thinner 3 7/16" over bored sleeve kits are the only option. I am more concerned about forces on the crank than engine HP.
This time I plan to start with the Archoil AR9100 from the first fill of the crankcase and may just go with the Rotella T6 5W-40. The last time I ran 15W-40 diesel oil without the AR9100 for the first 5 break in hours.
/ Got started putting 1948 Allis Model B engine back together. #15
you should use kerosene if anything to wash the block out, Gasoline is way too dangerous!. suggested: soap and water, followed by kerosene!..
Plus it makes it hard to breath but the ethanol helped remove the antifreeze from the crankcase.
Got the new rebuild kit ordered today.
The new rebuild kit came today from Steiner.
/ Got started putting 1948 Allis Model B engine back together. #18
Mags. Are the least reliable!--had a bunch of them,--Now most have been changed to dist. ign.--Currently have a 38 B that is hand crank only and mag. ign. Guess what?--Won't start unless you pull start it! NO spark at crank speed. --This has been a problem with all mags. no matter what brands or what engines they are used on.
Aircraft ignitions are NOT anything like tractors.
Transistor ignitions are not successful in ALL engines.--- Old engines were not designed for them and some just can not be tuned so they work.-- I can't see spending that much money on something that has a 50-50 chance of not working on my engine. thanks; sonny580
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
INOP/NON-RUNNING 2015 International DuraStar 4300 Lab/Chassis Truck, VIN # 3HAMMAAL3FL514548 (A61165)
INOP/NON-RUNNING...
ALUMINUM FUEL TANK & DEHA ELECTRIC BANDSAW (A62131)
ALUMINUM FUEL TANK...
2001 CHAPPARAL B/STOCK TRAILER (A62130)
2001 CHAPPARAL...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
