Search function sucks!
   / Search function sucks! #1
IchabodCrayne
No place of consequence
Why does the search function on every forum using this format suck so bad?
It seems no matter how I change search criteria the same results just keep coming back over and over.
I know the topic is here, I've seen, it but no amount of time wasted on search will bring it up.
Not just this forum but all that use this format/template.
There would be far less repeat topics and questions if the search functioned even a little.
   / Search function sucks! #2
I know! I've complained about that a long time ago already. Of course, stuff like that IS NEVER FIXED!
But now, if the forum topic is Quick Hitches, they will be at the top of my screen for sale. THAT, they can do!
   / Search function sucks! #3
Try putting your search terms in " quotes". When you do that , only threads with that exact phrase will appear.
   / Search function sucks! #4
What are you searching for?
   / Search function sucks! #5
Rather than using the site search, use Google search. Type the following site:tractorbynet.com back blade (or whatever you want)
   / Search function sucks! #6
Doesn't it tottaly suck you have to jump through hoops like this instead of the forum having a direct SQL query to search within it's confines? It's craptastic.
   / Search function sucks! #7
What's so hard? There's a built-in Google search right at the top of the forum.
attachment.php
   / Search function sucks! #8
I type in "compact tractors designed wrong" and I get the following results...
attachment.php
   / Search function sucks! #9
It's sad, because there is so much information here that is pretty much inaccessible.
   / Search function sucks! #10
I type in "rock crawler hill mid range dog" and I get the following...
attachment.php
20FT X 30FT STEEL CARPORT (A58216)
20FT X 30FT STEEL...
Turfco Mete-R-Matic XL Towable Golf Course Drop-Style Topdresser (A55973)
Turfco...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
LANDHONOR LHR-PC90 HD PLATE COMPACTOR (A52708)
LANDHONOR LHR-PC90...
Eagle Weathervane (A55853)
Eagle Weathervane...
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A56858)
2007 Mitsubishi...
