Purchasing the proper chain sharpener
/ Purchasing the proper chain sharpener #1
Wakey
Madison Georgia
John Deere Z915B Zero Turn 54 Deck
I have a few saws I'd like to get the Pferd or Stihl sharpeners. For my Stihl MS-291 Chainsaw that uses the https://www.amazon.com/dp/B0007ZK5KS/ref=sxts_kp_lp_2?pf_rd_m=ATVPDKIKX0DER&pf_rd_p=8778bc68-27e7-403f-8460-de48b6e788fb&pd_rd_wg=F5pWY&pf_rd_r=CHXZ50081DTJKPVNFKH5&pf_rd_s=desktop-sx-top-slot&pf_rd_t=301&pd_rd_i=B0007ZK5KS&pd_rd_w=rwkNT&pf_rd_i=stihl+26rm3+74&pd_rd_r=960c7cd3-0588-493d-81dc-d983e126e339&ie=UTF8&qid=1541167079&sr=2 I purchased the https://www.amazon.com/Pferd-17301Pferd-Chain-Sharp-Filing/dp/B003M4LGPE/ref=sr_1_1?ie=UTF8&qid=1540385922&sr=8-1&keywords=pferd++17301 It seems to be the correct one, perhaps someone can confirm? :laughing:
I've got a couple pole saws I'd ALSO like to get a sharpener for. These chains don't cost much but it is nice to touch up a chain while taking a break. The battery saw, Black and Decker 20 Volt LPP120 Oregon 90PX034X Chain 8 bar .043 ⅜ pitch 34 links and the TrimmerPlus head https://www.amazon.com/TrimmerPlus-PS720-8-Inch-Pole-Chain/dp/B0007MGCSU/ref=cm_cr_arp_d_product_top?ie=UTF8 on my gas trimmer uses the https://www.amazon.com/Oregon-R34-AdvanceCut-Chainsaw-Remington/dp/B000BOAG0O/ref=asc_df_B000BOAG0O/?tag=hyprod-20&linkCode=df0&hvadid=167146984279&hvpos=1o1&hvnetw=g&hvrand=14329922419374651716&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1015254&hvtargid=pla-305921216083&psc=1 R34 which might be the same chain.
When selecting the sharpener is it the pitch that matters? The R34 is 3/8 and the L74 for the Stihl is .325 (3/16?)
This is likely more difficult than it needs to be!
/ Purchasing the proper chain sharpener #3
I had one friend give me a cheapie bench mounted sharpener. I never knew you need different stones for different chains and one for the depth gauges.
So another friend in the small engine business clued me in. I got another sharpener at Princess Auto (Basically HF) and this guy, with his Oregon sharpener, tried it and actually gave it his endorsement. He said, for the price difference, the PRO sharpeners aren't worth it.
/ Purchasing the proper chain sharpener #4
Tried a bunch of different ones over the years, I go back to this one (the guide with the round file in it) every time.
/ Purchasing the proper chain sharpener #5
What TnAndy said...........
Cheers,
Mike
/ Purchasing the proper chain sharpener #6
I have two sharpeners - one is Oregon and the other is ??. Both clamp on the bar and have adjustment for pitch and angle. These are the only two I've ever used out here for 37+ years now. I go thru the round files like a kid goes thru candy canes.
When its really sharp - either saw - both are Stihl - can cut a long curley-Q in green pine.
/ Purchasing the proper chain sharpener #7
Just get a few proper sized files for your chain & sharpen often. That makes maintaining/ keeping the set angles much easier.
/ Purchasing the proper chain sharpener #8
i think I've said this before somewhere on TBN, But if you are cross-cutting, a chain is not supposed to cut a long curly-Q. Chains are designed so the cutter "porpoises" through the wood, taking chips, not ribbons. It is possible to cut a long curly-Q if you are cutting parallel to the grain (often referred to as "noodling"), but even a poorly sharpened chain will do that.
/ Purchasing the proper chain sharpener #9
I use a Dremel tool with the correct bit. I don't need to remove the chain and I can easily fix teeth that are damaged. I have a bench grinder but it takes much longer and I don't think it does a better job.
/ Purchasing the proper chain sharpener #10
Really?
Just fit a new chain when the previous one dulls, or call your man servant to make things better...
Best is to pick up a good saw file and learn to use it! It's not hard!
/ Purchasing the proper chain sharpener #11
Ive seen chips an inch or more long pulled from a cross cut in ideal condition.
Really?
There was a kid at the Ace near my last property that I paid $6 to sharpen my chains, he was a wiz. But one day he was gone and after that they had nobody that really knew what they were doing.
Cal, was that you? Where did you go?
/ Purchasing the proper chain sharpener #13
If you got a bunch of bulk chains. There is a guy in Ohio that has a couple 25K costing each franzen deals. razzorsharp
his pricing razzorsharp | Pricing and Shipping
He just posted this on my site. Send us 10 plus sharpenable chains at 1 time 0”to 36”= $7.00 (plus tax) per chain, we pay shipping back ������
I do it local for 5 myself.
/ Purchasing the proper chain sharpener #14
I use the Stihl 2n1 sharpener when refueling. After two of these sharpening s,I put the chains into the pro Oregon and bring the teeth all back to the same
length. No matter what method that you use, you have to keep the teeth the same length along with the raker depth.
Use all of the tools -- file, depth gauge together.
At age 70, the wife and chainsaw are at the same decibel, but I can understand the chainsaw!!!!!
JW5875
/ Purchasing the proper chain sharpener #15
How much market is there for chain sharpening? I was thinking about doing it. I only know of 2 places that do it in town and they both do an awful job. I could make a chain sharper than they can by putting it on backwards and cutting a brick. There’s no sarcasm there. If you saw my other chain sharpening thread I’ve got the hang of it and can do a pretty good job.
/ Purchasing the proper chain sharpener #16
I've been following this thread because though I've got 3 chains for each of my saws to stay sharp - and it works for the most part because I don't usually do a ton of sawing - I wouldn't mind being able to sharpen up on my own for those times that I'm dulling chain fast.
Local saw shop here sharpens chains for $5 each, a day or two turnaround (I'm almost never in town two days in a row so I'm not quite sure).
/ Purchasing the proper chain sharpener #17
Treat your self to a diamond file, its all I use, no guide just the file. They come in different sizes for different chains, but I always fit a wooden handle on the file.
/ Purchasing the proper chain sharpener #18
denchen,
Is this a file with industrial diamonds on it, a steel file with a diamond pattern, or a Black Diamond brand file? I'm all confused.
/ Purchasing the proper chain sharpener #19
I use steel files coated in fine industrial diamonds. Here in the UK I get them off Ebay, they are not too expensive. They last quite a while if they are not abused, and you let the file do the work and not use brute force.
/ Purchasing the proper chain sharpener #20
It is important to get the teeth the same length if you use a "non-progressive" depth gauge filing guide like this type sold by Oregon
The tool works by resting across two or more teeth, and measuring down from the plane established by those teeth. Since th eteeth slope back, getting shorter as you file them back, the heights can vary if you don't keep all teeth the same length. If you use the style in the bottom of the picture (with the "saddle" in the middle), the depth gauge height you get is determined by the average height of the two teeth. if you use the upper style (with the drop al the way at one end), depth gauge height is determined by the slope of the tool: if that slope is not parallel to the bar, the depth gauge height can be off significantly.
If I had to choose one of those two depth gauge tools, I'd use the type with the saddle in the middle, since the errors introduced by two teeth of unequal lengths are smaller. With the saddle on the end type, any errors are actually magnified. With either one, if you rock your chain and damage all the cutters on one side, then file them back till they are sharp again, all of the teeth on one side will be shorter in length - and thus shorter in height. Since the depth gauges are not matched specifically to their associated teeth, the teeth on one side of the chain take a bigger bite than the teeth on the other side. The saw will tend to cut in a curve. (If it gets bad enough, that curve will cause it to bind in the cut. Extended cutting under these conditions can also cause your bar to wear unevenly, contributing to cutting on a curve, even if you replace the chain with a new one.) The effect happens with either of the above depth gauge tools, but it is magnified with the "saddle on the end" type.
Since the Stihl 2n1 (aka Pferd CS-X) sharpener works on the same principal as the "saddle in the middle" type of gauge as far as setting the heights of the depth gauges, it's susceptible to all of the same problems. (Not as bad as the saddle on the end type, but still an issue). Keeping all of the teeth the same length avoids a problem with uneven cutting.
If you use a progessive depth gauge tool, each depth gauge is tuned to the tooth immediately following it. Because of this, it's far less important that the teeth be all the same length. I still eyeball them from time to time, and may take an extra stroke or two when filing the long ones, but having exactly the same length is not necessary. Here are a couple of progressive depth gauge guides (they all rest on one tooth, and file the depth gauge associated with that tooth):
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
2022 EZ-GO ELITE...
2025 Mini Bucket Excavator Attachment (A64553)
2025 Mini Bucket...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
King Kutter 5' 3-Pt Gear Driven Rotary Tiller (A66285)
King Kutter 5'...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
