Vinegar coolant system flush?
/ Vinegar coolant system flush? #21
Because such information would add nothing to the question of the number of flushes that might be required to remove the residual acidity after a treatment with vinegar.
I certainly wouldn't want to diverge from that theme into "How many flushes with DI water does it take to neutralize my well water". ;-)
Vinegar rinses easily, that is one of the reasons it is used for cleaning.
Your explanation sounds like "spin" to me.
Whoa! I just "googled" ph of vinegar.
2.4 was the first response. That seems quite "strong" on a scale of 0-7. ;-)
/ Vinegar coolant system flush? #24
So, using the correct terms would add nothing to a discussion? But making up some bogus plus and minus does? :confused2:
Oohhhkay!
Bogus?
Ahh, You have little time in the lab.
/ Vinegar coolant system flush? #27
Hey Guys ,
New to the Q&A. I have a DK45 Kioti 2003. Looking for a good after market Canopy. Then add on different parts as the weather gets colder and I can afford more parts.
Thx’s Wallyt
Vilas NC
/ Vinegar coolant system flush? #28
I poured straight vinegar into the empty radiator and ran the engine through two heating cycles before dumping the flush.. (red residue evident?)
My tap water is a bit alkaline. How many "flushes" with tap water will it take to "neutralize" the acidic vinegar? \
If the answer comes to you,
"How many pancakes does it take to shingle a dog house? " ;-)
by the way, the visible portion of the cooler fill opening looks much the better for the vinegar flush!
I am late to this party, but doesn't most commercial radiator flushes contain a strong alkali rather than acid. Alkali cleans organic matter really well without affecting the base metal whereas acids will attack the metal.
Baking soda neutralizes acid quickly, so if you use household vinegar (a really weak acid) then a 1/4 cup of baking soda mixed with enough water to fill the system will turn the vinegar into a neutral. Any excess baking soda will flush clean since it dissolves completely in water.
Note: I don't think vinegar is going to do any damage to your cooling system if you don't get it all out. However, I don't know how compatible it (or baking soda) is with anti-freeze solutions so a good flush with tap water would be advisable. Get as much of the tap water out as possible then fill with anti-freeze/distilled water.
/ Vinegar coolant system flush? #29
Not to hijack this thread about tractor coolant system flushes, but here is my other experience.
I have several small outboard motors (aluminum) that are always used in salt water.
At the end of each summer I run them in a 30 gal. container of pure vinegar. I fill the 30 gal container only half full, and save the used vinegar for next year. I never follow with a fresh water flush.
These little aluminum block engines show no internal corrosion, and are over 30 years old.
/ Vinegar coolant system flush? #30
But you don't put coolant in a small outboard.
/ Vinegar coolant system flush? #31
My small outboards all use salt water as THE coolant.
Salt water is extremely corrosive.
This thread does seem to be about removing corrosion in cooling systems.
My point was intended to show that vinegar works as a corrosion cleaning agent, and does not necessarily need to be completely flushed. A minute amount will not damage anything even if it remains in a closed cooling system.
2020 POLARIS SPORTSMAN HIGHLIFTER XP-1000EFI ATV (A62131)
2020 POLARIS...
Bobcat MT85 (A60462)
Knapheide Service Bed (A61165)
Knapheide Service...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A61165)
2016 Volvo VNL...
UNUSED JCT HYD TRENCHER (A62131)
UNUSED JCT HYD...
2013 Case 850L Dozer (A64047)
2013 Case 850L...
