Armorpoxy Floor coating.
/ Armorpoxy Floor coating. #1
countrybumpkin
Elite Member
Kioti, kubota
Finally got around to doing the floor coating for my shop it’s only been sitting 3 years waiting for me to make a decision on which coating and also the time to do it.
I ended up going with Armorpoxy brand and there armor ultra kit, it’s a 3 coat process. So far I’m really pleased how it turned out, how ever it was a LOT of prep work for 1 person with it only being 1200 Sqft.
First was many power washings of the floor and scrubbings , I then lightly went over the entire floor with a 7” hand grinder with a diamond cup wheel. The shop had only been used to store my tools and shop equipment since it was built but I did find a couple of spots were some oil leaked out of a tote and a piece of shop equipment. After cleaning many times I still could not completely remove the stain , so I ended up using a 2 part oil spot primer over the area were the stains were just to be safe.
The next day I did the entire floor with the 2 part epoxy primer.
On the third day I put down the epoxy and color flakes. ( The lighting in the pic makes it look tan for some reason but it’s light gray.)
Fourth and final day was the 2 part military clear top coat.
This was after a couple days of dry time.
Floor has been down about 4 weeks now and I’ve finally started doing electrical work and started putting the white wall metal up. Should really start to brighten up inside.
/ Armorpoxy Floor coating. #4
I build my drive shed in 2014 and was going to go with a fancy floor but the year got too late.
I have had major oil leaks and floor damage from moving equipment and skids around. Plus, so much dirt gets tracked in there, sometimes I think, what's the point?
Can it be scratched? Can one really clean up oil so the stuff will stick?
Yes it can be scratched by heavy equipment, nothing on the market is scratch proof. According to armorpoxy there are ways to get the floor into a usable condition to install a coating. If I were going to have heavy equipment with tracks and such I wouldn’t have done this type of coating. Also welding sparks and slag from cutting torches will put burnt spots in it.
/ Armorpoxy Floor coating. #6
Looks real nice! I just want to know how you could possibly wait 3 years without using the shop? I couldn't wait 3 hrs after the basics were all done...
/ Armorpoxy Floor coating. #7
What is the cost per square foot, lets say per 100, or 500?
/ Armorpoxy Floor coating. #8
That floor sure looks NICE.
/ Armorpoxy Floor coating. #9
Yeah, I think the last time I saw a floor like that, it had a couple of Mercedes cars parked on it.
Actually it went by pretty fast with all the other projects and stuff I had going on. I spent almost every day I wasn’t at work in my old shop for the last 15 years , so a little break the past 3 doing outdoor projects was nice.
Thank you, not sure how long I can keep it that way but we shall see. One reason I started this thread was to be able to update it now and then over a few years maybe and give some feed back on how well the floor holds up.
/ Armorpoxy Floor coating. #13
I did my garage about twelve years ago, with Epoxy Coat high solids. https://www.amazon.com/EPOXY-COAT-FULL-KIT-BEIGE-500/dp/B00C7VX2V4
I used the single coat system. Clean it, grind it, vacuum, paint it, flake it, dust with in traction sand, done.
There is some wear, in the areas where the car tires run, and trash containers are stored. But, has stayed down, it's still shinny, and looks good.
/ Armorpoxy Floor coating. #14
How did oils that may have soaked into the concrete clean up, assuming you had that?
/ Armorpoxy Floor coating. #15
It sure is nice. But I wonder if just parking my Duramax in there with tires coated in stone dust and possibly stones in the treads would play havoc with the finish.
/ Armorpoxy Floor coating. #16
Finally got around to doing the floor coating for my shop it痴 only been sitting 3 years waiting for me to make a decision on which coating and also the time to do it.
I ended up going with Armorpoxy brand and there armor ultra kit, it痴 a 3 coat process. So far I知 really pleased how it turned out, how ever it was a LOT of prep work for 1 person with it only being 1200 Sqft.
First was many power washings of the floor and scrubbings , I then lightly went over the entire floor with a 7 hand grinder with a diamond cup wheel. The shop had only been used to store my tools and shop equipment since it was built but I did find a couple of spots were some oil leaked out of a tote and a piece of shop equipment. After cleaning many times I still could not completely remove the stain , so I ended up using a 2 part oil spot primer over the area were the stains were just to be safe.
On the third day I put down the epoxy and color flakes. ( The lighting in the pic makes it look tan for some reason but it痴 light gray.)
Sweet job... well done.
/ Armorpoxy Floor coating. #17
They give you a prep to clean it with in the kit. That worked fine except one spot, where there was a prolonged power steering leak on one of my old vehicles.
That spot fish eyed a little. I dropped some paint in the fish eyes with a small brush the next day. It's not noticeable.
I did not anticipate a problem, or I would have soaked it with solvent, and used compressed air to remove it, prior to painting.
It's hard to get the paint spread out thin enough to get the 500 sq ft coverage the say the kit is good for. I have 450 sq ft, and I just got it all covered.
If it's the first time, I would figure to only get 400 sq ft, out of the 500 ft kit, so you don't have to sweat having enough material.
I also recommend buying the spiked sandals, so you can walk out in the wet paint, to broadcast the paint flakes, and sand. Buy extra, and practice spreading the flakes, and sand, the day before. It does take some practice to be able to keep your coverage even. Throw them upward, so they disperse more evenly.
/ Armorpoxy Floor coating. #18
When my garage was new I did the floor with a gray, single component, stain. I just washed it and did an etching rinse with muratic acid prep. 25 years old and still mostly gray. Makes cleanup a lot easier.
/ Armorpoxy Floor coating. #19
We have the same stuff the OP used on his floor in our shop. Gravel road, skid steer going in and out. It scratches the floor and dulls the finish. Takes a while to get to the point where you need to go over it. 10 years for us. We just went over it with fine floor sander. Then thin coat right on top. Did not cost anywhere near original job. Happy with it, makes cleaning oil and grease much easier.
/ Armorpoxy Floor coating. #20
Appreciate the real life feedback.
My experience, whatever you place value on, will suffer. Don't care, and nothing will happen to it. No one ever got a ding, scrape or dent in a junker vehicle parked in a parking lot.
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
